Old 05-03-2018, 09:47 AM   #1
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Bout to install a used header question
I just got a used Gruppe S coated UEL header. I have new OEM gaskets and torque wrench. Ratchets, extensions, etc. But will I need bolts to connect header to overpipe ? Reading it seems the stock header uses studs ? If I do need bolts it seems like Grade 8 10Mx 1.25 x 35 is what I need. Are those available at local hardware stores usually ? Thanks any other useful tips appreciated.
22R
22R is offline   Reply With Quote
Old 05-03-2018, 11:07 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
You'll probably have more luck at an auto parts store sourcing the bolts, though I have no idea what home supply store actually stock. They're usually softer.
The header I just removed has studs ('17)
Old 05-03-2018, 12:38 PM   #3
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
22R
any hardware store should have that stuff. you're on point with grade 8; you can go higher if you wanted to, but not necessary. As far as what bolt size/length; that doesn't matter as long as it's long enough and the nut screws on to the bolt properly and goes through the hole correctly. I personally would make sure to get stainless steel to avoid rust. I'd also grab lock washers so when you tighten them down they don't come loose.
pgranberg11 is offline   Reply With Quote
The Following User Says Thank You to pgranberg11 For This Useful Post:
22R (05-03-2018)
Gruppe S header install question 22R Engine, Exhaust, Transmission 9 04-28-2018 08:53 PM
Openflash header 2 install question. SubieRumble Engine, Exhaust, Transmission 5 12-25-2016 11:34 PM
Final Bout II- FRS/BRZ Photo Compilation Touge Factory FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 09-23-2015 09:04 PM
New Member (mates are sick of me talking bout the ft-86) FT-86GOD AUSTRALIA 26 10-23-2010 08:51 AM
