Old 09-19-2016, 01:13 AM   #1
FIREISFUN135
FIREISFUN135's Avatar
Drives: 2013 BRZ DGM
Engine Misfiring and Stalling
So this problem came up after my battery died. The car starts and idles but after it warms up it just bogs and misfires when you give it gas then dies. No CEL or codes.
2013 BRZ 45K
-Avo turbo kit
-Delicous tuning flash & go reflash
-Nameless 3 inch downpipe
-Perrin 3 inch catback
-Avo catch can
-3 Bar MAP
Tried-
Cleaning the MAF
Checking the Cat to see if it was clogged
Any Ideas?
2013 DGM BRZ <-current
2006 WRB STi <-sold
2004 ES1 Civic <-sold
FIREISFUN135 is offline   Reply With Quote
Old 09-19-2016, 01:19 AM   #2
pantdino
Drives: Firestorm 2013 FR-S
2013 BRZ 45K
-Avo turbo kit
-Avo catch can
-3 Bar MAP
Tried-
Cleaning the MAF
Any Ideas?
I know nothing about flashes, but does it have to be reflashed after losing battery power for X amount of time?
Sounds like the mixture is way off, like the CEU is giving way too little fuel.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 09-19-2016, 02:39 AM   #3
steve99
Drives: FT86
2013 BRZ 45K
-Avo turbo kit
-Avo catch can
-3 Bar MAP
Tried-
Cleaning the MAF
Any Ideas?
flat battery wont effect tune in ecu its in flash memory.
did you relpace battery or just charge it, check battery volts
check any connections you touched
check maf plugged in correctly and gasket under maf is good
humfrz (09-20-2016)
Old 09-19-2016, 04:57 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Could be a vacuum leak. Check turbo hoses for leaks and clamps are tight.
Old 09-19-2016, 07:19 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
How is your total trim after it warms up and starts to run like crap? AFR?
guybo is offline   Reply With Quote
Old 09-19-2016, 08:42 AM   #6
FIREISFUN135
New battery, checked the alternator, and all other electronical connections. No obvious lose turbo or vacuum lines. It drove around fine but once it warm up same problem. It didn't want to restart and you could smell gas for alittle bit. Let it sit and fired right up. Trying to find my cable so I can log this
2006 WRB STi <-sold
Old 09-19-2016, 09:17 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Also does your fuel pressure look good? First task is is to figure out if it's missing because of a prob with fuel or fire, then work back. If you don't have a CEL, I'd suspect fuel pump since it's a hot soak issue.
The battery problem could be incidental. Why did you replace the battery? Did you have it tested?
Old 09-19-2016, 04:19 PM   #8
FIREISFUN135
It's getting fuel at least from the pump. Battery went bad and it was tested and replaced.
2006 WRB STi <-sold
Automatic Frs stalling Abe1120 Issues | Warranty | Recalls / TSB 44 09-11-2020 08:35 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Stalling, Misfiring, poor idle.. Car is at Toyota, hopefully some results soon WTF Issues | Warranty | Recalls / TSB 12 06-14-2014 11:40 PM
Not stalling? grgonium Scion FR-S / Toyota 86 GT86 General Forum 24 11-17-2012 11:26 AM
At 5,000kms and fuel injectors 2 & 4 are misfiring!!! UnLeasHer AUSTRALIA 55 11-12-2012 05:41 AM
