Old 08-28-2013, 01:48 PM   #99
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
Originally Posted by zc06_kisstherain View Post
you didnt miss any step.
1. either washer is defective or worn.
2. you might striped thread of oil pan plug.
i used to use torque wrench on tightening the plug but not on oil pan bolt anymore. i just put enough torque with hands. they won't come off.
recheck washer and replace it again for next change. I would put old oil plug bolt back with washer then see if there is leak. if not, then might be fumoto valve thread is damaged or washer doesn't fit well with fumoto valve
Well, The leak was present before installing the fumoto valve so I don't think it is that. Also, the valve has it's own foam/rubber washer so I did not use another crush washer. I will probably switch back to the original bolt (with a new crush washer) this weekend and see if the leak persists.
Sevs753 is offline   Reply With Quote
Old 08-28-2013, 06:28 PM   #100
Marrk
Drives: Honda Fit
Good idea.
Also, I was thinking that you might use some teflon tape (a.k.a. plumber's tape) on the threads of the drain bolt and/or the fumo valve. Don't know if teflon tape is rated for a hot oil application, but . . . .
Keep us posted.
Marrk is offline   Reply With Quote
Old 09-08-2013, 09:32 AM   #101
afsefo
afsefo's Avatar
Just did my very own oil change!
So just got done doing my first oil change EVER!
Parts:
Dimple Magnetic Drain Plug
Prova Sports Oil filter
and
Eneos Sustina 0W-20 Synthetic Oil
afsefo is offline   Reply With Quote
The Following 2 Users Say Thank You to afsefo For This Useful Post:
FRSapex (09-13-2013), Marrk (09-08-2013)
Old 09-08-2013, 11:50 AM   #102
Marrk
Drives: Honda Fit
^^I'd like to see a picture of the metal debris (if any) that is on that Dimple Magnetic Drain Plug at your next oil change.
Old 09-09-2013, 01:40 PM   #103
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Parts:
and
Nice! I ended up using the Idemitsu 0w-20, OEM black oil filter and the Dimple plug! I'm a bit jealous of your Prova filter and Eneos oil haha. :happy0180:
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 09-10-2013, 10:16 AM   #104
frs10
Drives: tezla
info on the dimple plug?
what else needs to be replaced with the oil change?
frs10 is offline   Reply With Quote
Old 09-10-2013, 11:47 AM   #105
Marrk
Drives: Honda Fit
Thanks,
Rick
I am always a little cautious about deviating from OEM when it comes to oil filters. After-market filter failures are an incredibly easy way to blow up an engine.
Do we have any reliable feedback or assessment of the Prova filter?
Thanks.
Old 09-10-2013, 04:17 PM   #106
RallySport Direct
Thanks.
Yeah I am okay with using any of the high end brands for the oil filter, I just prefer OEM as it is well.. OEM lol. We have heard nothing but great things about the Prova oil filters, but I have never cut one apart to compare, although if we ever have a chance to cut on open.. I will I was in a hurry on our last oil change and the Prova filter was throw out so I was not able to test it out.
Thanks,
Rick
The Following User Says Thank You to RallySport Direct For This Useful Post:
Marrk (09-10-2013)
Old 09-10-2013, 04:33 PM   #107
Marrk
Drives: Honda Fit
Thanks,
Rick
When you finally do cut that baby open, post the pics.
Old 09-10-2013, 04:40 PM   #108
RallySport Direct
It is an extremely high power neodymium magnet. They are like scary powerful haha, I have a set of their "black hole" oil filter magnets on my desk and if you are not careful and get your skin caught between them, they will give you a blood blister...ask me how I know lol.
Basically they are just a great option for someone wanting a magnetic drain plug, they are super high quality and come with a lifetime warranty. Besides the oil filter, oil, drain pan, funnel and new drain plug gasket, nothing else should be needed.
Thanks,
Rick
Old 09-10-2013, 04:41 PM   #109
RallySport Direct
Will do!
Thanks,
Rick
Old 09-10-2013, 04:56 PM   #110
Marrk
Drives: Honda Fit
Thanks,
Rick
FYI Some folks on Bob the Oil Guy pointed out that having a drain plug magnet could lead to an oil blockage, like so: that super-strength Dimple magnet collects a whole lotta metal, then a bunch of it breaks off and circulates to a narrow place in the system . . . and there's your blockage.
While I like the magnet idea, there could be unintended consequences, especially with a super-strength magnet. Frequent oil changes or frequent oil changes with an adequate-strength magnet may be just as good an option.
Old 09-10-2013, 05:08 PM   #111
RallySport Direct
That is something to think of as well. And when it comes to oil and oil systems I might take their word over mine haha, but I will still continue to run one and here is why.
Everytime I pull my magnetic drain plug for an oil change, I have a film of metal goo on there, and while the oil filter could easily handle that load, it is less debris getting caught in the filter.
Now if you ever have enough shavings or metal chunks on the magnet to potentially plug up the pickup tube, oil galleys or any part of the oil system, something else is going on inside the engine, and you may catch it before a catastrophic failure occurs.
Also with the Dimple, I am able to pick up hammers, and other large heavy tools with them, I trust that the metal will stick to the plug vs getting swept away in the oil pickup.
Now please note all of the above is just my theories/opinion so take them with a grain of salt I have run a magnetic plug on all of my cars for about 8 years, and I have never had a problem before, plus I just like looking at the particles stuck on the plug to make sure it is just normal wear and tear and not a real issue.
Hope this helps!
Thanks,
Rick
The Following 4 Users Say Thank You to RallySport Direct For This Useful Post:
chanomatik (09-10-2013), FRSapex (09-13-2013), GT86_PRAGUE (12-09-2014), Marrk (09-10-2013)
Old 09-10-2013, 06:18 PM   #112
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
That's pretty much what my tuner/mechanic said. If there's enough metal being caught to cause a problem, then you have bigger problems to address.
The Following User Says Thank You to chanomatik For This Useful Post:
RallySport Direct (09-11-2013)
Oil Change Questions #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 06-28-2012 11:06 PM
Color Change Dark_Angle Mid-Atlantic 10 05-30-2012 02:00 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
I was able to change my pre-order. nkrein22 BRZ First-Gen (2012+) — General Topics 23 04-10-2012 04:16 PM
Can SOA change my preorder? Zaneman BRZ First-Gen (2012+) — General Topics 8 04-08-2012 02:06 PM
