Drives: '23 BRZ
Fuel starvation, verus flap?
I got fuel starvation at 7/8 tank at New Hampshire Motor Speedway (chicane/chicane) couple of weekends ago, coming out of T6/T7 (6 is a heavily banked 180 degree left-hander that blends into 7, also left). Is the Verus flappy door the preferred cheap-and-easy fix? Palmer coming up June 19/20, it's the only place I've had fuel starvation before, and that was at just under 1/2-tank. With apparently grippier tires this year (Nankang CR-1) I'd like to be able to run at 1/2-tank, or at least 3/4 without running into this issue after extended turn 1-2 left-hander...
#2 |
Drives: Crapcan
It helps a lot, especially on an NA car. I used to get fuel starve on this long decreasing radius left, now I don't at even low fuel levels.
#3 |
Drives: FRS Hot Lava
worked for me like a charm. NA engine, starving on long left quick turn @msRH.
check filling full full the tank if you properly reseal the tank. |
#4 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
As another data point, I just received my Verus Fuel Door. I too had fuel starvation issues while less than 3/4 tank on 245/40/17 A052's. I'm honestly surprised more people don't have issues, but I guess it's a function of G-force which may only be achievable on certain tracks/setups. Will update here with my results.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
| The Following User Says Thank You to Goingnowherefast For This Useful Post: | ZDan (05-18-2021) |
#5 |
Drives: 2014 Subaru BRZ
It helps but won't fix your issues. At one of my local tracks without the flap I'd get fuel cut at 1/2 a tank or less on 200tw tires, with the flap I can go down to about 1/3rd of a tank before fuel starve. For me, that's worth it since it means I can do 2x20min sessions before refueling instead of needing to top off after every session.
| The Following User Says Thank You to 14stu For This Useful Post: | ZDan (05-18-2021) |
#6 | |
Drives: '23 BRZ
#7 |
Drives: '23 BRZ
Flap ordered, thanks fellas!
#8 |
Maybe replace oem pump with a stronger aftermarket pump. How old is the oem pump. Your in there might as well just in case you decided to goto more power or boost
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | ZDan (05-19-2021) |
#9 |
Drives: '23 BRZ
it's a 2017, not too worried about the fuel pump. I'd be more likely to get a new 2.4 and go from there rather than boost the 2.0, I think... Any case I'll put other possible upgrades until I needs em.
#10 |
Drives: Crapcan
The issue is the fuel runs out of the fuel basket on left turns where the fuel pump is housed. The only real 100% fix is to go to a swirl pot.
| SAVAGE! Autoworks fuel starvation flap $55 | Ashikabi | Engine, Exhaust, Bolt-Ons | 0 | 10-24-2020 10:10 AM |
| Fuel Starvation? | Lunatic | Tracking / Autocross / HPDE / Drifting | 37 | 03-29-2018 12:47 AM |
| How to fix fuel starvation on left hand turns - Verus Fuel Door | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 3 | 08-21-2017 04:22 PM |
| Fuel Starvation issues? YAY OR NAY? | track_warrior | Tracking / Autocross / HPDE / Drifting | 23 | 10-22-2013 12:19 PM |
| Fuel Starvation | feldy | Tracking / Autocross / HPDE / Drifting | 1 | 06-09-2012 11:14 AM |
