Drives: 2014 MY15 86 GTS
Spoiler
Anyone done a rear spoiler swap from a limited brz/GTS prefacelift to limited brz/GTS facelift
Was it a straight swap? Also is the facelift rear tail lights the same on 86GT and 86GTS? |
#2 |
Yes, it's a straight swap. However, F/L models have extra pin that fix the spoiler in addition to 2 holes on each side. You can remove the pin easily, and you will be able to swap the F/L spoiler on the pre-F/L model.
Tail lights are the same. No need additional wiring jobs. |
#3 | |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
Is directly replaced with this spoiler, which only has 3 contact points, without leaving holes in the trunk? Maybe I'm missing something, wouldn't be the first time, but to me that doesn't look like a direct replacement. Looks like modification of the trunk is definitely required. Maybe the furthest mounting holes are the same, but it looks to me like you're going to need to do trunk work on everything inbetween. |
#4 | |
ProCrastinationConsultant
16+ holes are also further forward, so the '13-15 spoiler won't cover front to back either.
#5 |
Thanks for replies guess I’ll have to do a rear boot swap to have that spoiler.
#6 | |
I'm in the same position as you, and it's the main reason I haven't gone away from the original 13 spoiler yet. I'd be doing a full boot swap as well, probably to one that never had a spoiler (and therefore has zero holes) so I could put whatever spoiler on I want whether it be the newer OEM one or an aftermarket one. Buying the limited version definitely looked great at the dealership with the added perk of a spoiler, but as soon as you try to change it out, you realize the non-limited boot has the advantage and is actually easier to upgrade. |
| The Kiske spoiler, Skyline GT-R R35 Spoiler vs. ebay replica | soundman98 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-29-2020 09:53 PM |
| Battle Aero Swan Neck Spoiler Paired W/ Rocket Bunny V2 Duck Bill Spoiler | Preppy | Cosmetic Modification (Interior/Exterior/Lighting) | 30 | 02-10-2017 09:20 PM |
| BRZ Limited Spoiler. Is their any spoiler that uses the stock spoiler holes? | FR-Sizzle | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-21-2015 02:29 PM |
| FS OEM BRZ Whiteout Spoiler or Trade for Rear Lip or Duckbill Spoiler | Tripp1117 | Exterior Parts (Aero, Lighting, Etc.) | 1 | 07-11-2014 03:58 AM |
| Special: FRS/BRZ TRD & Stivo spoiler hybrid Spoiler design | JonMotoring | Groupbuys | 22 | 06-23-2014 02:03 PM |
