Old 07-08-2019, 06:37 PM   #1
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
Catless Emissions?
Seeing that this has to do with the exhaust system. I was wondering if I would be able to pass emissions next year with a catless manifold. I know the tune tricks the the ECU and to be fair I live in Georgia and I believe all they do is stick something to my gas tank and plug something into the OBD2. I would hate to have to swap my headers just for an emissions but I wanted to get other people’s input on it.
Howaitoguru is offline   Reply With Quote
Old 07-08-2019, 06:49 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If they are sniffing the tailpipe you will most likely be screwed. It will pick up a high NOx reading. If it isn't you are probably fine.
Old 07-08-2019, 07:08 PM   #3
Howaitoguru
I don’t think they even check the tail pipe though they always just open my gas cap and put some device on there and then they plug something into the OBD 2 port. I’ve never seen them go to the back and get down and check the exhaust.
Old 07-08-2019, 08:11 PM   #4
steve99
Drives: FT86
Different states different checks. As above depends how extensive checks are. Ie if your jn california you will likely fail with anything but stock tune and stock engine components.
http://www.ft86club.com/forums/showthread.php?t=130030
Old 07-09-2019, 02:02 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
steve99: makes me think that while that won't do for disabling P0420 on catless, but there might be some sense in piggyback solutions for use in Cali for sake of leaving CALID/CVN same but for engine to actually work different.
Old 07-09-2019, 01:00 PM   #6
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I am completely catless and e85. I feel no sympathy for the people behind me who smell the corn. Lol
And Oklahoma is emissions free
Dr. BRZ is offline   Reply With Quote
Old 07-09-2019, 01:36 PM   #7
radroach
Drives: car
@Howaitoguru it seems all you need to pass is the gas cap pressure test and the OBDII readiness check.
Check this post by @steve99 http://www.ft86club.com/forums/showp...6&postcount=34
Who says you might be able to skirt by as long as you don't disable any codes (P0420) from your rear O2 sensor, it MIGHT not throw a code for some time. Some catless headers have a built-in O2 spacer which will help you to temporarily get passed.
I suggest trying a dry-run through the emissions place after installing and seeing what you can do, and post results.
The Following User Says Thank You to radroach For This Useful Post:
Howaitoguru (07-09-2019)
Old 07-09-2019, 02:07 PM   #8
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If there's no visual inspection, no tailpipe inspection, and your car throws no codes, then you'll be OK. An aftermarket header will fail a visual and a sniffer, and will fail if your tune doesn't work around codes.
Old 07-09-2019, 07:27 PM   #9
Howaitoguru
So what tunes wouldn’t work around codes? Open Flash? Delicious? I know they don’t make custom tunes to break emissions laws.
Old 07-09-2019, 08:08 PM   #10
EAGLE5
Dismember
EAGLE5's Avatar
I don't know. Never tried to pass smog with catless. Probably they all could do it if set up right. I'd talk to your tuner. I'm sure delicious could set it up not to throw a code.
Old 07-09-2019, 08:16 PM   #11
radroach
Drives: car
@Howaitoguru There isn't a tune that "works around emissions", your car needs to be able to throw problem codes in order to pass emissions. This is called "readiness" - No ability to throw codes = no readiness, no pass.
https://www.obdautodoctor.com/scanto...tors-explained
There are ways of modifying the tune (romraider) to enable / disable problem codes. Again, in this case you want them enabled for readiness.
To pass your emissions, you need to use techniques to hopefully temporarily trick your car into not throwing codes; that is O2 spacers and (guessing here) driving around in closed-loop mode by driving around super slow / low rpm / low throttle.
What exhaust to pair with my Catless UEL & Dual-Resonated FP (Catless)? kev0 Engine, Exhaust, Transmission 7 05-09-2019 09:29 PM
MD emissions BR-ZED Mid-Atlantic 3 12-11-2018 10:10 PM
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 08:13 PM
Frontpipe catless/hfc and emissions, sound level... steveholt Engine, Exhaust, Transmission 20 04-05-2015 01:11 AM
Emissions - MD TheseColorsDontRun Mid-Atlantic 6 08-23-2013 07:06 PM
