follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 27 of 42
Search took
0.31
seconds.
Search:
Posts Made By:
vfrqqq
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
12-26-2023, 04:15 PM
9
Do FA20s normally get this dirty after ~80k miles?
4,172
Posted By
whataboutbob
I think a catch can would help with this. Even NA...
I think a catch can would help with this. Even NA I got a decent amount of blow-by and I suspect what you are seeing is a result of blow-by.
Forum:
Engine, Exhaust, Transmission
10-28-2023, 05:34 PM
20
Looking for Community Input on Blown FA20: To replace or not to replace
3,316
Posted By
e1_griego
Last motor swap I did (which was a few years ago)...
Last motor swap I did (which was a few years ago) took about 5 hours from driving one into the garage with rod knock to firing the new (used, ebay) motor up.
These things are stupid simple.
Forum:
10-11-2023, 09:51 PM
20
3,316
Posted By
NoHaveMSG
It's not just the cam sensors. The reluctor wheel...
It's not just the cam sensors. The reluctor wheel for cam positioning is different as is the crank position sensor and reluctor wheel. Inny vs. Outy. Pre-facelift ECU can't read the signal on the...
Forum:
10-10-2023, 08:39 AM
20
3,316
Posted By
blsfrs
I did something similar to get my FRS. Before...
I did something similar to get my FRS. Before car prices went crazy, I made friends with the manager of a small car lot near my house. I would stop in weekly and we would look at various auction...
Forum:
07-31-2023, 01:12 PM
1
Anyone know difference between Subaru OEM coolant in black and in white container?
1,036
Posted By
Figo
Iv figured it out. They are the same. Subaru...
Iv figured it out. They are the same. Subaru updated the part number from soa868v9270 to soa868v9272 and changed containers. so the Black container is the new version of the coolant!
If you are...
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
09-23-2022, 09:30 AM
24,612
WHAT DID YOU DO TO YOUR FRS TODAY?
7,307,377
Posted By
blsfrs
Purchased Billetworz 500g shift knob from vfrqqq....
Purchased Billetworz 500g shift knob from vfrqqq. My butt dyno says it added 2.57 hp. Feels really nice too.
Forum:
Engine, Exhaust, Bolt-Ons
08-23-2022, 10:23 PM
31
SOLD
7,476
Posted By
dreamwonder
Carb tune works for 2015. The tune itself is non...
Carb tune works for 2015. The tune itself is non transferable.
Forum:
User/Vendor/Sponsor Reviews, Feedback, Comments
08-15-2022, 11:47 AM
17
Watch for Scammers Everyone
2,832
Posted By
DarkPira7e
That's why I don't comment on things I intend to...
That's why I don't comment on things I intend to buy typically. Easier to PM them
Forum:
08-13-2022, 11:17 AM
17
2,832
Posted By
Windycity
Hey fellow car guys, this forum is one of the best and most thorough resources for the 86 platform. I have purchased many things from this forum over the years and have had no issues. I recently...
Forum:
07-11-2022, 05:52 PM
31
To Rebuild or not, but with no Experience with Engine Rebuilds
4,663
Posted By
jrhudson
i went this route and its really not as simple as...
i went this route and its really not as simple as you making it out to be. I was on the same boat as you. novice "mechanic"(meaning not real mechanic, does it for a hobby on my car), mechanically...
Forum:
07-11-2022, 05:36 PM
31
4,663
Posted By
NoHaveMSG
If you haven't done any kind of engine assembly...
If you haven't done any kind of engine assembly before I don't recommend it. A boxer is just like any other engine but almost double the parts. If you don't have experience with FIPG it can be easily...
Forum:
31
4,663
Posted By
For sure! Long block is doable. There are some...
For sure! Long block is doable. There are some differences in the layout of electrical parts, so make sure the replacement is compatible. I don't remember the cutoff years offhand, just that it's...
Forum:
07-11-2022, 04:04 PM
31
4,663
Posted By
DarkPira7e
I second the notion that you doing a rebuild...
I second the notion that you doing a rebuild isn't a great idea. There are things so impossibly small that will make or break your build, this engine isn't forgiving in the slightest.
Just get...
