Old 08-09-2022, 08:12 PM   #1
Romeodjan
Drives: 2013 Scion10 FRS
FRS 2013 doesn`t start after swap
Hi, guys here the deal:
I have bought Scion FRS 2013 with blown engine, replaced the engine for a rebild one, and its cranking but not start, there is no spark and injectors are not opening. Fuel goes into the ramp.
Replaced crankshaft position sensor, but nothing have changed..
DTC shows codes: p1640 U0100
Would be glad for any thoughts and advice
Romeodjan is offline   Reply With Quote
Old 08-09-2022, 09:17 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
If you haven't already, recheck all of electronic connections.
Old 08-09-2022, 09:23 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
what model year engine did you install?
is the DI module bolted/down and grounded?
Old 08-09-2022, 11:25 PM   #4
Romeodjan
Not sure what model year...
Yes bolted...
Old 08-10-2022, 12:03 AM   #5
Romeodjan
Old 08-10-2022, 02:59 AM   #6
whataboutbob
AutoX-10/10ths every run
Simple web search, may not be accurate seems to point to faults with the Engine Control Module. I'd verify that your engine harness is connected correctly. Might need a new engine harness?
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
FRSapex (08-11-2022)
Old 08-10-2022, 03:38 AM   #7
soundman98
soundman98's Avatar
Yes bolted...
that would be the first thing to figure out. the cam indicators changed in 15 along with some other updates, so a 15+ motor in a 13-14 requires additional work
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
alphasaur (08-10-2022), DarkPira7e (08-10-2022), Tcoat (08-10-2022)
Old 08-10-2022, 08:33 AM   #8
Romeodjan
Contacted with the seller -engine 2014
Old 08-10-2022, 12:26 PM   #9
OK don't take this as me thinking poorly of you but the question needs to be asked.
Have you checked all fuses and relays?
DarkPira7e (08-10-2022), soundman98 (08-11-2022)
Old 08-10-2022, 12:58 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The engine has a turbo on it, what is the MAP size? What parts have been swapped from your old build to this one? Honestly you'd be better off getting it running on a stock map with stock intake/ exhaust manifold if you're having issues
alphasaur (08-11-2022)
Old 08-10-2022, 09:45 PM   #11
Romeodjan
Yes i did, few times- all are good..
I agree that the main issue when you need to figure out what was done with the car before. The story from previos owner is: He bought HKS GT3-RS turbokit, and a lot of parts and software (ill put the list below), took the car to the shop to install everything, and they returned him car with blown engine . What happend we may only guess))
Parts
• [1 Mishimoto oil cooler (off the car)
• [1 Injen Air Intake (off the car)
• [] Borla UEL headers (off the car)
[1 Omni map 3 sensor
[1 Delicious tuning
- [] Ecutek tuning software (off the car)
•[] AEM air / fuel gauge
- [1 SB DXD Stage 3 daily clutch
[1 HKS GT3-RS Turbo kit
[] Hks s type oil cooler
[1 Tein flex Z coilovers
[1 Borla exhaust
•[1 Brand new flywheel and clutch
Clutch, flywheel and turbo brand new
The Following User Says Thank You to Romeodjan For This Useful Post:
Tcoat (08-10-2022)
Old 08-10-2022, 09:49 PM   #12
THIS^
At this point there are so many unknowns that all the guess on the internet may never catch it.
DarkPira7e (08-11-2022), soundman98 (08-11-2022)
Old 08-11-2022, 10:03 AM   #13
blsfrs
blsfrs's Avatar
Old school diagnosis trick: Spray some starter fluid into the intake. If it tries to start then you know it's a fuel problem. If nothing happens, you are no worse off.
The Following User Says Thank You to blsfrs For This Useful Post:
FRSapex (08-13-2022)
Old 08-11-2022, 10:11 AM   #14
Romeodjan
Threre is no spark, so I`m not sure it will start and don`t want to start it this way.
probably today will take out the engine and look if shafts are stand in propper way...
blsfrs (08-11-2022)
Car won't start - doesn't try to crank at all, but lights are working HELP cdo221 Issues | Warranty | Recalls / TSB 28 06-06-2018 07:30 PM
Push start doesn't ignite? Had to try many times hanabie Issues | Warranty | Recalls / TSB 4 07-09-2017 10:20 PM
Car doesn't start without fully charged battery. frsq5 Issues | Warranty | Recalls / TSB 6 06-09-2017 10:59 PM
Car doesn't start, multiple "clicking" when trying to start tracerit Issues | Warranty | Recalls / TSB 22 01-27-2017 03:56 PM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 03:09 PM
