Forced Induction Turbo, Supercharger, Methanol, Nitrous |
01-12-2014, 12:37 AM | #1 |
Big Member
Drives: 2014 FR-S
Why aren't some concerned about putting a turbo on a high compression motor?
I see people post about getting a turbo or thinking about it, on the stock FA20 engine. But with the high compression of 12.5:1, I don't think it's a good idea. I'm not an expert at all on engines, but this is one of the more common sense things about cars. It just adds pressure to an engine with already high pressure.
01-12-2014, 12:58 AM | #2 |
Drives: 2013 Raven FRS MT
I agree with having high compression motor with a turbo not being a logical combination. Yet I have also read that the motor was built quite strong. Now, that does not mean one could not burn up a piston or break a rod.
I plan on a turbo in a couple of years. Rods and pistons are getting replaced with the turbo install. Other things can still break. I am most concerned about the transmission and drive shaft. Or burning up the clutch. Compression ratio would be the least of my worries when considering a turbo in this car. |
01-12-2014, 01:00 AM | #3 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Two words.
DIRECT INJECTION
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
The Following 7 Users Say Thank You to OmarGC For This Useful Post: | mack4477 (01-13-2014), Poodles (01-12-2014), Rick@Vortech (01-13-2014), SkAsphalt (01-12-2014), Sportsguy83 (01-12-2014), suaveflooder (01-12-2014), tr1x5tuh (01-12-2014) |
01-12-2014, 01:11 AM | #4 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
If you can afford to go FI, you most likely can afford a built block if / when it pops.
The Following User Says Thank You to midnight23 For This Useful Post: | protpibe (01-12-2014) |
01-12-2014, 01:26 AM | #5 |
Drives: 2013 GBS BRZ Limited
That is one reason for all the talk of E85 with FI.
Less chance of knocking at boost. |
The Following User Says Thank You to stugray For This Useful Post: | SkAsphalt (01-12-2014) |
01-12-2014, 01:48 AM | #6 |
Boosted
Drives: Not a supra....yet
Technology has Gone a long way. Cars now run a 14:1 comp on pump gas, few years ago people bitched about 12.5:1
The Following 2 Users Say Thank You to SmsAlSuwaidi For This Useful Post: | Sportsguy83 (01-12-2014), wparsons (01-12-2014) |
01-12-2014, 01:52 AM | #7 | |
Drives: 2014 Premium BRZ
I think E85 has an octane rating around 110 +? correct me if I am wrong? But we all know E85 has less energy per gram than gasolene. So what the hell does it matter? Octane rating IMO just refers to how much a fluid can be "compressed" before the pressure and heat of said compression causes it to detonate before the timed spark, this results in bad things happening and it is why engines fail more than most usually, tuning problems. All engines are chunks of metal moving at high speeds..it really isnt rocket science. I am just a third party who hangs around very old guys too often who like to talk too much and write their own ecu's ...and I can never figure out when to leave and go home without interrupting them ... But compression ratios do not matter as long as you keep in mind where your threshold for spontaneous detonation of your fuel occurs, if you can intercool it, methanol inject it , retard your timing ..w/e. it doesn't matter .. The only thing you need to concern yourself with is combustion chamber temperature/ mix temperature as I understand it. Compression ratio and boost pressure and volume are "variables" that affect that, but your only goal is to keep your fuel from spontaneously detonating. There are many ways to do/influence that and I Would suggest learning more about fuel itself to the OP. Last edited by Photonic; 01-12-2014 at 02:04 AM. |
The Following User Says Thank You to Photonic For This Useful Post: | DeliciousTuning (01-13-2014) |
01-12-2014, 01:53 AM | #8 |
My FR-S has 5 gears
You guys are missing the point.
Again, technology has come a VERY long way. Direct injection, gives you the benefit of keeping the cylinders much cooler than a standard fuel injection system. Thus allowing you more headroom for boost, and more aggressive timing and fuel profiles.
Omar GC
01-12-2014, 01:56 AM | #9 | |
Boosted
Gt3s arnt boosted and gt2(which is boosted ) has a 9.4:1 but yeah i do agree with everything else you wrote Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | OmarGC (01-12-2014) |
01-12-2014, 02:08 AM | #10 | |
I prefer to focus on fundamentals rather than the general idea. if your fundamentals are good ..you can open your head to the kinda stuff you are talking about. I have a lot to learn about direct injection still ..but again all you need to look at is how you can keep your mix cooler ..cooler = less detonation threshold = more compression or timing can be run ...and it = more efficient also. Thanks so much! I like to make more long winded answers. I can be annoying. but I Want to assume people may not understand where I am coming from. Maybe people don't know what "cool" means in regards to how all the variables come together. |
01-12-2014, 02:15 AM | #11 |
High compression + boost is ideal. The only concern is that the engine can handle it.
High VE + boost = You guys should do a little research on how much boost a BONE STOCK s2000 engine can take reliably. It's a 11.x:1 compression engine without DI, and is using 20 year old technology now. Hint: It's a lot. |
The Following 8 Users Say Thank You to CSG Mike For This Useful Post: | ATL BRZ (01-13-2014), FreshFRS (01-12-2014), lbroskee (01-13-2014), MAPerformance (01-12-2014), OmarGC (01-12-2014), SkAsphalt (01-12-2014), Sportsguy83 (01-12-2014), wparsons (01-12-2014) |
01-12-2014, 02:42 AM | #12 |
Big Member
Drives: 2014 FR-S
01-12-2014, 02:48 AM | #13 | |
Boosted
Turbos on a high comp motor is not as bad as you think Sent from my IBrick
01-12-2014, 02:58 AM | #14 |
Big Member
Drives: 2014 FR-S
So I guess the consensus argument for turbo is 1) use E85 gas and 2) direct injection helps cool things.
Similar Threads | ||||
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit | FullBlown | Forced Induction | 414 | 07-14-2014 09:52 PM |
Frs300 Fa20club built motor and turbo build | Frs300 | Member's Car Journals | 32 | 01-18-2014 05:27 AM |
Crawford Limited Turbo BRZ - built motor | Mrqb22 | Forced Induction | 8 | 11-11-2013 01:34 PM |
Building a motor before turbo? | ikeryder13 | Forced Induction | 25 | 11-04-2013 09:04 AM |
Anybody else thinking about buying crawfords rebuilt motor and turbo? | Frsexxxy | Forced Induction | 21 | 05-29-2013 04:07 AM |
