| Software Tuning Discuss all software tuning topics. |
Drives: 2016 BRZ Limited
ROM corrupt when opening in RR
I'm running an SBD500x kit, OFT sent me a base tune to use but they are taking months to respond so I'm attempting to edit my tune but I get an error when opening the tune file in RR and all the numbers are scrambled. My cal id is ZA1JF40D, I am using the F40D OFT definition also. Obviously im a noob and missing something here but any help would be appreciated!
It won't let me attach the file but the filename is: OTS OFT350 Full exhaust B01D_F40D Is it somehow hacked to appear as F40D? |
#2 | |
Drives: FT86
Correct its likely your rom has calibration id hacks to allow oft to load a rom thtats not your native calid. It woyld appear your rom is likely a B01D but calod hacked to look like an F40D. So you would need a B01D definition to open it. However you would need to "hack" the B01D def to look like an F40D to fool romraider |
#3 | |
![]() attached the zipped tune file. SBD TURBO TUNE.zip |
#4 | |
Drives: FT86
Ok got a definition working. Yes its an old A00D rom. Those rom had a fult from factory with transient ignition retard not active id suggest you fix that as it can cause di injector issues if you do a lot of high rpm shifting. Ive messaged you |
| Tags |
| turbo oft |
| Corrupt SD - blackvue dr650gw-2ch | SmartedPanda | Electronics | Audio | NAV | Infotainment | 7 | 06-18-2016 10:57 PM |
| Need Help Opening Taillights in PDX | XanRules | Northwest | 7 | 10-07-2015 05:07 PM |
| Ecutek Corrupt ECU, Bad Flash, Can i reset? | gdrider77 | Software Tuning | 48 | 07-04-2014 12:25 AM |
| Trunk not opening | grgonium | Issues | Warranty | Recalls / TSB | 4 | 02-06-2013 03:47 PM |
