Old 03-13-2013, 05:24 PM   #1
Liquidsnake
Drives: "I drives like a Porsche"
Anyone notice this car eats coolant at a high rate?
I have filled the bottle twice in a 8,000 mile period, and its already halfway down after a month. Is this normal?
I remember refilling it once a year on other cars.
Liquidsnake is offline   Reply With Quote
Old 03-13-2013, 05:37 PM   #2
CBR600RR
Drives: Raven Black
Huh??
My coolant hasn't budged.
Needing to top up a cars coolant once a year isn't normal either.
Old 03-13-2013, 05:58 PM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Every car I have owned up to the FR-S has consumed coolant, but they all had issues. My A4 needed coolant and oil topped off every 3-4k miles.
My FR-S remains within spec though
supramkivtt2jz is offline   Reply With Quote
Old 03-13-2013, 06:02 PM   #4
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Are you filling the over flow tank? Are you checking the level of the fluid when the car is completely warmed up or completely cold?
If you want to check your coolant levels, wait until the car is completely cooled down, and then open the radiator cap. If you can see coolant at the top then you should be fine. Don't top off the over flow tank.
Ranatsu is offline   Reply With Quote
Old 03-13-2013, 06:16 PM   #5
Liquidsnake
Ok thanks. I did not do this. I checked it after driving it for a while.
Old 03-13-2013, 06:23 PM   #6
Ranatsu
Cone basher
Make sure the car is completely cool, because the radiator is under pressure when its warm.
Old 03-15-2013, 01:30 AM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Coolant is not a fluid that is consumed. If your coolant level is consistently going down, you have an issue.
Make sure you're filling it properly. The coolant bottle has cold and hot levels marked. Make sure the coolant is between those marks. Do not fill the bottle! The levels are where they are to leave room for expansion.
If the coolant is filled properly, and you find it is going down take your car to the dealership! You have a leak somewhere. Hopefully it's just a loose hose clamp. But it could be a faulty head gasket.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
AZP Installs (03-18-2013), Jesse (04-19-2013)
Old 03-18-2013, 07:59 PM   #8
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
100% agree. There is a cold and a hot mark on the overflow tank. It should be at either of those marks depending on if the motor is hot or cold. Don't overfill and it should not consume any coolant. If it does it is a sign of a much larger issue.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following 2 Users Say Thank You to AZP Installs For This Useful Post:
CSG Mike (04-16-2013), Jesse (04-19-2013)
Old 04-14-2013, 10:12 PM   #9
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
I went on a 1000+ road trip recently and noticed some liquid coming out of my car when I was filling up, closer inspection showed it to be water. I checked my coolant level since I got back and if 0 is low and 10 is full, it's sitting at a 2, cold, on level ground. I thought I'd just go buy some coolant and add it to the system, problems?
slizoth is offline   Reply With Quote
Old 04-14-2013, 10:23 PM   #10
AZP Installs
Was it water (as in clear water) or coolant (blue or green)?
-Mike Paisan
Old 04-14-2013, 10:28 PM   #11
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
I only check mine when cold, no movement after an initial top of at 5000 miles, I'm near 10000 soon
Huehuecoyotl is offline   Reply With Quote
Old 04-16-2013, 12:24 PM   #12
slizoth
slizoth's Avatar
Hard to say when its on the ground but I think it was clear like water, it certainly had the texture and "smell" or lack there of like water. When I got some on my hands (only a small amount) it appeared to be clear I didnt notice any sign of blue tint.
Old 04-16-2013, 12:27 PM   #13
atledreier
Drives: GT86 DGM
Then it's most likely A/C discharge and completely normal.
atledreier is offline   Reply With Quote
The Following 2 Users Say Thank You to atledreier For This Useful Post:
AZP Installs (04-16-2013), Jesse (04-19-2013)
Old 04-16-2013, 05:55 PM   #14
AZP Installs
+1
-Mike Paisan
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 06:13 PM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
Good Eats in AZ apoplexy Southwest 1 08-12-2012 04:28 PM
