Old 09-22-2012, 02:11 PM   #1
gxgn
Drives: Scion FR-S
heated mirrors?
Hi, does anyone know if you can add the heated mirror function of the BRZ to an FRS? Has anyone seen a tutorial for that?
thanks
G
gxgn is offline   Reply With Quote
Old 09-23-2012, 02:49 AM   #2
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
I'm starting to look into it (however I want to do just the mirrors, not the power folding pieces). They would end up connecting to the rear window defogger circuit.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-01-2012, 11:54 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Mine came with heated mirrors, is it a Canadian model only feature ?
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
Calum (10-07-2012)
Old 10-03-2012, 03:25 AM   #4
CMOS
Drives: 2012 FUJI Z
Heat comes on canadian and BRZ with heated seats, the heated part should be relatively easy, if you're not planing to sell them retail all you need is a tiny heating pad (or any DIY resistor combination that does not exceed a few watts) on the back of the mirror and an on/off switch. I bet replacement glass for the BRZ won't be that expensive either.
CMOS is offline   Reply With Quote
Old 10-07-2012, 02:17 PM   #5
Whiteoutjames
Drives: 2013 Scion FR-S--> 2015 WRX
I have a canadian FR-S and it definitely has Mirror de-frost/fogger
Whiteoutjames is offline   Reply With Quote
Old 10-07-2012, 03:40 PM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
Same here.
My last car was an Impreza 2.5i that 'didn't' come with heated mirrors. When I had the door cards off I plugged the mirror heaters in and they worked perfectly for the four years I had the car. It might be worth looking to see if the plugs are there.
The Following User Says Thank You to Calum For This Useful Post:
quasimoto (10-16-2012)
Old 10-07-2012, 06:24 PM   #7
roddy
roddy's Avatar
Drives: '13 Ultramarine
Where is the switch?
Old 10-07-2012, 06:48 PM   #8
CMOS
Drives: 2012 FUJI Z
No separate switch, my moneys on the rear window defroster, too warm to test.
Old 10-09-2012, 09:16 PM   #9
truenosan
truenosan's Avatar
Drives: 13 Firestorm FRS
You are correct. There is no separate switch. When you use the rear defroster, the mirrors defrost as well.
truenosan is offline   Reply With Quote
The Following User Says Thank You to truenosan For This Useful Post:
fritzburg (01-13-2015)
Old 10-09-2012, 09:53 PM   #10
chutrain
chutrain's Avatar
Drives: WRB BRZ
They are actually very fast for the mirrors. Hasn't been cold enough to test how well the seat warmers work in these cars.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 10-09-2012, 10:12 PM   #11
roddy
roddy's Avatar
You are correct. I got to test them out this morning. They work fast on fog, so they should be good for ice too...nice.
Old 10-11-2012, 10:38 PM   #12
gxgn
Drives: Scion FR-S
calum, chutrain roddy. - can you guys detail on what do I have to do to make it work? Do I need to take the inside door covers and tie some wires?
Thanks
George
Old 10-12-2012, 12:20 AM   #13
chutrain
chutrain's Avatar
Drives: WRB BRZ
I have the BRZ Limited. I am not sure if the premium model or US Spec FR-S come standard. If it doesn't you should be able to source the heated mirrors and the wiring should be in the door, gauging from how these cars are optioned.
In the garage:
1988 BMW E30 M3
Old 10-12-2012, 07:30 AM   #14
roddy
roddy's Avatar
Thanks
George
In my case they are already hooked up. They turn on with the rear defrost button.
must do this
heated seats debs0712 Cosmetic Modification (Interior/Exterior/Lighting) 47 04-08-2018 10:06 PM
anyone else love APR GT3 Mirrors ???? ESBjiujitsu Cosmetic Modification (Interior/Exterior/Lighting) 23 04-10-2016 01:13 PM
Adding heated mirrors to US spec FR-S @Art_Mighty Cosmetic Modification (Interior/Exterior/Lighting) 8 09-18-2012 03:35 PM
Fr-s Power Folding Mirrors? Koolkiid Cosmetic Modification (Interior/Exterior/Lighting) 19 09-15-2012 01:31 AM
Retrofit heated seats to Premium? blalor BRZ First-Gen (2012+) — General Topics 4 05-31-2012 08:50 AM
