Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Search Forums
Showing results 1 to 30 of 124
Search took 0.01 seconds.
Search: Posts Made By: makinen
Forum: DIY (Do-It-Yourself) Guides 11-22-2025, 03:05 AM
Posted By makinen
Actually I was suffered when cold before adding...
Actually I was suffered when cold before adding heat protection walls.
228163
Battery, heat protection foam, a printed wall with almost void inside, heat protection foam.
Forum: Suspension | Chassis | Brakes -- Sponsored by 949 Racing 09-25-2025, 02:04 AM
Posted By makinen
I've used my17 rear shocks with GR86 rear springs...
I've used my17 rear shocks with GR86 rear springs since 2023 without any problem.
The lower side radius of the gen 2 springs is smaller than the gen 1's but they work with gen 1 shocks.
Forum: Engine, Exhaust, Transmission 12-06-2024, 09:03 AM
Posted By makinen
Oh, my assumption of ATF cooler flow direction...
Oh, my assumption of ATF cooler flow direction was opposite according to the diagram tha Luns posted.
It seems legit as looking at some upper oil pan pictures.
226381
226382
226383
Forum: Engine, Exhaust, Transmission 12-02-2024, 08:14 PM
Posted By makinen
For the coolant flow direction, refer this. ...
https://www.ft86club.com/forums/showpost.php?p=3550174&postcount=11
Forum: Engine Swaps 11-05-2024, 07:32 AM
Posted By makinen
http://revo-tune.jp/feature-areitcles/dairy_report...
http://revo-tune.jp/feature-areitcles/dairy_reports/2023/02/14/id17999
Revolution did it.
Forum: Engine Swaps 09-10-2024, 01:14 AM
Posted By makinen
https://motor-fan.jp/weboption/article/110007/2309...
https://motor-fan.jp/weboption/article/110007/230927dvnc09_a75i5483/
They did similarly.
Forum: Engine Swaps 07-28-2024, 08:37 PM
Posted By makinen
225560 Possibly caused by the gap between...
225560
Possibly caused by the gap between the sensor and the cam trigger plate?
225561
Forum: Engine Swaps 07-28-2024, 08:10 PM
Posted By makinen
I've read that and it's hard to find the...
I've read that and it's hard to find the difference of a few millimeters by comparing pictures of different angles. But it is clear that the target wheel in your picture has enough gap over the...
Forum: Engine Swaps 07-27-2024, 09:29 PM
Posted By makinen
Are other pulleys same? I'd like to reuse my...
I'd like to reuse my electric water pump on FA24 so the water pump pulley might not be an issue.
My 2013 engine was blown and stock FA24 was sourced. I wonder how RS...
Forum: DIY (Do-It-Yourself) Guides 01-25-2024, 10:10 PM
Posted By makinen
The first gen snorkel exit shape is slightly...
The first gen snorkel exit shape is slightly wider and shorter than the second gen.
223795
The clean one is the second gen.
Forum: Suspension | Chassis | Brakes -- Sponsored by 949 Racing 01-07-2024, 01:55 AM
Posted By makinen
F 2.7k BRZ springs R 3.4k MY17 -> 4.0k GR86...
F 2.7k BRZ springs
R 3.4k MY17 -> 4.0k GR86 springs
FSB 18mm stock
RSB 15mm Impreza or MY17
The ride height changes with loads are manageable. Before installing the Traction Mode, I was worried...
Forum: Engine, Exhaust, Transmission 11-24-2023, 05:55 AM
Posted By makinen
Please refer my post at...
Please refer my post at https://www.ft86club.com/forums/showpost.php?p=3550174&postcount=11.
And 2nd gen. has dedicated inlet and outlet for its oil cooler.
223185
The outlet of the oil cooler...
Forum: Engine, Exhaust, Transmission 10-30-2023, 08:39 PM
Posted By makinen
I think it works, but with little drag as its...
I think it works, but with little drag as its entrance is wider than required.
222968
This figure from Tune to win, Carroll Smith.
