Tomei 60S Fitment Low?
Hey guys,
Had my Tomei Type 60S installed yesterday and noticed the muffler and bend sits rather low. My car is somewhat lowered.. Is this generally how these systems fits? Just want clarification from others..
#2 |
Slack Bum
Drives: FT86
Should be about there .. mine wasn't that low as my car wasn't lowered.
#3 |
Drives: Whiteout FRS
I think you can still move it more. My type-80 has maybe less than half an inch of clearance from the subframe? to the top of the pipe. It used to look like how yours is right now, sagging/low in the middle. Not sure if it will be the same as the type 80.
#4 |
Drives: 2013 Scion FRS
Damn. Better watch out for pot holes and road debris to keep that pretty metal clean!
#5 |
Drives: Turbo BRZ & Supercharged E90 M3
Whoa that's way too low. Looks like there's more room to go up near the subframe.
#6 |
Thanks guys for the feedback..
Seems most hang low but I'll try move it up a tad bit more.. Love the tomei system on my Evo which doesn't hang low at all. ![]() I find the lack of turbo in the BRZ/86 makes this tomei system louder than I thought, but still a nice note. Now I just need a supercharger to match the noise it makes.. |
#7 |
Drives: 1997 Eagle Talon TSi AWD
Love the Tomei! Great choice
![]() It does sit quite low but I think that's a bit TOO low, maybe check it over one more time |
#8 |
My Tomei 80R exhaust hung low where it crossed under the subframe, but with some tweeking and twisting where the pipes clamp together got it up there to around 1/2'' from the subframe.
It still hangs pretty low though. |
#9 |
Drives: 2013 Hot Lava FR-S 6 MT
Here's a pic of mine that I installed Wednesday. It's a little low in my opinion, I'm going to try to get it a little higher, but I was trying to get it higher when I installed it too ... lol
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
#10 |
Drives: 2014 Scion FR-S
I love everything about my Tomei 60S, but I am concerned about the clearance as there are a lot of speed bumps, potholes, and torn up roads that I can't avoid at times driving where I live.
Can anyone tell me if it is possible to get more clearance than what I have now, and if so, how does one go about doing that? I've heard some people mention "twisting" it, but I didn't really see how that was supposed to be done during the installation - can you adjust it higher if the spring-clips aren't on the exhaust? I had them on before lifting it up to the car, but I've seen some people mention that you're not supposed to clip the piping together until after it's bolted on. Here are a few images of the clearance I have now - my car is not lowered, everything about it sans the exhaust and a few cosmetic modifications is stock. ![]() ![]() For reference, I measured the clearance and ATM I have exactly 4" clearance for the lowest hanging part. Last edited by Ammunition; 03-06-2021 at 03:01 PM. |
#11 |
If I'm not mistake, stock muffler is approximately around that position as well...
#12 | |
I understand that this exhaust is going to hang a bit low, but I just want to ensure that I have as much clearance as is possible to get with it. |
#13 | |
| The Following User Says Thank You to CSG David For This Useful Post: | Ammunition (09-18-2014) |
#14 |
Drives: Skyline R33 GTR
Why did Tomei separate the silencer and the exhaust tip? Should have made it look like the 80R, would have made for more ground clearance and a better looking exhaust!
| Tomei 2-Way LSD now at RallySportDirect.com! | RallySport Direct | Transmission and Driveline | 51 | 03-25-2015 01:15 PM |
| Tomei Exhaust with Tomei Straight Pipe | leech | Engine, Exhaust, Transmission | 10 | 01-07-2014 10:42 AM |
| Tomei 60s installed!! | brn12345 | Engine, Exhaust, Transmission | 13 | 10-28-2013 04:29 PM |
| FS: Tomei UEL Header (WRX) | [deleted] | Miscellaneous | 0 | 03-19-2013 09:58 PM |
| Tomei 2-Way LSD | BPAuto | Engine, Exhaust, Transmission | 0 | 07-20-2012 02:15 PM |
