Old 09-11-2015, 02:41 AM   #1
Gank61
Drives: 2013 Scion FRS Special Edition
Short shifter clearance issue with driveshaft
I just ordered the DSS aluminum drive shaft for my car but I was wondering if anyone had an issues with it not clearing a kartboy short shifter. I saw a video of one person who had issues but it appeared his install was incorrect. Just trying to get an idea before I take my car apart and damage the shaft.
Gank61 is offline   Reply With Quote
Old 09-11-2015, 01:11 PM   #2
Hi ya, Gank61 ........
hmmm......sorry, I fail to understand the "connection" between the shifter and the driveshaft ......... ??
Maybe someone could clarify for me ...... and you ....
Old 09-11-2015, 01:37 PM   #3
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
http://www.ft86club.com/forums/showthread.php?t=62227
G-Man is offline   Reply With Quote
Old 09-11-2015, 01:53 PM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by G-Man View Post
Read the thread u posted & look @ last page.
Old 09-11-2015, 03:02 PM   #5
G-Man
G-Man's Avatar
what about it?
Old 09-11-2015, 03:04 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
^ for op 😂
The Following User Says Thank You to chaoskaze For This Useful Post:
G-Man (09-11-2015)
Old 09-11-2015, 03:06 PM   #7
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I never saw where he posted it fixed his issue. Interested as well, because the Aluminum driveshaft is larger than the carbon one. He ended up just grinding the shift rod down so it didn't hit anymore.
Old 09-11-2015, 03:07 PM   #8
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
noticed that no one mentioned this but in the videos i noticed your missing your reverse lock out plate , which is why your lock out in non functional and probably why it was hitting the drive shaft
There are no clearance issues
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 09-11-2015, 03:09 PM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
it's fixed, look @ last page of the thread, there was no problem.
Only problem was he took something off to reduce weight haha
Old 09-11-2015, 03:16 PM   #10
G-Man
G-Man's Avatar
I think he forgot to install the reverse lockout which is a tiny plate but apparently enough to cause problems because angles. I think he was joking about the weight loss reason.
The joints are(should be) the same size, just the body on the aluminum is bigger. I have only seen people hitting the joints. and never a real problem just install errors
The Following 2 Users Say Thank You to G-Man For This Useful Post:
chaoskaze (09-11-2015), DustinS (09-12-2015)
Old 09-11-2015, 04:15 PM   #11
Gank61
Alright cool. I appreciate the input guys I just got nervous because I asked 86 speedfactory after I ordered it and they said they weren't sure which got me all crazed.
Old 09-11-2015, 04:24 PM   #12
Gank61
I never did see that build thread say his lack of a reverse lockout fixed his issue tho. I was really hoping someone would just say yeah I run that setup and it works. I guess I'm a pioneer but most likely not.
Old 09-11-2015, 04:52 PM   #13
G-Man
G-Man's Avatar
he ground it down and fixed it himself before there was a chance to install it correctly and test. so I guess there is no real proof that it would have fixed it.
Old 09-11-2015, 05:46 PM   #14
humfrz, you ignorant old fool ...... allow me to draw you a picture .......
See, the linkage sets BEHIND the tail shaft of the transmission.
NOT on top of or beside it, like the last transmission you tore apart, back in the 50's....
Shifter rattles after CF driveshaft install? Venz1028 Engine, Exhaust, Transmission 5 03-28-2015 03:43 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
Clearance issue Wilson15 Engine, Exhaust, Transmission 0 10-17-2014 03:52 PM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 02:24 AM
Issue with Kartboy short shifter tisb0b Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 10-20-2013 07:15 AM
