Old 08-26-2019, 01:44 PM   #1
TheLaughingMan
TheLaughingMan's Avatar
Popping/creaking noise in hard left turns
So I have been experiencing this issue for a bit and I haven't been able to figure out what it is.
When I make a hard left turn, meaning the load and pressure are shifted to the right side, there's a popping/clunking/creaking noise that comes from the right front wheel. It also happens sometimes when going over potholes/bumps. And almost certainly happens when turning left OVER potholes/bumps. It can happen more than once during a turn.
It definitely seems to be more prevalent during hard, 90 degree, turns as compared to slow gradual curves in the road.
I have stock suspension and 36k miles on my 2013.
Any idea what this might be? I am not sure if it would be steering or suspension, nor what specific component might be causing it.
TheLaughingMan is offline   Reply With Quote
Old 09-20-2019, 06:01 PM   #2
Silverz
Drives: Black frs
Your car is too new and low miles for a lot of the suspension problems. Especially if you haven’t run over any big pot holes lately.
I would check for the simple stuff first. My noise ended up being that the grill was pulled and separated from the front bumper because I parked over a wheel stop and it pulled on front bumper when I backed out.
When I went to the dealer, they told me it was my right strut/spring. They wanted $700 to change out one. I had a lot more miles than you. I bought a used set from eBay and changed out both the front left and right strut. Still heard popping. Then changed out my right tie rod. Still heard the noise. I got so frustrated that I spent like 2 hours one morning just checking and yanking on everything until I found the bumper issue. Pulled the grill towards me and Popped it back in and the noise disappeared when I went for a drive. Would have never figured that it was that simple.
My symptoms: No noise at high speed, Only made noise at low speeds and when I turned at low speeds and when I went over bumps.
Hope it helps.
I did all the YouTube videos on diagnosing problems like yanking the wheel at 6 and 12 and 3 and 9 to diagnose what type of an issue if it is an actual suspension issue and came up negative.
Silverz is offline   Reply With Quote
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 01:50 PM
Popping sound when going over bumps and sharp turns Silverz Issues | Warranty | Recalls / TSB 14 01-31-2019 08:13 PM
Humming noise on left turns. kphan Issues | Warranty | Recalls / TSB 10 10-27-2016 12:49 PM
Vibration on hard right turns ravisraval Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 10-22-2015 10:33 AM
Switching the Turns and the DRLs, possible, or just too dang hard? VesperLynn BRZ First-Gen (2012+) — General Topics 3 08-18-2013 10:38 AM
