Northern California NorCal
Old 05-01-2014, 04:04 PM   #1
exE36M3
Working Fender Vent Project... Need your spare parts
Hey Guys... so I decided to start a fender project and need some spare parts.
What you get in return is a working prototypes.
My idea:
1. Take the black portion of the garnish and use it for a template to cut aluminum mesh from.
2. The leftover "arrow" garnish do two things:
a. drill up symmetrical holes to allow the engine heat to vent
b. paint the "valley" portion flat black - so with the mesh in place, all that shows through is black.
3. So what's left is this... because I can't see anyone, even me spending $200+ for something comparable that doesn't even work.
Can you guys help?
I just need some donor black inserts (and maybe a pair of fender garnishes).
I'll supply the aluminum mesh which is available in brushed aluminum and powered coated black.
I'm not looking to "sell" these things. If I get this to work right, I can just publish the how-to online so everyone benefits. The only real cost would be the aluminum mesh and the tools. At this point, the mesh is like $25. The biggest expense are those darn garnished, they are like $100+ a set!
Here's what it will look like...
exE36M3 is offline   Reply With Quote
Old 05-01-2014, 04:25 PM   #2
racer_tom
Has been racer
racer_tom's Avatar
Drives: 2013 Hot Lava FRS
Why do you need donor black inserts, since you plan to replace those? Can't you just trace a good one and use that as your pattern for the mesh?
racer_tom is offline   Reply With Quote
Old 05-01-2014, 06:08 PM   #3
exE36M3
Thanks for asking Tom... I just need to borrow the inserts to trace off of.
I'd rather not destroy mine or anyone else's (by pulling it off the garnish) if they happen to have a spare one lying around.
But if no one has one lying around - I'll most likely just destroy mine - per se.
Old 05-02-2014, 02:15 AM   #4
MyRx
MyRx's Avatar
Not a bad idea. Paging @omegared19 since he's done similar to his [non] BRZ vents. I wouldn't mind exploring this option, even pick up a set, drill the holes to make it function. I could see my drawback as color-matching the finished product tho. Otherwise, vent vent vent!
Old 05-02-2014, 02:55 AM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I have been thinking about this for a while. I Found a wrb set for fairly cheap but am still waiting to see paint costs. Match worries me a bit too since it wouldnt be blended.
Old 05-02-2014, 11:55 AM   #6
exE36M3
Well if I can get the process down and documented - there really wouldn't be a need to buy the garnish portion, but the mesh to replace the black inserts.
All the owner would have to do from there is drill out their stock garnish.
Once I get a working unit, I'd send the mesh off to a machine shop to make sets of them.
Old 05-02-2014, 02:14 PM   #7
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
i recall @omegared19 actually did this to his brz with prova vents and also cutout the fenders so they are functional.
garfull is offline   Reply With Quote
Old 05-02-2014, 07:07 PM   #8
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Yes, @MyRx @finch1750 @garfull, I did. Any help that I can ever lend on the subject will be gladly given. Help in cutting the fenders is offered as well. I have the Dremmell and the cutting discs.
Someone had posed the question on this topic once about a risk of hi/low pressure and balance. Yes this could become an issue. So to those of us planning on breaking the 400kph barrier, remember your Hans device
omegared19 is offline   Reply With Quote
The Following 2 Users Say Thank You to omegared19 For This Useful Post:
MyRx (05-02-2014), Pwolf (05-02-2014)
WTT FR-S fender vent for BRZ fender vent (white) Anthony Exterior Parts (Aero, Lighting, Etc.) 8 12-02-2013 07:52 PM
WTT: My Asphalt fender vent covers for your DGM BRZ fender vent covers SkAsphalt Canada Classifieds 0 10-07-2013 01:25 PM
TRADE: FT86 Fender Vent for BRZ Fender Vent xia Exterior Parts (Aero, Lighting, Etc.) 0 10-04-2013 09:56 PM
WTB Red BRZ/FRS fender vent. CajunFRS Exterior Parts (Aero, Lighting, Etc.) 3 09-21-2013 04:17 PM
SWP BRZ fender vent for SWP FRS fender vent BoxRZ_86 NY / NJ / CT / PA 4 05-27-2013 10:24 PM
