| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Hot Lava FRS
Windshield fluid pump system - check valve failed
Hello,
I own a 2014 FRS - and more recently I started having issues with my driver side windshield nozzle. It was not spraying properly - and had a very weak trickle. After troubleshooting, I identified the culprit as the 3 way check valve. Has anyone else run into this issue? Symptoms: - spray was weak from one side - but seemed stronger than usual on the other. - motor pump is more audible - still in working condition - no change in spray pattern was seen when swapping the nozzles from left to right. Part Number: SU00302699 (*had difficulty finding as of June 2024) Alternative Toyota Part Number: 85321-28020 (Valve, washer) Part #29 in this diagram Last edited by zeroxg35; 06-11-2024 at 05:03 PM. Reason: adding new part numbers |
| The Following 4 Users Say Thank You to zeroxg35 For This Useful Post: |
#2 |
Famous Potatoes
Drives: '15 ultramarine
Nice diagnosis. Hope you weren't stranded somewhere.
#3 |
[insert cool phrase here]
Drives: BRZ Premium
Woh, my driver side nozzle has been weak as of late. Might be worth a shot on checking it out.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#4 |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#5 |
This is good stuff, @zeroxg35. Thanks for posting your experience for us.
#6 |
86
Stick a pin down the hole to clean your pipes
#7 |
#8 |
Weight Weenie
Drives: 15 FR-S
| The Following User Says Thank You to new2subaru For This Useful Post: | Boomerang (07-26-2018) |
#9 | |
Yep, THAT is a weird feeling - ![]() humfrz |
| Windshield washing fluid on freeway?! | FR-Sky | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 08-06-2017 09:48 PM |
| check valve behind pcv | myioz86 | Forced Induction | 62 | 09-07-2016 06:15 PM |
| Nameless overpipe/downpipe welds failed and perrin endlink failed | stockysnail | Northwest | 4 | 01-14-2016 07:27 PM |
| How many people have taken out the windshield wiper fluid tank? | ML | Engine, Exhaust, Transmission | 15 | 04-13-2014 10:07 PM |
| Windshield Fluid not pumping | taimysho0 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 06-12-2013 01:02 PM |
