Old 12-26-2023, 03:33 PM   #1
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
Do FA20s normally get this dirty after ~80k miles?
I removed the manifold on my engine and found quite a bit of gunk in the intake manifold and ports. Is this normal for an FA20 with about 80,000 miles on it? It’s all oily, gunk that wipes off relatively easily, but I don't have experience with how dirty these motors can get and this seems excessive. Also, this is a replacement motor and I know nothing of its history beyond that it was compression and run tested by the seller, so I'm wondering if this maybe indicates how this FA20 was run before me.
Sorry if there are already plenty of posts about this, but I always get an error now when I try to use the forum search function.
vfrqqq is offline   Reply With Quote
Old 12-26-2023, 04:15 PM   #2
whataboutbob
AutoX-10/10ths every run
I think a catch can would help with this. Even NA I got a decent amount of blow-by and I suspect what you are seeing is a result of blow-by.
Build thread:Here
Old 12-28-2023, 09:46 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That’s a bit heavier than I expect to see at that millage. A leak down is a better test than just compression. You could also try a WRX pvc. Bit stouter for the boost.
Old 12-30-2023, 09:16 AM   #4
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
I should add that, from the salvage pictures of the donor vehicle, the previous user at least wasn't running any FI and everything appeared to be stock from what I saw in the engine bay. Of course, that says nothing about how it was driven or was running an other-than-factory tune on the ECU.
Old 01-02-2024, 11:42 AM   #5
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Looks normal to me. Many intakes on modern engines get soot like this due to the EGR systems. I'd recommend replacing the PCV when installing it and using some intake and carb cleaner to clean it up.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 01-05-2024, 09:32 AM   #6
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
@vfrqqq Are you running or planning to run forced induction?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 01-14-2024, 07:50 AM   #7
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
I'm not running or planning to run forced induction. All the same, I installed a PCV/CCV dual catch can system to help mitigate the problem. I'm also planning to run a flexfuel tune on this NA setup and am curious if using flexfuel every now and then will sort of "clean" this up over time.
Old 03-28-2024, 02:22 AM   #8
Muffled
I thought port injection was supposed to help with exactly this issue?
Muffled is offline   Reply With Quote
Old 03-28-2024, 06:28 AM   #9
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
It did help with the issue. The port injectors won't keep it spotless.
dragoontwo is offline   Reply With Quote
Old 03-28-2024, 05:49 PM   #10
alphasaur
friendly
Drives: 17' 86
Recently removed my manifold for injector replacement and my valve were pretty spotless at approx ~70k miles. I have often run ethanol though.
I will likely be pulling manifold again soon and will check how they look post boost.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Possible for our FA20s to have the Torque Curve of the FA20DITs? brzfl Forced Induction 21 02-21-2017 07:43 AM
Post your dirty 86 Rayme FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 31 02-17-2013 04:19 PM
Dirty drifting in the FRS. dem00n FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 11-03-2012 06:31 PM
Windshield appear to be dirty. trueno86power Issues | Warranty | Recalls / TSB 17 08-03-2012 02:20 PM
Clean & Dirty trueno86power Other Vehicles & General Automotive Discussions 1 02-07-2012 12:54 PM
