Old 03-17-2018, 07:10 PM   #1
GrantedTaken
Which style phone mount is best ?
Vent mount or windshield suction mount?
Magnetic or spring clips?
Threads are old. Options change.
Anyone got something they like?
GrantedTaken is offline   Reply With Quote
The Following User Says Thank You to GrantedTaken For This Useful Post:
JoeC (03-17-2018)
Old 03-17-2018, 07:24 PM   #2
Audio
Drives: 16 FR-S Raven
I use one that mounts inside the CD player entrance, it's okay but blocks the radio a little bit. But my goal was to keep the windshield clear as possible
Sent from my Pixel XL using Tapatalk
Audio is offline   Reply With Quote
Old 03-17-2018, 07:30 PM   #3
GrantedTaken
I've decided I want to avoid the spring clamp kind.
I want a magnet one.
Old 03-17-2018, 07:41 PM   #4
FryinBerries
FryinBerries's Avatar
I have this one mounted to the right of my head unit. I love it. Can see it easily & can plug it in with a 6” charging cable.
FryinBerries is offline   Reply With Quote
Old 03-17-2018, 07:41 PM   #5
extrashaky
Drives: 2014 BRZ Limited
This is the best one I've found:
The Following User Says Thank You to extrashaky For This Useful Post:
Audio (03-17-2018)
Old 03-17-2018, 08:33 PM   #6
How about "mounting" it inside the glove box ??
humfrz is online now   Reply With Quote
bkharmony (03-19-2018), Impureclient (03-17-2018)
Old 03-18-2018, 08:47 AM   #7
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
3D printed from forum member and installs without tools and is removable. Just add your mag mount of choice.
22R is offline   Reply With Quote
The Following 3 Users Say Thank You to 22R For This Useful Post:
chas3wba0 (03-22-2018), Sisko's_Baseball (12-29-2019), Spectral Entity (11-07-2018)
Old 03-18-2018, 10:05 AM   #8
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Not new or anything, but I have a generic suction mount on the little side window next to the mirror. I'm away from my car, so I can't take any pictures right now.
Pros:
-Easy to glance at if using for navigation
-Not in the way of anything important
Cons:
-Needs a long charger cable and clever routing due to opening the door.
-Out of reach of passenger if you need them to do something (my fiance is usually the navigator)
Old 03-18-2018, 11:23 AM   #9
extrashaky
Not new or anything, but I have a generic suction mount on the little side window next to the mirror...
Cons:
I have a Galaxy Note mounted there to run Torque as an engine monitor. Here's what I did with the cable:
There's a little square gap at the top of that panel just big enough to let a cable pass through. It's as if it were designed to allow this.
I have the cable run to a USB power port mounted to the steering support member under the dash (not shown). I have the USB port powered off the heated seat circuit in the fuse panel under the dash right there using an add-a-circuit.
It makes it a lot cleaner than having to plug it in somewhere. Eventually I'm going to run that cable through the boot in the door hinge and out the little gap next to the small window, so that it doesn't need any slack to open and close the door.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
humfrz (03-18-2018), Spuds (03-18-2018)
Old 03-18-2018, 02:44 PM   #10
Spuds
The Dictater
Spuds's Avatar
So much better than my solution. Mine was just to string it along using cable clips in the interior panel gaps.
Old 03-19-2018, 11:01 AM   #11
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
That's the exact one I have. It's good,but the claps are slow moving in the winter when it's cold.
Th3rdSun is offline   Reply With Quote
Old 03-19-2018, 11:13 AM   #12
extrashaky
Because then I can't see my GPS directions or my radar.
Old 03-19-2018, 11:13 AM   #13
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I've been using this mount for a few months and love it, only thing is you will need a case for the phone that covers the back so you can place the magnet inside (unless you don't mind a magnet sticker on your phone).
http://www.hdaccessory.com/products/...IaAj4-EALw_wcB
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-19-2018, 12:27 PM   #14
Dake
Dake's Avatar
I bought this one.
Holds well, and doesn't block the entire vent.
Dake is offline   Reply With Quote
The Following User Says Thank You to Dake For This Useful Post:
MJones_RB (11-05-2018)
Custom phone mount so26 DIY (Do-It-Yourself) Guides 20 11-07-2016 05:15 PM
Stealth Phone Mount (Magnet) KevinB85 BRZ First-Gen (2012+) — General Topics 23 07-21-2015 12:47 AM
Best phone mount? JS + BRZ Electronics | Audio | NAV | Infotainment 9 03-24-2015 10:02 AM
ProClip custom phone mount seanyboy Interior Parts (Incl. Lighting) 1 03-27-2014 12:46 PM
DIY phone mount GaDgeT Electronics | Audio | NAV | Infotainment 2 07-05-2013 11:18 PM
