Old 11-24-2015, 04:01 PM   #1
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Arrow How to Install Subaru BRZ RGBW™ & Switchback LED Boards by Diode Dynamics
[ame="https://www.youtube.com/watch?v=ifmj2ktqr54"]How to Install Subaru BRZ RGBWâ„¢ & Switchback LED Boards by Diode Dynamics - YouTube[/ame]
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Diode Dynamics (11-27-2015)
Old 11-24-2015, 08:57 PM   #2
AzureShadow
Drives: 2015 Subaru BRZ Limited 6MT WRB
Anyone know if these are as bright as the DIY mod that was posted a while back? If it was it'd be a great alternative for those of use that don't want to mess around with breaking and re-soldering traces.
AzureShadow is offline   Reply With Quote
Old 11-24-2015, 09:17 PM   #3
sactownbwoy
sactownbwoy's Avatar
Drives: 2014 BRZ Limited
They appear to be much brighter than stock so I am going to guess that yes they are as bright as the DIY
sactownbwoy is offline   Reply With Quote
Old 11-25-2015, 12:27 AM   #4
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
They are NOT as bright as the mod posted. I asked Diode Dynamics about this today in an email -- The LED boards here will increase brightness over stock but not substantially as heatsinks/heat management would be required.
I wish it were true... but if you're going for higher brightness I don't think this will cut it!
ajcarson11 is offline   Reply With Quote
Old 11-25-2015, 01:36 AM   #5
ryoma
ryoma's Avatar
I think the switchback would be cool since it will work as a turn signal too, but would it be too much with the original turn signal AND the boomerang? lol
Old 11-25-2015, 02:52 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you have an LED flasher module you could remove the standard indicator without issue. Or you could replace it with an LED bulb and I reckon it would look quite good.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-25-2015, 12:39 PM   #7
AzureShadow
I wonder if their LED's can handle more current or not. I would think you could throw some small heatsinks on the back of the LED's and be alright. I mean no one seems to be having issues with the DIY mod.
Old 11-30-2015, 12:02 AM   #8
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
This would be a good question for @Acree
xkalelx is offline   Reply With Quote
Old 11-30-2015, 09:27 AM   #9
ajcarson11
I've already contacted DD on this to some degree:
"Thank you for choosing Diode Dynamics! Our LED drop in boards will be at a slightly brighter then factory brightness level but this was not the main focus of the replacement boards. To safely increase the brightness of these boards, you would also want to provide the necessary heat sinks within the headlight. To keep the modification to a minimum the brightness level has only been slightly increased.
Both the RGBW and switchback LED board will work in conjunction with the Always on Module!
Best,
Justin
It looks like you could drive more current through with some additional heat protection (heat sinks) but the boards aren't made to be much brighter than stock.
So yes, if you want to buy some boards and do some modification (add heat sinks, change components) to increase current flow I can't see why this would be a problem.
The Following User Says Thank You to ajcarson11 For This Useful Post:
xkalelx (11-30-2015)
Old 12-02-2015, 09:11 PM   #10
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Considering Diode Dynamics created the new boards, I would ask them for the maximum current rating for the new LEDs.
Obviously whatever controller they use will need to be replaced with something compatible to run at a higher current.
You will also need to take care of all of the same thermal considerations.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Always-On™ Module for Subaru BRZ by Diode Dynamics JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 245 06-07-2021 12:14 AM
BRZ Review/Install Guide for XML2 LED fog lights from Diode Dynamics 4honor Cosmetic Modification (Interior/Exterior/Lighting) 31 12-28-2016 11:12 AM
Fog Light Install Diode Dynamics snakey Cosmetic Modification (Interior/Exterior/Lighting) 16 12-09-2015 04:34 PM
Diode Dynamics Switchback Turn Signals LED 2isballer Cosmetic Modification (Interior/Exterior/Lighting) 2 03-02-2014 01:46 PM
DIY - Diode Dynamics HID install on WinJet/Spyder Headlights FT-86 SpeedFactory DIY (Do-It-Yourself) Guides 0 02-21-2014 09:57 AM
