Old 03-14-2015, 02:25 PM   #1
trdric
Drives: fr-s
Coldest start possible on e85 stag2 oft?
What temperature where you guys able to start your car on e85? its roughly -10C (14F) here in the morning and I wanted to know if the car will start if I switch over to E85.
If not, what temperature do you think I will start without any issues !
trdric is offline   Reply With Quote
Old 03-14-2015, 10:06 PM   #2
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
lmao mine had trouble starting when it was 50*F. I switched back to 93 octane because of it, but they say mixing in a little bit of 93 octane will help bring the e-content down enough to where starting isn't a problem. I'd recommend getting a flex fuel kit at that point.
Jyn is offline   Reply With Quote
Old 03-15-2015, 01:59 AM   #3
steve99
Getting E85 to start at those temps is going to be difficult.
It might be best to wait till it warms up a bit, or have a can of engine start handy.
cold start mods these guys did worked down about 20 degrees.
you can also add a gallon or so of petrol to make starts easier
http://www.ft86club.com/forums/showp...1&postcount=40
http://www.ft86club.com/forums/showthread.php?t=67310
A flex fuel kit wont help starts on E85 , its just the properties of ethanol that make it hard to start.
Old 03-16-2015, 02:18 PM   #4
trdric
Drives: fr-s
for information, the car started easily this morning at -5C(23F)
The Following User Says Thank You to trdric For This Useful Post:
steve99 (03-16-2015)
Old 03-16-2015, 02:42 PM   #5
D_Thissen
D_Thissen's Avatar
Was the car in the garage or plugged in by any chance?
Old 03-16-2015, 04:42 PM   #6
trdric
Drives: fr-s
nop outsde for night. i was home at 8pm and drove away this morning at 7AM
Old 03-16-2015, 05:18 PM   #7
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
I'll usually have pops and weird idle for the first few minutes under 40*F even with the cold-start IPW changes. Lowest I dropped down to using e85 this winter was about 25*F and started on the first try, albeit with the aforementioned pops and weird idle...
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 03-16-2015, 05:50 PM   #8
carlitosway6891
Drives: white out project fr-s
anything at or lower than 50 degrees and mine would take several attemps to get started. back on 93 till it stays warm =(
carlitosway6891 is offline   Reply With Quote
Old 03-16-2015, 05:55 PM   #9
bfrank1972
Drives: 2013 FR-S Argento
Depending on where you are, you might not be getting E85 from the pumps - in colder climates they switch to a winder blend with less E content to help the flex fuel vehicles with starting in very cold weather.
bfrank1972 is offline   Reply With Quote
Old 03-16-2015, 06:08 PM   #10
trdric
Drives: fr-s
[ame="https://www.youtube.com/watch?v=ceFu46s72Vs"]e85 cold start -5C - YouTube[/ame]
video of is starting
Old 03-16-2015, 06:16 PM   #11
steve99
Assume that was with cold start mods ??
Old 03-16-2015, 06:45 PM   #12
trdric
Drives: fr-s
not at all im new to OFT and havent done anything other than writing
Old 03-16-2015, 08:29 PM   #13
cawith
Drives: Toyota GT86 6M/T
I have had the same issue and I'd also done the IPW changes.
Don't know what the popping is, but it doesn't sound very good. Found out that if I revved it to 2500-3000 rpm just once immediately after the engine had turned on, then the popping would not happen. Have you tried that?
cawith is offline   Reply With Quote
Old 03-16-2015, 09:38 PM   #14
momo3605
Drives: 2014 Fr-S Monogram
The popping is just excess fuel being burnt. By giving gas, you push more fuel, so it ignites on the exhaust side causing the pop. It's harmless. There's a thread dedicated to how to get the car to pop and crackle more Mini Coopers and Abarth's pop and crackle like crazy
momo3605 is offline   Reply With Quote
Coldest you've driven your BRZ Deslock BRZ First-Gen (2012+) — General Topics 18 02-18-2015 07:07 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 05:06 PM
