follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 26 of 26
Search took
0.02
seconds.
Search:
Posts Made By:
etc
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
09-13-2019, 09:20 PM
56
EvoX rear caliper swap
33,329
Posted By
etc
This doesn't use brz rear rotors, this uses STI...
This doesn't use brz rear rotors, this uses STI rear rotors. They are a larger diameter as well. There is also only one rotor I know this works with the DBA4000 because it is STI but dual drilled for...
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
06-21-2019, 02:14 PM
373
Sticky:
Which wheels clear 17+ BRZ Performance Package Brembos
261,242
Posted By
etc
TSW nurburgring 18x8 +45 should clear...
TSW nurburgring 18x8 +45 should clear (https://photos.app.goo.gl/rJVdbDbjBpZQTLY67).
Note that I don't technically have the PP brembos but this cadillac/evo chimera...
Forum:
01-10-2019, 12:55 PM
56
33,329
Posted By
etc
The bias calculators say to only use half the...
The bias calculators say to only use half the pistons in a fixed caliper setup vs floating. From http://www.tceperformanceproducts.com/bias-calculator/ :
Forum:
02-28-2018, 10:38 PM
56
33,329
Posted By
etc
ya, I am pretty sure it would hit the hub, I...
ya, I am pretty sure it would hit the hub, I don't think there is much space there at all. I also don't think there is enough extra metal to cut the slot into (nor can I think of a good way to cut...
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
09-27-2017, 01:56 AM
1
86 badge CAD
730
Posted By
etc
86 badge CAD
I put together a basic cad for the 86 / FRS badge in onshape if anyone is interested in using it or tweaking it: ...
Forum:
06-23-2017, 12:37 PM
56
33,329
Posted By
etc
I was out at Thunderhill yesterday. Worked great,...
I was out at Thunderhill yesterday. Worked great, no issues.
Braking is significantly better for me but I also upgraded my front pads (ebc yellow -> carbotech xp8). But with this setup now and...
Forum:
04-21-2017, 01:52 PM
56
33,329
Posted By
etc
I will update when I have put some track time on...
I will update when I have put some track time on these, I am in the middle of moving though so I don't plan on hitting the track again until maybe mid june.
As for a larger disc, that would be...
Forum:
04-19-2017, 01:20 AM
135
$600 Brake retrofit, Cadillac ATS brembos, STI rotors.
103,318
Posted By
etc
To address the bias shift I have tested swapping...
To address the bias shift I have tested swapping evox calipers over to create a matched set: http://www.ft86club.com/forums/showthread.php?p=2894514#post2894514
As noted there, this will...
Forum:
04-19-2017, 12:41 AM
56
33,329
Posted By
etc
http://i.imgur.com/YJlMx5H.jpg
http://i.imgur.com/yRVNvPR.jpg
This is designed as a complement to the ATS front caliper swap: http://www.ft86club.com/forums/showthread.php?p=2628568#post2628568
Forum:
Issues | Warranty | Recalls / TSB
09-29-2016, 01:32 PM
7
Another p0018 thread, Scion TSB?
3,456
Posted By
etc
So it appears I am out the other side, CEL has...
So it appears I am out the other side, CEL has been off for a couple days now.
Had a cam gear replaced by a local subaru engine builder (outfront motorsports) which was about $800 and replaced the...
Forum:
Software Tuning
09-29-2016, 01:18 PM
110
Replacing a Bricked damaged or faulty ECU with new or used ECU FRS BRZ GT 86
73,839
Posted By
etc
So to follow up. I had my cam gears replaced a...
So to follow up. I had my cam gears replaced a week or so ago but still had the CEL. I tried flashing b01c again and leaving the battery off for about 15min. The CEL came back.
I swapped in a new...
Forum:
Software Tuning
09-20-2016, 05:51 PM
110
73,839
Posted By
etc
Just some more info for those that are curious. I...
Just some more info for those that are curious. I was unable to find the procedure in the service manuals available on the site (http://www.ft86club.com/forums/showthread.php?t=12135) Mostly because...
