Old 04-20-2018, 07:40 PM   #1
cocoy_labuyo
Drives: WRB BRZ
Need HELP. Car doesn't turn on
I need your help. My car is not turning on at all. It doesn't crank and accessory doesn't turn on. I was installing my coilovers and I accidentally hit the positive with my wrench. I have checked the fuses unless I missed something and the battery is at 14v. Even took out the terminal and sanded a bit then put it back but I still can't turn it on. What else can I check to fix this? Thank you
I wasn't sure where to post this.
cocoy_labuyo is offline   Reply With Quote
Old 04-20-2018, 07:49 PM   #2
sid94
Drives: 2013 frs
Did you check the fuses on the terminal? There are 2 iirc that could be your problem
sid94 is offline   Reply With Quote
The Following User Says Thank You to sid94 For This Useful Post:
Erick KY (04-20-2018)
Old 04-20-2018, 09:50 PM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Yes, check these 2. Fusible link block comes as an assembly with both fuses. Part# 82211CA010
BirdTRD is offline   Reply With Quote
The Following 3 Users Say Thank You to BirdTRD For This Useful Post:
humfrz (04-20-2018), new2subaru (04-21-2018), Teseo (04-21-2018)
Old 04-20-2018, 10:38 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Check ALL the fuses first then get back to us.
Under hood and in car.
Old 04-21-2018, 10:18 AM   #5
cocoy_labuyo
Drives: WRB BRZ
thank you everyone. it was the fuse on the terminal. good thing it's a cheap part.
Winjet doesn't know direction to turn for adjustment on headlights. Anyone here know? Username Cosmetic Modification (Interior/Exterior/Lighting) 1 10-05-2016 04:54 PM
LED stripe doesn't turn on on my FR-S Terruko Scion FR-S / Toyota 86 GT86 General Forum 17 09-10-2016 12:01 AM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 11:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 07:47 PM
Why doesn't traction/stability control actually turn off? Ganthrithor BRZ First-Gen (2012+) — General Topics 84 09-13-2015 02:37 PM