Forum:
07-11-2022, 03:20 PM
31
4,663
Posted By
Peace of mind went out the window as soon as the...
Peace of mind went out the window as soon as the supercharger was added. An overly aggressive, or poor tune was most likely the culprit.
If you are already hedging with "don't have the time to...
Forum:
Electronics | Audio | NAV | Infotainment
11-25-2021, 01:17 PM
4
Drivers side seat heater switch light doesn’t illuminate but heater works
1,209
Posted By
LimitedSlip
This should help: ...
This should help:
https://www.ft86club.com/forums/showthread.php?t=142734
:thumbsup:
Forum:
08-20-2021, 05:23 PM
8
Shifter Malfunction After Clutch Install
1,860
Posted By
wolffbite
OP hasn't replied yet but if the reverse lockout...
OP hasn't replied yet but if the reverse lockout gate is indeed your issue, here is the official procedure for setting the clearance.
Forum:
DIY (Do-It-Yourself) Guides
07-23-2021, 07:14 AM
217
DIY Clutch Replacement
221,984
Posted By
ermax
Like I said it’s Russian roulette. It isn’t that...
Like I said it’s Russian roulette. It isn’t that you had to turn it far, it’s just that you didn’t get lucky until you turned it far. I typically just turn it a few degrees and cross my fingers. If...
Forum:
07-14-2021, 06:22 AM
217
221,984
Posted By
Feezz
Its very useful, You put best efforts!
Forum:
07-08-2021, 12:58 PM
217
221,984
Posted By
blsfrs
I'm not an expert but I have worked on cars for a...
I'm not an expert but I have worked on cars for a long time. When a flywheel is resurfaced, an equal amount of material is removed from its entire face. Its "balance" won't change. That leaves the...
Forum:
07-08-2021, 08:49 AM
217
221,984
Posted By
blsfrs
Did you reach out to SBC? If the dealer won't...
Did you reach out to SBC? If the dealer won't help try the manufacturer.
Forum:
07-03-2021, 11:38 AM
217
221,984
Posted By
ermax
I’ve never heard of someone surfacing a FW...
I’ve never heard of someone surfacing a FW without also making sure it’s balanced but if I had to guess, this is where your problem is if it’s not the driveshaft. Did you mark the drive shaft before...
Forum:
07-02-2021, 03:04 PM
217
221,984
Posted By
pope
Ideally, removing an even layer of material would...
Ideally, removing an even layer of material would not change the balance. But was the layer removed an even layer? .030” from the highest point might have only been .025” from another point. The...
Forum:
06-14-2021, 07:28 PM
55
Difficult 1st gear and almost grinds 2nd, oil problem?
7,305
Posted By
itschris
I noticed this a couple years ago in my reservoir...
I noticed this a couple years ago in my reservoir too. I tried wiping it out with a paper towel when bleeding my clutch, it was kinda greenish blackish. Didn't get it all, but hasn't seemed to cause...
Forum:
06-11-2021, 09:33 PM
6
Are South Bend Clutch and Exedy the same company?
1,727
Posted By
Olson1288
Found this quote on a Subaru forum. It's from...
Found this quote on a Subaru forum. It's from like 10 years ago but I imagine the same process still applies:
"Hi guys, I work for South Bend Clutch. I just wanted to clarify your concerns.
Forum:
06-11-2021, 06:59 PM
6
1,727
Posted By
CSG Mike
They're made by Exedy, as are many clutches on...
They're made by Exedy, as are many clutches on the market, including the stock clutch.
Forum:
06-04-2021, 11:22 PM
55
7,305
Posted By
Capt Spaulding
If the friction point is that low it could very...
If the friction point is that low it could very possibly be a source of your problem. Since swapping the fluid and bleeding the system didn't resolve your issue, you might try adjusting the pedal...
Forum:
Forced Induction
03-27-2021, 05:18 PM
23
Sticky:
To Everybody installing Forced Induction
55,853
Posted By
ShadowReaper
I got some pictures to add to this thread 1st...
1st picture: Overlook
2nd picture: The hose (in red) connects to the solenoid, helpful for tracing it.
3rd picture: (From the back of the Intake Manifold)...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
10:53 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