Forum:
DIY (Do-It-Yourself) Guides
09-15-2016, 08:10 PM
18
3d print sound tube delete plug.
5,975
Posted By
etc
Lol I actually considered doing just that at...
Lol I actually considered doing just that at first too, had the hole saw out and everything :)
But decided to go slightly nicer looking, even though I only needed mine on temporarily since I took...
Forum:
08-31-2016, 04:03 PM
18
5,975
Posted By
etc
Thought I would share here too, I posted it on thingiverse:
http://www.thingiverse.com/thing:1743273
But if you remove your sound tube and need to plug the hole this will do it. I am currently...
Forum:
08-29-2016, 04:24 PM
7
3,456
Posted By
etc
Thanks guys, so much for my hopes of...
Thanks guys, so much for my hopes of short-circuiting the process :)
I will print the subaru TSB and bring it in, good suggestion. I guess ultimately I was hoping if I could point them at the...
Forum:
Forced Induction
08-16-2016, 04:38 PM
6,011
Jackson Racing Supercharger Owners Thread
2,082,180
Posted By
etc
The install was pretty straight forward. As was...
The install was pretty straight forward. As was mentioned before though be super careful about priming the rotrex before you start the car. I followed the instructions and primed it until the...
Forum:
06-14-2016, 07:39 PM
135
103,318
Posted By
etc
So quick update. Did two track days last month, 5...
So quick update. Did two track days last month, 5 mile at thunderhill and button willow (clockwise with the dragstrip, forget the #). Brakes performed excellently, no heat issues, the pads even still...
Forum:
05-13-2016, 01:35 AM
135
103,318
Posted By
etc
Also, I was putting my pads on tonight and as...
Also, I was putting my pads on tonight and as promised before I measured from the center of the hub to the edge of the caliper. For those trying to determine if they will fit your wheels. It measures...
Forum:
05-05-2016, 05:11 PM
135
103,318
Posted By
etc
Sorry I have neglected the thread for a bit. That...
Sorry I have neglected the thread for a bit. That is correct, those are these odd wheel weights GM put on camaro SS pads. I happened to have the camaro SS pads so I am using them until my track pads...
Forum:
04-21-2016, 12:20 PM
135
103,318
Posted By
etc
I looked around a bit for this, the ATS uses...
I looked around a bit for this, the ATS uses sliding caliper so that doesn't help. There are the camaro ss / ctsv brembos but they are much larger, around 14" diameter. The other option are corvette...
Forum:
04-21-2016, 12:44 AM
135
103,318
Posted By
etc
It is painted on as well with vht flameproof...
It is painted on as well with vht flameproof (2000f) paint. The usual recommended way is to.put a decal on then clear coat over it but I didn't trust that to handle track temps, especially with white...
Forum:
04-20-2016, 07:32 PM
135
103,318
Posted By
etc
I didn't dig too deep into the 2 piece options,...
I didn't dig too deep into the 2 piece options, you are going to spend 650+ for a set but the weight drop will be significant (~8lbs per rotor). You can start on the $190 blanks and work up to the 2...
Forum:
04-20-2016, 07:04 PM
135
103,318
Posted By
etc
Just to be clear this is only for the fronts. The...
Just to be clear this is only for the fronts. The rears would remain stock with this setup.
Forum:
04-20-2016, 05:25 PM
135
103,318
Posted By
etc
Is there anything in particular you would like to...
Is there anything in particular you would like to see?
Unfortunately I was running low on time when I actually mounted them and just did it quickly in one night so I didn't take a bunch of pics...
Forum:
04-20-2016, 05:07 PM
135
103,318
Posted By
etc
Here is a quick writeup of painting the calipers...
Here is a quick writeup of painting the calipers with vht paints and what I would do differently if I were doing it again.
First step is you prep the calipers. These are oem brembos and they don't...
Forum:
04-20-2016, 05:05 PM
135
103,318
Posted By
etc
Since I don't see any posts about it thought I would share here. A new budget option for larger brakes on the 86.
Calipers:
Cadillac ATS Brembos, $80-$150 each, new (price fluctuates widely on...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
08:05 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
