Old 07-19-2016, 08:58 PM   #1
nhamm1234
OFT 2/3 specs
I've searched Google, FT86 forums, even sent emails to Shiv; but I cannot find anything on the specs for the OFT headers.
Situation: I purchased the OFT3 headers with the slip-joint headers. The joint connecting the overpipe to the headers is leaking. Does anyone have the diameter of the joint before I go jacking my car up and measuring?
I'm likely going to get some RTV, JBWeld, or an exhaust clamp to fix the problem.
nhamm1234 is offline   Reply With Quote
Old 07-22-2016, 05:45 AM   #2
needle
Drives: MY15 BRZ WRblue
I just put the OFH 3 on as well and suspect I have the same problem. Will need to confirm once I get the car up and do a soapy water test. The leak is small and datalogging doesn't show a leak (at least to my limited knowledge) so I'm assuming the leak is after the first gaskets.
I did not put any sealing paste between the pipes during install, so that might be the reason for the leak. I'm hoping that applying some paste and tightening will fix the issue.
needle is offline   Reply With Quote
The Following User Says Thank You to needle For This Useful Post:
Teseo (07-22-2016)
Old 07-22-2016, 08:12 AM   #3
Teseo
Drives: frs
Try on a muffler shop, maybe can be a bolt/clamp loose for heat cycle. Man i wish you can make a sound clip, do you have catback?
Old 07-22-2016, 10:14 AM   #4
needle
All stock except the OFH3. I can make a sound clip sure, but I need to patch up that leak first. Right now it sounds like a go kart
Teseo (07-22-2016)
Old 07-23-2016, 04:47 AM   #5
needle
... Man i wish you can make a sound clip, do you have catback?
And here we go:
[ame="https://www.youtube.com/watch?v=W1z9Rf9qMPg"]Subaru BRZ MY15 E85 OpenFlash Header 3 (OFH3) + stock front & mid-pipe & muffler sound sample - YouTube[/ame]
Teseo (07-23-2016)
What are your specs? crash.1340 Off-Topic Lounge [WARNING: NO POLITICS] 19 01-20-2014 10:14 PM
Need help on specs TheSlickOne17 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-14-2013 08:12 PM
AC specs choi0706 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 04-22-2013 10:24 AM
Do i need the specs for an alingment? Pandle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-15-2013 12:34 PM
Cam specs?? brn12345 Engine, Exhaust, Transmission 6 11-12-2012 06:04 PM
