follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 17
1
2
3
4
5
11
Last
Showing results 1 to 30 of 500
Search took
0.58
seconds.
Search:
Posts Made By:
CxG
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
07-10-2019, 01:55 AM
632
Sticky:
FR-S / BRZ Wheel Directory, Gallery and Fitment Guide Chart
1,584,953
Posted By
ayoshioka1
ADVAN RACING TC3 18x9.5 +45 square setup...
ADVAN RACING TC3 18x9.5 +45 square setup 255/35/18 firehawks
https://i.imgur.com/Z2stv4m.jpg
https://i.imgur.com/Ou6Q4FF.jpg
https://i.imgur.com/AY0dkVb.jpg
https://i.imgur.com/rCg0myL.jpg
Forum:
Forced Induction
05-08-2019, 11:03 AM
1,372
Harrop TVS86 Owners Thread
393,311
Posted By
johan
I think as far as "where it hits its stride" is...
I think as far as "where it hits its stride" is defined by the compressor maps, I don't have that info. But yes, the point is, if the blower isn't working as hard, it will generate less heat via...
Forum:
Forced Induction
05-07-2019, 12:15 PM
1,372
393,311
Posted By
johan
Justin, I'm just going to wade into this gently,...
Justin, I'm just going to wade into this gently, but I believe what he was getting at is that the 1320 requires more horsepower to spin. So, within the relative boost range that the 900 and 1320 can...
Forum:
Electronics | Audio | NAV | Infotainment
05-02-2019, 11:29 AM
57
Replacing 2013-2016 BRZ Wheel For 2017?
36,000
Posted By
demariners
Well re-pinning the clock spring is completely up...
Well re-pinning the clock spring is completely up to the installation. You can re pin it however you wish. The 2015 clock spring is only using 2 pins for the cruise control but the plug supports 12...
Forum:
Forced Induction
04-27-2019, 05:25 AM
27
(Boosted) Blown Motor Advice - AFTER RECALL
10,200
Posted By
Xero-Limit
Sorry to hear about your motor, sad how this...
Sorry to hear about your motor, sad how this recall has played out. You might want to check out our build here: http://www.ft86club.com/forums/showthread.php?t=133475 on the latest car. Basically...
Forum:
Forced Induction
03-06-2019, 09:18 AM
71
2013 Valve Spring recall - modified (FI) engine thread
21,605
Posted By
xjohnx
If your dealer is refusing to perform the recall...
If your dealer is refusing to perform the recall without you paying to have mods removed, I implore you to open an NHTSA investigation at the following link:
Forum:
Forced Induction
03-05-2019, 11:58 AM
71
21,605
Posted By
xjohnx
I have obtained a copy of an email from a Subaru...
I have obtained a copy of an email from a Subaru district manager confirming they they are working against the spirit of the agreement Subaru entered into with the NHTSA. How could these items be a...
Forum:
Forced Induction
03-05-2019, 08:07 AM
71
21,605
Posted By
Sounds like you need to find a new dealer, not...
Sounds like you need to find a new dealer, not only for service, but for future purchases.
Forum:
Forced Induction
03-04-2019, 02:27 PM
71
21,605
Posted By
I think you may be right about the aftermarket...
I think you may be right about the aftermarket parts though. If you read through the Subaru instructions (https://static.nhtsa.gov/odi/rcl/2018/RCRIT-18V772-6522.pdf) (did not review Toyota) on page...
Forum:
Forced Induction
03-02-2019, 11:08 PM
71
21,605
Posted By
mswbrz
My car falls under the recall 13 Brz and I was...
My car falls under the recall 13 Brz and I was able to register with no issues and HAVE NOT DONE RECALL .
Forum:
Engine, Exhaust, Transmission
02-13-2019, 07:11 PM
439
Jackson Racing Dual Radiator/Oil Cooler
185,710
Posted By
staycrushing
the stock radiator and dedicated jackson cooler...
the stock radiator and dedicated jackson cooler would be a better option for you if you prefer separate units.
i personally run the dual oil cooler/radiator combo and have had zero issues with...
Forum:
02-13-2019, 08:56 AM
439
185,710
Posted By
Fred E
I don't think it's entirely reasonable to compare...
I don't think it's entirely reasonable to compare this unit to two dedicated separate units. Separate dedicated (high end) units could be more "effective" than this combo unit, but that also depends...
Forum:
Forced Induction
01-26-2019, 04:56 PM
71
21,605
Posted By
Norotor
I'm going to have this problem; I've had my...
I'm going to have this problem; I've had my forged engine with upgraded heads/valvetrain sitting around for a while and finally decided to drop it back into my frs, and of course the recall was...
Forum:
Forced Induction
01-24-2019, 03:53 PM
71
21,605
Posted By
kmbkk
Update... Priority Toyota agreed to do my...
Update...
Priority Toyota agreed to do my recall and I don’t have to remove the turbo kit. They’re also replacing the spark plugs and not charging any labor. I asked about using aftermarket valve...
Forum:
01-23-2019, 03:53 PM
439
185,710
Posted By
Butterballz
For me kinking was not a problem, you just have...
