Old 07-17-2014, 10:43 AM   #1
SlyCayer
Drives: 2015 Subaru BRZ Aozora White Pearl
Gauge Pods
Hey,
New to the forum, I just bought a 2015 BRZ Aozora Edition and I looking at a turbo install from Full Blown, I want to install gauges, I cannot seem to find any gauge pods at a decent affordable price.
I am looking at installing a total of 8 gauges in total, so 3 in pillar, 3 in the passenger dash and 2 either column mounted or just above the middle vents?
I know that's a whole shit load of gauges, but I am planning on pushing the capacities of this car and want the most look on temps and etc.
I could remove 2 gauges(oil pressure and Pre-Post Intercooler Temp Sensors).
SlyCayer is offline   Reply With Quote
Old 07-17-2014, 10:47 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Have a good read.
http://www.ft86club.com/forums/showthread.php?t=20250
Old 07-17-2014, 10:57 AM   #3
SlyCayer
I saw that, but so many options and none are really "buy online" type...
Most are too expensive, one of them is $295.00 for one pillar pod for 1 or 2.
I might have to the Universal way and mod that.
Old 07-17-2014, 11:04 AM   #4
Sportsguy83
Drives: Limited BRZ
My bad, I did not read your OP says "reasonable price".....
Honestly there are none at reasonable price. Cheapest is universal and you make it to fit.
Old 07-17-2014, 11:38 AM   #5
SlyCayer
No problem, affordable would be $300 for all the pods I need, $300 for just one pod is a little out of budget...
I will probably make a custom gauge pod going all around the middle vents.
The Following User Says Thank You to SlyCayer For This Useful Post:
Sportsguy83 (07-17-2014)
Old 07-17-2014, 04:17 PM   #6
frsvr4
Drives: '13 FRS
You don't need 8 gauges, haha. Get the AC vent gauge (P3Cars) and be done with it or at least cut that number in half.
Which 6/7 gauges are more important than oil pressure?
Check this thread for another alternative to littering your interior with gauges and pods: http://www.ft86club.com/forums/showthread.php?t=23530
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 07-17-2014, 05:24 PM   #7
SlyCayer
I know, but I am looking for the utmost information when I will be pushing the vehicle.
I was looking for this, this morning and couldn't find anything, looks sharp.
Old 07-17-2014, 06:14 PM   #8
G-awesome
Drives: 2015 Firestorm Scion FRS
ft86speedfactory had some. Not sure if it's affordable according to your standards.
http://www.ft86speedfactory.com/inte...a827394db61542
G-awesome is offline   Reply With Quote
Old 07-17-2014, 09:03 PM   #9
extrashaky
Drives: 2014 BRZ Limited
Torque is a decent compromise and could possibly reduce the number of gauges you'll need. The ECU has most of the data you want already, but the car just doesn't have a way to display it. I'm running Torque on a Galaxy Note I had sitting around after I upgraded to another phone:
The one major piece of data Torque will not give you is oil pressure, because this car does not have a real oil pressure transducer. The stock oil pressure sender only gives an on/off signal to the idiot light in the dash at some ridiculously low pressure when it's already too late. If you want oil pressure, you'll have to install a sender and separate gauge. (I have a gauge out of a crashed Beechcraft airplane that will eventually go in mine in place of that 1980s digital clock, whenever I get the time to install it.)
Old 07-20-2014, 12:47 PM   #10
xwd
I have the Cravenspeed flex pod which looks okay but the right side one blocks stuff you may be interested in seeing like the coolant needle. It's 52mm and I use it for the AEM failsafe.
I have a Greddy Multi D/A gauge in my vent, it's 62mm and fits great. More of a DIY though. It also displays three different things at the same time on the gauge but has hookups for pretty much everything. They've discontinued the old model but you can still find them for sale, they said there is a new version coming out.
Old 07-20-2014, 02:15 PM   #11
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Take a look at what I did.
http://www.ft86club.com/forums/showt...ghlight=gauges
Lunatic is offline   Reply With Quote
Gauge Pods?!? Supermassive Cosmetic Modification (Interior/Exterior/Lighting) 483 03-25-2018 08:32 PM
FS: Auto meter 2-1/16" Gauge Pods jort88 Interior Parts (Incl. Lighting) 2 07-23-2014 12:06 PM
FS: Aero Body kit Rear Pods painted in white CSI:86 Australia Classifieds 1 01-25-2014 01:27 AM
WTB: Rear Bumper Pods rbrender Australia Classifieds 0 07-11-2013 08:50 PM
DCW Dash Gauge pods for FRS and BRZ doggy Interior Parts (Incl. Lighting) 21 05-09-2013 04:50 PM
