Old 08-18-2017, 04:16 PM   #1
PR138
PR138's Avatar
Drives: '14 WRB BRZ | '17 CB STi
EcuTek maps separate learning or not?
This may be a dumb question, and I apologize if it is because I have no idea what keywords to search to get an answer for my question.
I have a flex fuel setup with EcuTek, all maps are set for flex fuel but have different RaceRom features on each map. For example, map 1 has no special features other than flex fuel, map 3 has launch control, flat foot shift, rev match on downshift, and traction control.
Does anyone know if each map is self contained as far as short/long term fuel trims and throttle learning, or if they're all using the same learned fuel trims but with just the different RaceRom features per map? I'd think they share the same learned trims since you can switch maps on the fly, but I'm just curious if this is the case.
Edit: now that I think about it a bit more, if the same tune was copied across each map and they just modify the existing car's ECU learned tables, they'd all be the same no matter what since they'd be using the same baseline. The only way it'd be different is if each map had a separate ign/fuel mapping applied to it. Is this correct?
PR138
IG: @pr.138
2008 LBP Honda S2000
2013 UM Scion FR-S
PR138 is offline   Reply With Quote
Old 08-18-2017, 04:20 PM   #2
steve99
Drives: FT86
When you switch map modes in ecutek 1,2,3,4 the fuel trims are same
You just switching
Racerom features
Base timing and fueling maps
Any custom maps activated on each map mode
All ecu learned parameters are same regardless of map mode setting
PR138 (08-18-2017)
Old 08-18-2017, 04:36 PM   #3
PR138
PR138's Avatar
You just switching
Racerom features
Awesome, that confirms my thinking and it makes sense. Thanks!
PR138
IG: @pr.138
2013 UM Scion FR-S
Ecutek Help, Can't seem to choose maps Allan13 Software Tuning 5 12-31-2014 12:55 PM
Can't seem to swap maps Ecutek Vex Software Tuning 3 07-02-2014 05:57 PM
EcuTek ProECU PI/DI Maps Added EcuTek Software Tuning 1 12-22-2013 10:23 AM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
EcuTek Gurus - questions about RaceRom feature maps RehabJeff86 Software Tuning 8 09-09-2013 02:22 PM
