| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: ford focust ST
17x7.5 vs 18x7.5 wheel
Hi Guys,
I currently have stock wheels which are 17x7.5 48 offset. Do you think 18x7.5 48 offset will fit without any issue? Im asking this because I will keep the stock suspension and I will not lower my car. someone told me that stock suspension can't handle 18x8, so what about 18x7.5? |
#2 |
Only users lose drugs.
Drives: All the time
If only there were a sticky thread somewhere, perhaps at the top of the wheel and tire section of the forum, which could link to the information you need...that'd be just great. Maybe if it had a catchy name like "Will this fit?", so people would see it easily...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | churchx (05-02-2018), funwheeldrive (05-02-2018) |
#3 |
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Try the calculators below for whatever setup you want to try. Its not just the wheel size, but also tire width and height.
https://www.rimsntires.com/specspro.jsp https://www.willtheyfit.com/ https://tiresize.com/wheel-offset-calculator/ I didn't plug in your values since you didn't mention what you want for tires, but off the top of my head I don't see why 18x8 wouldn't work.
#4 | |
#5 |
Drives: 2013 Firestorm FR-S
So plug it into the tools he linked to, start using the information and resources already available to you (like the SEARCH feature and very helpful technical guides located all over this forum), and quit making a bunch of useless/repeat threads.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | Mr.ac (05-02-2018) |
#6 | |
Senior gif poster
Drives: 2013 Asphalt FRS
I thought all stock 86 wheels were 17x7 w 48 offset |
#7 |
#8 | |
It says there's no result whatever I serach for. |
#9 | |
Country Boy 4 Life
THE WHEEL DIRECTORY This is a guide with info on what will fit and a compilation of almost all members wheels, specs, and pics. https://www.ft86club.com/forums/showthread.php?t=7535
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Shark_Bait88 (05-02-2018) |
#10 |
No idea what you're searching then. I typed "18x7.5 fitment" and got 25 thread results. The 1st and 3rd results both led to the wheel directory, which has plenty of examples of wheels with similar specs that could answer your questions or at least give you an appropriate existing thread in which to ask your question. Sometimes you have to do some digging.
#11 | |
Drives: 2018 BRZ Limited, 2017 Sportage
2. There is no performance reason to go to 18's especially if you are keeping the same offset. 3. If you are keeping the stock suspension, it means you are not racing the car. Therefore, there is no reason to go beyond 215's or 225's for the width of the wheel. Both of these will fit on 7", 7.5", and 8" rims. 4. 17's will give you a slightly better ride and protect the rim more as there is more sidewall. 18's can give slightly better cornering, but the increase is so slight I doubt if you would notice it. 5. If you have that money burning a hole in your pocket, buy better tires. That is the one thing that will make a big difference if you have OEM tires. I started a whole thread on this topic and have ended up keeping the 17" OEM rims but changing the tires to 225/45/R17 Michelin Pilot Sport 4S -- the same model that is on the tS (except the tS has 18" rims). I really wanted to justify buying new rims, but in the end, it would have been only for looks. If you are just in it for looks, buy what you want and forget that it might negatively impact performance. |
#12 |
Drives: 2018 WRX STI
This may be of interest:
http://www.ft86club.com/forums/showthread.php?t=24102 (Note that the wheels in that thread are insanely light at something like 16 pounds...obviously, most 18-inch wheels will not save weight over an OE 17-inch wheel, and can entail a loss in acceleration and fuel economy, with often limited handling gains in regards to street performance.) |
#13 |
Site Moderator
Drives: ichi 86 Project
It's all up to offset of the wheel. I've ran 18x8 +35 (225/40 tires) w stock suspension without any rubbing.
As long as you accommodate width of the wheel with offset of the wheel, it won't rub. |
#14 | |
For number 1, It is 17x7.5. My car is BRZ performance package. Yea, I am not racing, and only reason that Im considering 18 wheel is for look, but I am concerning that 18" will make my car look like off-road car, and fuel efficiency bad. I am considering either 17x7.5 or 18x7.5 (JDM STI wheel) now with 225/45/R17 (or R18) Michelin Pilot Sport 4S -- the same model that is on the tS |
| Wheel Directory: TRD SF2 18x7.5 +46 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 07-22-2016 08:22 PM |
| What Wheel is this? 18x7.5 5 Spoke | continuecrushing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 06-15-2016 02:44 PM |
| Wheel Directory: Work Emotion XT7 18x7.5 +48 / 18x7.5 +42 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-26-2013 09:42 PM |
| Enkei EKM3 17X7.5 or 18X7.5 for a DD | FR-S Matt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 02-27-2013 01:36 AM |
| (SoCal)TE37 17x7.5 OR Tom's TN06 18x7.5 (both bronze & 5x100) | bino | Wheels and Tires | 17 | 11-13-2012 02:04 PM |
