Old 08-14-2021, 11:33 AM   #1
daniloneil8
Had a hard time seating new brake pads
I put in the new metal sheet metal things, and lubed the pad ears, and it was a real hassle to get the pads to seat in the notches. Is this normal? I had to jam the metal sheets with a screwdriver to make they were fully seated into the notch. Even still, the pads did not just slip into place easily.
daniloneil8 is offline   Reply With Quote
Old 08-14-2021, 03:22 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
what replacement pads did you use?
likely an issue with the specific company
Old 08-22-2021, 03:50 PM   #3
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I’ve had the same experience when installing aftermarket pads which included new clips. They just didn’t seem to seat in well making the pads impossible to install.
I resorted to cleaning up the original OEM clips which showed no wear and reusing them. The new pads went in easily then. Damn aftermarket crap!
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
strat61caster (08-22-2021)
Old 08-22-2021, 04:18 PM   #4
daniloneil8
Centric
Old 08-22-2021, 04:19 PM   #5
daniloneil8
I had no issue with clips.
There were none on Centric pads.
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails oppiee Canada Classifieds 4 10-07-2019 06:27 PM
Changing Brake Pads for the first time. vincelive123 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-22-2016 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
People having a hard time with the FR-S blind spot driver01 Scion FR-S / Toyota 86 GT86 General Forum 28 06-16-2012 04:27 PM
