Old 07-24-2018, 08:34 PM   #1
mrg666
pessimistic skeptic
mrg666's Avatar
replacing the crank pulley on automatic
I will be replacing my crank pulley with fluidampr in a couple of days. My FRS is an AT and I read that I will do the replacement with transmission in Drive position. Do I need to do this Neutral instead? I bought the Company 23 crank pulley tool
Old 07-24-2018, 10:07 PM   #2
I don't see where it would make any difference. -
mrg666 (07-25-2018), Ultramaroon (08-12-2018)
Old 07-24-2018, 10:31 PM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
I made a tool much the same as in the pic but cruder.
I left it in park, inserted the tool at an angle towards the floor. Then I stack wood bits under the handle until it was wedged good and tight. I then got out the breaker bar, pipe extension and gave it a quick jerk to break it free.
Rinse and repeat to install it and torqued it to spec.
Then I reversed the procedure a few K later cause I bought garbage pulleys. Live and learn.
The Following User Says Thank You to new2subaru For This Useful Post:
mrg666 (07-25-2018)
Old 07-24-2018, 10:50 PM   #4
sid94
Drives: 2013 frs
If you got the tool you should be fine in any gear
sid94 is offline   Reply With Quote
The Following User Says Thank You to sid94 For This Useful Post:
mrg666 (07-25-2018)
Old 07-24-2018, 11:02 PM   #5
86TOYO2k17
Drives: 2017 toyota 86
I’m about to do the same fluidampr in my AT. I got a slightly diff tool but I think used the same. Anyways not sure but I read there is like a clip or someway to lock in the crank from moving to get pulley off. Not sure exactly. Should do a quick write up for me after you finish
Old 07-25-2018, 04:50 AM   #6
mrg666
pessimistic skeptic
mrg666's Avatar
Okay, thanks for the feedback so far. My main concern is avoiding damaging transmission or engine. I will let you know.
Old 07-25-2018, 07:43 AM   #7
Lantanafrs2
Drives: 2013 frs red
Put the breaker bar against the ground and flick the key. Just make sure you have it the right way.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 07-25-2018, 10:49 AM   #8
ermax
ermax's Avatar
I'm spoiled with a MT so I simply throw it in 6th with the ebrake. No tool needed.
Not sure you've read the torque specs for putting it back on but it's 15ft-lbs and then an additional 90deg. Make sure you oil the threads and head/washer before torquing it. You will also notice the bolt has hash marks every 90 which is handy.
Old 07-25-2018, 10:52 AM   #9
ermax
ermax's Avatar
I've used this method and it works well but I never suggest it to others due to the part I bolded. It's too easy for someone to not place the breaker in the right position and have it swing around smashing into crap.
Old 07-25-2018, 10:56 AM   #10
ermax
ermax's Avatar
Think about it this way. The car has 200hp and doesn't harm the tranny. No way will you be able to harm it with your arms and a breaker. Throw it in neutral with the brake set if you're really concerned. This will also allow you to freely rotate the pulley to whatever position works best for your tool.
Old 07-25-2018, 11:32 AM   #11
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I had to buy a tool, I couldn't get it to "break" the bolt since the car was moving several inches when I would try to apply torque to the bolt. Now I own a Company23 crank pulley tool I only used once.
Trueweltall is offline   Reply With Quote
Old 07-25-2018, 12:39 PM   #12
ermax
ermax's Avatar
The key is 6th gear.. not just any gear. The other trick is to put the breaker on the bolt with the handle as far to the right side of the engine bay as possible. Then put the car in 6th with the break off and then roll the car forward. This will plant the breaker all the way to the right and take up some of the slack. Now pull the brake. When you pull the bar it will only move about 10deg before all the drivetrain slack (mounts, gears and clutch disk springs) is taken up leaving plenty of room to break the bolt loose.
The biggest key though is 6th gear. It takes way too much movement of the crank to take up all the slack when in lower gears.
Old 08-12-2018, 04:41 PM   #13
mrg666
pessimistic skeptic
mrg666's Avatar
I have been driving with the Fluidampr since several days. The engine is running smoother at every rpm, even at idle. There is definitely less vibraton when engine revving up to 6-7k rpm. Very happy with the result.
AT definitely needs a tool to hold the pulley. I bought Company 23 pulley tool with FA20DIT Intake/Exhaust pin kit. The OEM pulley has large holes and the crank pulley pin kit works when removing the stock but these do not fit in the small holes on Fluidampr for holding it during installation of the new pulley. That is why Intake/Exhaust pin kit is necessary. It was a very easy installation with two important things to consider.
After the bolt is out, wiggle out the stock pulley very gently to make sure oil pump cover and the thin black o ring are left in place. If those are displaced, place them back very precisely. Once the stock pulley is out, apply oil to bolt head and thread, insert the new pulley after aligning the pin on the pump cover with the hole on pulley. Make sure the new pulley is sitting flush and secure, insert and tighten the bolt to 94 lb-ft torque. Install the belt again. Done!
Old 08-12-2018, 05:51 PM   #14
If one is dumb enough to try it without thinking about it then one will eventually do something else that is equally stupid. Might as well get the lesson over with quickly.
ermax (08-13-2018)
Removing crank pulley on automatic nlowell Engine, Exhaust, Transmission 11 11-11-2016 12:08 PM
SOSOSOS CRANK PULLEY AUTOMATIC HELP ScionFR-S Engine, Exhaust, Transmission 5 10-21-2014 11:30 PM
Lightweight crank pulley on an AUTOMATIC Gani21 Engine, Exhaust, Transmission 17 09-30-2013 11:27 AM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 11:12 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 08:45 PM