For me kinking was not a problem, you just have to twist where the fitting meets the hose. However, I did get rubbing. I twisted the lines to avoid touching anything but when pressurize, it tries to...
Forum:
Forced Induction
01-15-2019, 10:07 AM
71
21,605
Posted By
Yep that is why I said check with your dealer....
Yep that is why I said check with your dealer. There has to be some that would like the extra income to do the work.
I hear ya on the Ca thing. That does sort of put your back up against the wall....
Forum:
Forced Induction
12-24-2018, 05:24 PM
1,372
393,311
Posted By
sw20kosh
I run a 16psi pulley and control boost via...
I run a 16psi pulley and control boost via throttle mapping. I target a nice flat 12 psi across the rev range.
Forum:
Forced Induction
12-20-2018, 03:56 PM
1,372
393,311
Posted By
johan
I don't want to go too far down the rabbit hole...
I don't want to go too far down the rabbit hole on this, as you guys should do your own testing and find the limits on this platform / blower. All of my testing was done on a Honda K20.
But I'll...
Forum:
Forced Induction
12-17-2018, 11:05 PM
1,372
393,311
Posted By
firekat
I'm running the JR Radiator with the Harrop. ...
I'm running the JR Radiator with the Harrop. Both coolant and oil run a little over 190F most of the time. This is notably lower than stock readings. The only time I have seen these values creep...
Forum:
Forced Induction
12-17-2018, 02:06 PM
1,372
393,311
Posted By
Trefoil
Just took a look at the Harrop oil cooler for our...
Just took a look at the Harrop oil cooler for our car: https://www.harrop.com.au/shop/engine-oil-cooler-toyota-86subaru-brz?search=oil%20cooler
Ouch! About the same price and no mention of...
Forum:
Forced Induction
12-14-2018, 08:34 PM
1,372
393,311
Posted By
Trefoil
I went to a Jackson Racing dual radiator cooler...
I went to a Jackson Racing dual radiator cooler and experience extremely solid values from IAT sensor, OTS, and CTS. It has been a functional upgrade for driving in both cold and heat in a high...
Forum:
Forced Induction
11-14-2018, 01:53 AM
1,372
393,311
Posted By
byun
Have to say this kit with the 85mm pulley and E85...
Have to say this kit with the 85mm pulley and E85 is amazing. Hitting 13psi and car feels a lot faster than the 90mm pulley I was running before
Forum:
Engine Swaps
09-20-2018, 10:01 AM
139
3S-GE BEAMS swap
110,695
Posted By
VR4EVER
The guy who owns Puristmod is the same guy who...
The guy who owns Puristmod is the same guy who posted earlier in this thread... Dustin@Dynosty.
I actually bought Dustin's car (which had the BEAMS swap done on it) for my LS swap. Super nice guy....
Forum:
Engine Swaps
09-18-2018, 09:13 PM
139
3S-GE BEAMS swap
110,695
Posted By
Kenny_LongWrench
This may be of help. ...
https://www.puristmod.com/collections/86swap-com/electronics
Forum:
Engine Swaps
09-14-2018, 01:59 AM
62
1UZFE vvti into GT86 - vids, pics, comments
47,661
Posted By
Manji
Car has been almost fully rebuilt over past 12...
Car has been almost fully rebuilt over past 12 months.
Decided to dry sump motor. Meant it could be mounted better, lower and further back.
Twin plate clutch, new cooling system, ducting and vents,...
Forum:
Forced Induction
09-05-2018, 06:22 PM
1,372
393,311
Posted By
sw20kosh
My car dry (no gas, passengers, cargo, trunk...
My car dry (no gas, passengers, cargo, trunk stuff) is 2750 lbs.
Mods:
Half roll cage
Harrop SC kit
2 oil coolers
Brembo Club Racer 350mm big brake kit
Brembo GT rear big brake kit
17x9.5...
Forum:
Forced Induction
09-04-2018, 08:37 PM
1,372
393,311
Posted By
Yoshoobaroo
That's why I'm asking, people with coilovers don't really have this issue, but with lowering springs you may need a 1/4" spacer on the top hat to level it back out. Spacers like this:...
Forum:
09-02-2018, 04:54 PM
439
185,710
Posted By
falcon_wizard
So I promised I would provide some feedback once...
So I promised I would provide some feedback once the Jackson Dual Cooler was installed.
Initial comparison logs seems very promising. While Oil temp could easily reach 280 degF when driving at...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
08-21-2018, 02:52 PM
146
2017 BRZ Performance Package Brembo Brakes Part Numbers
109,779
Posted By
JRitt
Please also note...brake disc thermal mass plays...
Please also note...brake disc thermal mass plays into longevity. That's why we have multiple kits to cater to differing needs. My hunch is that the Brembo disc weighs about 20-21 lbs. Our 299x32mm...
Forum:
08-14-2018, 02:16 PM
439
185,710
Posted By
FymTom
I purchased the dual setup through CSG recently....
I purchased the dual setup through CSG recently. I did a data log of my daily commute before and after the install. I figured the data may interest some, since I was looking for more.
Car has JDL...
Page 1 of 17
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
07:42 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
