follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 20 of 20
Search took
0.31
seconds.
Search:
Posts Made By:
Molez93
Forum:
Tracking / Autocross / HPDE / Drifting
03-06-2024, 07:32 PM
34
Wheel hub bearing life expectancy?
5,226
Posted By
DocWalt
Does anybody know what's different about second...
Does anybody know what's different about second gen front hubs? Nobody seems to know. Rear hubs are the same between generations. Considering the GR86 still has the steel knuckles I'd assume the bolt...
Forum:
01-09-2024, 03:05 AM
117
Oil weight for track only car with a lot of cooling?
44,165
Posted By
x808drifter
FTFY
FTFY
Forum:
06-20-2023, 02:02 PM
209
STX setup sharing thread (2023)
46,379
Posted By
DocWalt
This needs to be a concerted effort to make STM...
This needs to be a concerted effort to make STM happen, I've been trying for well over a year but there just weren't enough letters being written.
Please go write a letter: www.sebscca.com...
Forum:
06-20-2023, 09:27 AM
209
46,379
Posted By
DocWalt
lol, what? The second gen has a lower CoG,...
lol, what?
The second gen has a lower CoG, 25-50 pounds more overall weight (down low though) and 40+ more horsepower. How in the heck would it *not* be dominant?
I was ~5 tenths faster in my...
Forum:
06-01-2023, 09:35 AM
146
Why did I wait so long to try the pedal dance
25,557
Posted By
dalte2
An Autox'er that isn't trail braking is very...
An Autox'er that isn't trail braking is very unlikely to win. Lets say there is a big declining radius sweeper (seems like nearly every course has one), you absolutly have to trail brake into that. ...
Forum:
06-03-2022, 12:59 AM
132
2022 Twin to STR
19,493
Posted By
otter
I've run with both styles of classing (SCCA and...
I've run with both styles of classing (SCCA and NASA) and both have their flaws. NASA's is more approachable for the average person but there's too few classes and too much disparity in cars within a...
Forum:
05-19-2022, 12:36 PM
970
SCCA Solo D Street discussion
210,582
Posted By
Locust
I can drive my wife's base model Civic on...
I can drive my wife's base model Civic on all-seasons within 5 seconds of my STX times. 9 seconds is a lot more than just car. It doesn't matter what car/setup you're starting with your first year or...
Forum:
02-23-2022, 10:24 AM
132
2022 Twin to STR
19,493
Posted By
PointDSM
I love that Gen1's get a longer lifespan in STX. ...
I love that Gen1's get a longer lifespan in STX. It'll create a great battle in STR and leave STX as-is (which is perfect).
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
05-05-2020, 02:45 PM
44
Metal ball on the tranny drain plug magnet. What gives?
11,354
Posted By
AxisPower
Just to avoid confusion, these are different from...
Just to avoid confusion, these are different from the detent balls that sit inside the shiftfork shafts. Those are much bigger than the one in OP's picture. Only way I could see this happening is if...
Forum:
05-05-2020, 01:51 PM
44
11,354
Posted By
AxisPower
Since I just had the pleasure of taking my...
Since I just had the pleasure of taking my transmission apart I can tell you exactly what that is. Each hub/sleeve has 3 of these spring loaded balls. BRBA02 in the diagram....
Forum:
04-13-2020, 04:40 PM
23
High water % in brake fluid resivoir. Thoughts?
3,519
Posted By
Well, if you want to do it up right, I suggest...
Well, if you want to do it up right, I suggest you change out the master cylinder, the slave cylinder and the line that runs between the two, then bleed the system.
After that, if your test still...
Forum:
04-07-2020, 07:25 AM
44
11,354
Posted By
Code Monkey
You will need a new transmission, sooner rather...
You will need a new transmission, sooner rather then later, linky (https://www.ft86club.com/forums/showpost.php?p=3272420&postcount=133).
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
10-01-2019, 11:23 PM
628
Ohlins Road & Track for FRS/BRZ suspension install/review thread
256,514
Posted By
glhs386
I had the same exact problem. Sheared off three...
I had the same exact problem. Sheared off three endlink brackets, each time Ohlins had to pull a replacement off of a used set because they don't stock spares. Initially it seemed that it was...
Forum:
07-02-2019, 09:27 AM
3,914
Sticky:
STX Rules and Setup Questions
889,615
Posted By
DocWalt
Guys, we're in the STX thread. It's definitely...
Guys, we're in the STX thread. It's definitely legal, it literally says "ANY STEERING WHEEL MAY BE USED" with the caveat that it weighs as much or more than OEM. You're not going to make the OM wheel...
Forum:
04-11-2019, 11:30 PM
110
STX setup sharing thread (2019)
32,305
Posted By
CoolHandMoss
There is an older “STX setup sharing” thread but things definitely change over the years. I thought it would be nice to start a new thread for anyone that would like to share their current STX setup...
Forum:
04-01-2019, 07:08 PM
3,914
Sticky:
889,615
Posted By
cueball89
Do it, it's a great site! Scott, it's...
Scott, it's Mike! I've made the jump to STX as well. Welcome to the dark side:cheers:
Forum:
03-10-2019, 12:20 AM
3,914
Sticky:
889,615
Posted By
strat61caster
SPL has a good reputation, up to you if they're...
SPL has a good reputation, up to you if they're worth almost 2x the price of the alternatives, but hey maybe they're worth it, idk, haven't seen anything that makes me think they're worth the extra...
Forum:
03-01-2019, 05:42 PM
3,914
Sticky:
889,615
Posted By
strat61caster
The SPL is absolutely a no-go, as you say, all...
The SPL is absolutely a no-go, as you say, all metal, it also spins and rotates, functions not in the OE part.
I'm not positive is RS-R is legal, looks good but I would have to measure and compare...
Forum:
03-01-2019, 05:35 PM
3,914
Sticky:
889,615
Posted By
justinco
Your best bet is the DIF setup mentioned above....
Your best bet is the DIF setup mentioned above. You can buy them ready to go in SPC LCA's at FRsport if you don't have access to a press/shop that can do it :...
Forum:
01-25-2019, 06:51 AM
37
Opinions on Trac Control off for Autocross
6,131
Posted By
bdtbdtbdt
During one of the last autox events this year, My...
During one of the last autox events this year, My (long time pro) co driver and I experimented with the different traction settings in the cold and wet. I use a pedal dance eliminator (...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
03:38 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