Forum: Engine, Exhaust, Transmission 10-28-2023, 04:09 AM
Posted By makinen
It'll be helpful to get air guide panels. 222950
222950
Forum: BRZ First-Gen (2012+) — General Topics 10-22-2023, 11:23 AM
Posted By makinen
I've experiencing that "chirping" sound after...
I've experiencing that "chirping" sound after chaning a gas station recently, first time, even after 120,000km mileage. And getting used to that sound because that gas station is cheaper. :bonk: No...
Forum: DIY (Do-It-Yourself) Guides 10-15-2023, 10:59 AM
Posted By makinen
A battery adapter for Shorai LFX36L3-BS12. ...
222738
222739
https://www.thingiverse.com/thing:6266287
Forum: Engine, Exhaust, Transmission 10-08-2023, 10:41 AM
Posted By makinen
At least the fans are working when AC is on, it...
At least the fans are working when AC is on, it belongs to the ECU.
222654
The fan could run at 103 C without AC in some conditions.
222655
Forum: Suspension | Chassis | Brakes -- Sponsored by 949 Racing 09-06-2023, 10:45 AM
Posted By makinen
I reckon it can be installed regardless of regid...
I reckon it can be installed regardless of regid collars but could be better with some kind of similar things.
I installed GP Sports kit without rigid collars, but there have been installed...
Forum: Software Tuning 07-05-2023, 09:33 AM
Posted By makinen
I forgot that I made changes for K00G not K01E. ...
https://www.ft86club.com/forums/showpost.php?p=3586160&postcount=19
Forum: Software Tuning 07-05-2023, 09:30 AM
Posted By makinen
Modifications for K00G
As AussieBRZ mentioned this is required for K00G rom, I'd like to add my modifications for K00G. Any rom definitions based on K00G could work.
But as usual use this at your own risk.
Forum: Software Tuning 06-29-2023, 09:18 AM
Posted By makinen
I made overboost cut for A01E and K01E. Not hard...
I made overboost cut for A01E and K01E. Not hard for K00G if needed. I guess callisto can do either.
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 05-30-2023, 09:03 PM
Posted By makinen
Why don't we have a fan car like T.50?
Forum: Suspension | Chassis | Brakes -- Sponsored by 949 Racing 04-17-2023, 12:52 AM
Posted By makinen
Yes, several reviews mentioned. ...
https://ameblo.jp/naughty-bear/entry-12371533584.html
https://minkara.carview.co.jp/userid/645187/car/1816052/6352485/note.aspx
Forum: Suspension | Chassis | Brakes -- Sponsored by 949 Racing 04-16-2023, 06:34 AM
Posted By makinen
Have you noticed rear ride height changes? Some...
Some reviews that I found in minkara told that rear springs should be changed to the strong ones.
Forum: DIY (Do-It-Yourself) Guides 04-13-2023, 04:55 AM
Posted By makinen
That Ford vent introduced at 2016. ...
https://www.ft86club.com/forums/showpost.php?p=2724649&postcount=773
Forum: Engine, Exhaust, Transmission 04-05-2023, 12:49 AM
Posted By makinen
It fits perfectly catback-wise. Quieter than GT86...
It fits perfectly catback-wise. Quieter than GT86 stock catback.
219736
Forum: DIY (Do-It-Yourself) Guides 03-29-2023, 10:59 AM
Posted By makinen
I gladly share this STL file. ...
https://www.thingiverse.com/thing:5938973
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 03-15-2023, 07:30 PM
Posted By makinen
Yes, it is 3D printed one for diff cooling.
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 03-15-2023, 12:54 AM
Posted By makinen
219141 You can see the holes in the rear...
219141
You can see the holes in the rear bumper.
There are chances that hold heat inside the rear bumper space. So I made holes to escape heat out of that space.
The connector parts that hold...
Forum: DIY (Do-It-Yourself) Guides 03-07-2023, 08:10 PM
Posted By makinen
1st gen. door mirror wing
Hi,
This is a kind of anti-buffeting device, so to speak, concentrated on the aesthetic side more.
218973
218974
218976
