| Software Tuning Discuss all software tuning topics. |
#1 | |
Drives: GT86 AT 2013
O2 Lambda Sensor Deactivation?
Hey Guys,
As i want to go catless i am wondering what need's to be done to deactivate the O2 Sensors? Will it affect the engine if i don't change the software? expect from the error code poping up and the check engine light. I did find some info's in some posts here, but im still confused about the things they talked. Quote:
Can someone please explain me what to do? ![]() I also heard about putting a spacer inbetween but if it can be done with software this would be a better option for me. for info i got a 2013 GT86 EDM with AT transmittion Thanks for your time! |
#2 |
Drives: 2014 GT86
If ECU detects problems with primary catalisator (by using said O2 sensor), it will throw appropriate CEL (don't remember which code), and will disable cruise control. Except that no other ill effects.
One can disable those checks in ECU tune. Most popular for this platform ECU tuning solutions are Ecutek/OFT/Tactrix. Ecutek might be better option if tuned with professional tuning shop, OFT & Tactrix might be better choice for ones to DIY tinker. |
#3 | |
I am sorry, I forgot to mention that i got tactrix and i know how to flash the car. But i don't know what to edit in Romraider to achieve a normal working car without that o2 sensor
#4 |
Drives: 2012 GT86 EU-spec
If going catless you want to deactive the CEL for the secondary o2 sensor, thus disabling the P0420 cel in the software using romraider, this has been done by default on the stage 2 tunes by Shiv and Wayno. Also you can disable the secondary o2 sensor fueling adjustments.
#5 | |
![]() When i also disable the fueling adjustments i guess the ecu will not try to get better lambda results anymore, so the engine should run better? Can you also tell me the code for this one? Thanks for your help guys! |
#6 |
-The P0420 you can just disable in romraider
-For the trims of the secondary sensor, see the link below, it seems to make fueling more predictable: http://www.ft86club.com/forums/showthread.php?t=121126
#7 | |
Drives: FT86
Mate your over thinking this if you have oft or Wayne tune for sage 2 that already set up for catless header with correct tune setting and p0420 disabled. Just flash it amd drive. You dont need to disable o2 senasors to run catless just the cat efficiency cel code P0420. You still need the sensors to work The stuff you were looking at was likely if you wanred to completly remove the Rear o2 sensor to ise as flex kit input |
#8 | |
![]() The thing is im not sure if i can go stage2 right now. It's the plan in future for sure. But right now i got the 1st cat removed, and a hole in the 2nd one. so i guess thats not enough for stage2? So iwanted to keep stage 1 for the next week cause im a bit busy atm. and then remove it fully. What would happen if i flash stage 2 and there is not enough flow? do you know that? |
#9 | |
Drives: FT86
Just open your stage1 tune in romraider and disable P0420 then reflash will stop the cel light |
#10 |
| P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help | Johnders2586 | Issues | Warranty | Recalls / TSB | 9 | 04-04-2023 03:32 PM |
| is the front o2 sensor a wideband sensor? | mad_sb | Engine, Exhaust, Transmission | 19 | 12-13-2015 02:20 PM |
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 06:39 PM |
