Old 12-06-2017, 05:10 PM   #1
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
DIY: Installing MCS 2way remote suspension
Just finished up installing my new setup from MCS this past weekend. I put together what turned out to be a pretty lengthy install video. It includes the suspension install plus mounting and routing of the remote reservoirs.
PLEASE NOTE: There is an alternative (more proper) way to assemble the rear shocks with Vorshlag top mounts. You can use the silver springs perches that come with your MCS suspension kit, as well as a small spacer, in place of the OEM black upper perch that I used. Use the image in the below link as a reference:
https://vorshlag-store.com/collectio...ations
The rear shock mount configuration should look like this shock on the left, when using the mounts that I have:
[ame]http://www.youtube.com/watch?v=nh3cfXpYWag[/ame]
justinco is offline   Reply With Quote
Old 12-10-2018, 03:10 PM   #2
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
It was brought to my attention that I assembled the Vorshlag rear shock mounts incorrectly in this video. While my configuration does indeed work just fine, using the silver perches provided with the MCS kit is the proper way to assemble the rear shocks with the Vorshlag top mounts.
Unboxing my MCS 2-way remote suspension system justinco Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-23-2017 10:19 PM
KW ClubSports 2way 86Tony Brakes, Suspension, Chassis 2 06-27-2016 06:40 PM
KW ClubSports 2way 86Tony Canada Classifieds 12 06-27-2016 05:52 PM
Installing OEM Suspension Help mengmoua Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-17-2016 04:27 PM
Installing an Airlift Performance suspension on a BRZ Mach V Dan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-30-2015 12:20 AM
