BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
04-26-2023, 12:50 AM | #1 |
Drives: 2015 FRS for daily and track use
EL vs UEL Header Showdown
Plus an in-depth view of clearing your oil pickup.
Thought you will enjoy this episode. |
The Following 4 Users Say Thank You to Strat_FRS For This Useful Post: |
04-26-2023, 09:07 AM | #2 |
Drives: 22 BRZ limited
Very timely video as I just put CSG era ACE350 on my 2022. Now I don't feel so bad for saving them.
Thanks strat!
04-26-2023, 01:17 PM | #3 |
Drives: '23 BRZ Limited
Before I spend almost half an hour watching this, when you put the headers on did you give each one a specific dyno tune? Or did you just throw them on?
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
04-26-2023, 03:39 PM | #4 | |
Drives: 2023 brz limited 6mt red
So unless they dyno both of them specifically and have it tuned for the same car on the same dyno then the data to me would be relatively inconclusive other than if Ricky Bobby slapped this on his car and called it a day with a negligible difference other than a sound preference.
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
04-26-2023, 03:58 PM | #5 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | MrSkubi (04-27-2023) |
04-26-2023, 03:59 PM | #6 | |
04-26-2023, 04:49 PM | #7 |
Unless op tells us the details I would say it makes sense if you just plan on putting headers on with no tune. So in regards to “which style header makes more power without a tune” would be more accurate video description but doesn’t necessarily end the “vs” part without tuning them both.
04-26-2023, 05:07 PM | #8 | |
Drives: Crapcan
Edit: And I am not just putting this out there to criticize the OP, but when you put stuff like this out there it is fodder for discussion.
04-26-2023, 06:24 PM | #9 |
Haven't watched the vid, but just to add to the conversation...
Another way to do an untuned comparison is to reset the ECU before each set of pulls. Otherwise, all your Long-Term trims are going to be based on what WAS in the car. Resetting the ECU will give you results that are not biased or skewed and will be based on how the car naturally makes power. The argument can be made that 'they need a tune', and of course that's always a good idea to optimize power and efficiency, but none of these products are going to push any tables out of range, they just wouldn't be optimized, but at least the test would be more comparable. |
The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post: |
04-26-2023, 07:12 PM | #10 |
Drives: 22 BRZ
I see the lines on the graph, but what are the actual numbers?
04-26-2023, 08:55 PM | #11 |
I recommend watching the video. Each header we tested we optimized the calibration for.
The Following 5 Users Say Thank You to Strat_FRS For This Useful Post: | CaptainFenderbaum (04-27-2023), DocWalt (04-27-2023), OND (05-02-2023), Stonehorsw (04-27-2023), vindiesel (04-27-2023) |
04-27-2023, 12:00 AM | #12 |
Drives: '22 BRZ
Interesting. Very surprised to see the UEL coming out on top. I'm running the JDL EL on mine but have not taken it to a dyno. Scary amount of sealant on the pickup though! Mine was only about 40% clogged IIRC.
04-27-2023, 12:15 AM | #13 | |
This is an early car - not sure if that makes much difference in terms of the sealant. I was honestly surprised myself to not see more gains from the EL headers in the top end like we see with the 2.0 motor. There was no further power to extract there. There is just a touch more past the peak - but we are talking a couple hp - right in the same area we saw the gains with the intake. The OEM headers on the 2.4 are quite bit better than what the 2.0 had to start with as well. |
04-27-2023, 01:15 PM | #14 |
Drives: '22 BRZ
It seems like the engine is just plain out of flow up top, interestingly.
Similar Threads | ||||
Sound Deadener Showdown | SkyeHack | Electronics | Audio | NAV | Infotainment | 6 | 09-27-2018 10:14 PM |
Summer showdown jul 4-5 | Xtreme-86 | Southeast | 2 | 06-29-2015 01:16 AM |
BRZ vs. FR-S Restomod Showdown | switchlanez | BRZ First-Gen (2012+) -- General Topics | 28 | 05-17-2013 09:15 AM |
Sound Deadening Showdown | DatDudeLoso | Electronics | Audio | NAV | Infotainment | 15 | 03-02-2013 03:22 AM |
FT86 ancestors get it on! Touge Showdown | Rampage | Other Vehicles & General Automotive Discussions | 0 | 06-19-2012 01:51 PM |
