Old 08-23-2017, 03:05 PM   #1
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
Coilover VS Spring/Shock
what would be better? ive been looking at either Tein Flex A of Flex Z or go with lowering springs and shock combo. the car is my daily all year round(during winter) and i like the idea of being able to adjust the height for summer and winter ride. from other peoples thoughts and knowledge what would you reccomend?
ImAdopted is offline   Reply With Quote
Old 08-23-2017, 03:28 PM   #2
Coil overs are springs and shocks.
Although the ability to adjust heights for summer and winter sounds great the question is would you actually do it? If yes then it may be worth while. Keep in mind that you may need to get an alignment each time you changed heights though.
I have the RSR Super low springs and winter drive my car with no issues.
8RZ (08-23-2017), Lynxis (08-24-2017), strat61caster (08-23-2017), wparsons (08-23-2017)
Old 08-23-2017, 03:47 PM   #3
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
i meant lowering springs and some konis perhaps or if i should by pass and go straight for a coilover setup. if its only twice a year (when i change out from winters to summers) then it may not be super bad but your right about if i actually do it lol. do you have any close up pics of you car? im interested in the drop and how much wheel gap is still there
Old 08-23-2017, 04:00 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Here's what some aftermarket adjustable coilovers look like after living through some winters. In a few years you may not be able to adjust ride heights. Springs and struts can give you just as much if not more of what you want while being a little lower maintenance and longer lifetime.
Also take a look at this thread:
http://www.ft86club.com/forums/showthread.php?t=121262
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
8RZ (08-23-2017), ImAdopted (08-23-2017), Tcoat (08-23-2017), Teseo (08-23-2017)
Old 08-23-2017, 04:27 PM   #5
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
oh lordy yeah i dont want that lol even though the Tein Flex A says its all coated and protects from rust and protects against chipping and peeling it still brings concern. i suppose i could get bigger wheels for summer as this is the look im going for
Old 08-23-2017, 05:03 PM   #6
DAEMANO
Time Traveller
Very shortly, I'm going to be swapping out my RS*R Sports-i coilovers for Showa Evolution spring/shock combo. Reason being is that I want a less complicated setup that still lowers the car a little and offers great ride. The Sports-i's have been fantastic but they include features I currently don't need. Extra features = more potential points of failure. As the original OEM shock manufacturer Showa knows this cars suspension perhaps better than any other aftermarket company. So I told myself why not give it a shot? This is a gen 2 design that should be even more durable than OEM components. Let's see.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
sugoi (08-23-2017), Teseo (08-24-2017)
Old 08-23-2017, 05:05 PM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
If you want a coilover that has a finish that will stand up really well, I suggest a KW product, (v1 is a great starting point,) or the RCE T0's. Made by KW with the same coating, valved and sprung to RCE spec!
I run ST's, the less expensive little brother to the KW V1's, and they wear well also. Every wheel and tire change I use a some WD40 and a nylon brush to clean the threads, then put a light coating of silicone grease on the threads. I used to use a copper based antisieze, like Wurth DBQ, or the Permatex copper, but have moved to silicone lubricant since it stands up really well, and is easier to remove. A tube of it will last the life of your coilovers and then some applying it twice a year if you're not overly generous.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Racecomp Engineering (08-24-2017)
Old 08-23-2017, 05:25 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
just remember that adjustable coilovers of any kind, no matter how durable, require you to inspect them periodically.
Maybe not every week, but at least once every 1-3 months.
Coatings are great but spring collars still move around and come loose. Same with upper mounts.
If you are the "install and forget it" type, get spring/shock.
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
churchx (08-24-2017), ImAdopted (08-23-2017), strat61caster (08-23-2017), Teseo (08-24-2017)
Old 08-23-2017, 06:14 PM   #9
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
to be fair i can fall in that category of "that guy" lol maybe it would be best to avoid coilovers as they are too much for a guy like me aha. plus a spring/shock combo should be cheaper to buy, maintain and fix up.. correct?
Old 08-23-2017, 06:55 PM   #10
Gunman
Drives: 2019 Mazda Miata RF
Technically, the stock spring and damper setup, IS a coilover
The Following User Says Thank You to Gunman For This Useful Post:
Old 08-23-2017, 07:17 PM   #11
mav1178
mav1178's Avatar
A proper spring/shock setup should not only last you a long time, it would probably never need to be serviced as long as you install it properly with the required bumpstops, new dust boots, and possibly new upper mounts at the same time.
A proper spring/shock combo should last you as long as the OEM setup, somewhere at least 4-6 years if not longer.
Zero maintenance other than checking for play in bushings, washing away excessive buildup of road grime/dust, and not attempting to drive in any condition where you will bottom out the suspension.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
ImAdopted (08-24-2017), Teseo (08-24-2017)
Old 08-24-2017, 10:22 AM   #12
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
[QUOTE=mav1178;2967364]A proper spring/shock setup should not only last you a long time, it would probably never need to be serviced as long as you install it properly with the required bumpstops, new dust boots, and possibly new upper mounts at the same time.
Zero maintenance other than checking for play in bushings, washing away excessive buildup of road grime/dust, and not attempting to drive in any condition where you will bottom out the suspension.[/QUO
so much knowledge in you lol thanks . but as long as i dont go offroading i should be fine i think aha the roads here arent THAT bad
Old 08-24-2017, 05:04 PM   #13
Here's something I wrote up a little while ago on this topic:
http://www.ft86club.com/forums/showthread.php?t=45542
Showa spring/shock available soon mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 110 01-04-2023 03:03 PM
BR Racing Coilover shock keeps blowing Moooiiissst Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-21-2016 05:16 PM
Suspension UPGRADE - Shock/Spring Pkg vs. Coilover System - Which to choose? themajesticone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 80 11-14-2014 06:01 AM
coilover shock body height adj garfull Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-19-2013 03:32 AM
