Drives: Scion FRS
FR-S freeze plugs
Hi guys,
Has anyone changed their freeze/expansion plugs that is located on the heads. A machine shop took it off to compression test the heads and now I cannot find the right size freeze plugs anywhere. So if anyone know where I could get them from let me know please because Subaru and Toyota couldn’t help me out on it. Thanks. ![]() Sent from my iPhone using Tapatalk |
#2 | |
Hi ya, Jeshbud and welcome to our forum - ![]() I didn't realize these engines had freeze plugs - ![]() I have this burning question; why did a machine shop take the freeze plug out to do a compression test? To address your question, I'm going to refer you to ol @Ultramaroon to look that up in his big book of parts to see if he can get you a description/part number. humfrz |
#3 |
Drives: Scion FRS
Machine shop told me they needed somewhere to compression test, so they took that part off. I went to another shop to see if they had the part and they also wondered why they did that.
#4 | |
What part of the engine was being tested for compression? Why is a machine shop messing with your car's engine? If it were the cylinders, their pressure is usually done via the spark plug holes. If it was the cooling system pressure being tested, that is usually done at the radiator cap. Maybe someone will come along and help us out here - ![]() It must be my med time - ![]() humfrz |
#5 |
6/22/12-2/6/24
where exactly on the engine is this freeze plug?
Could you give a zoomed out picture of where it is on the engine
#6 |
LMGTFY
Drives: 13 FRS, 91 Miata
The question I ask is why YOU are looking for the part.
If they removed it, THEY should be the ones fixing it. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Tristor (10-24-2018) |
#7 |
Drives: Scion FRS
FR-S freeze plugs
H
#8 |
Drives: Scion FRS
#9 |
Drives: Scion FRS
#10 |
Drives: Scion FRS
#11 |
6/22/12-2/6/24
yeah I still don't recognize exactly where that part is on the engine :/
see if you can find it here https://parts.toyota.com/Scion_2013_...omponents.html
#12 |
LMGTFY
Is it threaded at all?
I've looked at every part listed online for the engine and nothing. Google has listings for lots of universal ones. |
#13 |
Drives: Scion FRS
#14 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
| OpenFlash Manager Freeze | GoJoshGo | Software Tuning | 14 | 12-23-2017 01:11 AM |
| coolant/anti freeze | Newtothegrounds | Engine, Exhaust, Transmission | 44 | 07-04-2017 07:39 PM |
| Help !! Wrong Anti freeze D': | UchihaFanBoy | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 02-11-2015 12:34 AM |
| Heaviest Shift Knob that won't burn / freeze your hand? | bren5279 | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 09-28-2014 10:18 PM |
| BRZ Navigation Freeze/Crash | TM | Electronics | Audio | NAV | Infotainment | 3 | 06-08-2013 01:29 PM |
