Old 07-20-2013, 12:13 PM   #1
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
CEL U0073 - Network
Got a CEL light on the way to work this morning. Both the slip and engine lights came on. When I got to work I shut the car off and turned it back on, the slip light went away but the engine light was still on.
Mods: K&N CAI, Borla header back, Visconti tuned.
The car runs fine, I was just wondering if it's something serious or if I should just clear the code? Thanks in advance guys.
Trashed675 is offline   Reply With Quote
Old 07-20-2013, 12:57 PM   #2
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Were you running the Torque app on your phone/tablet by any chance? If you do not close the app after shutting the car off you will get that code when you start the car again with the app still running.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
Old 07-20-2013, 03:18 PM   #3
Trashed675
Trashed675's Avatar
I've got an android head unit. Torque starts every time i start the car and i've never turned it off before turning the car off, this is the first time i've gotten the light. It does appear to be ODB2 adapter related though.
Old 07-20-2013, 11:48 PM   #4
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Had the same code-cleared it couple of times hasn't returned.
Gords_zenith is offline   Reply With Quote
Old 09-08-2013, 09:27 PM   #5
nix
nix's Avatar
Drives: AVO BRZ
Same here, 2 or 3 times over the past 9 months.
nix is offline   Reply With Quote
Old 09-11-2013, 07:27 PM   #6
Struckbylitenin
Struckbylitenin's Avatar
Drives: 10 Series FR-S
I just got the same code but also my Cruise control light was lit in AMBER, my AC would not blow cold air and as I would come to a stop the tranns would jerk slightly (auto).
I literally cursed as I walked from my driveway all the way up to the house.
I also was using Torque but even with the app off and obd adapter unplugged the CEL still comes on during startup and the second I press Cruise control its light lights up amber and stays lit.
Gonna take it in tomorrow morning to have it looked at. I haven't had the car more than a month!!
Struckbylitenin is offline   Reply With Quote
Old 09-13-2013, 12:00 AM   #7
Dezoris
Dezoris's Avatar
Its the OBD2 adapter/torque you have plugged in.
If torque is open/sleeping in a certain state and the connection to the OBD2 adapter is open when you start the car, the ECU will see it as a fault and throw U codes.
Clear the codes with torque first.
Leave Torque off until the car is running problem solved. This is a normal bug.
Old 02-12-2014, 07:59 PM   #8
CBR600RR
Drives: Raven Black
How do you clear the code, U0073, with the torque app?
Old 02-16-2014, 06:41 PM   #9
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
just threw the same code today. How do you clear it?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 02-16-2014, 11:27 PM   #10
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
In Torque
  • Go to Dashboard (not Realtime info display)
  • Scroll/spin the thingy until you see "Fault Codes" app, open it
  • Tap the "..." at the top left to open the menu (or press your phone's menu button)
  • Select "Clear faults on ECU".
aegisdrgn is offline   Reply With Quote
Old 03-14-2014, 08:56 PM   #11
extrashaky
Drives: 2014 BRZ Limited
I had this happen to me today in rural Arkansas, out in the middle of nowhere. Engine and slip lights came on, and the engine dropped to half power. I pulled off and checked the codes in Torque: U0073. So I got on the internet and searched for U0073 and found THIS THREAD telling me what was wrong with my car. Cleared the code and was back on the road in about seven minutes. Drove another 400 miles without incident.
Not too many years ago I would have had to call for a rescue. Ain't technology grand?
Old 03-24-2014, 10:35 PM   #12
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Thanks for the thread, read it and cleared my code! Was using Dash (for Android) with the ODB2.
Meet Selina, my Asphalt FR-S MT6.
Like EightSixClub on FB, and follow us on Twitter!
DjDATZ is offline   Reply With Quote
Old 04-13-2014, 03:16 AM   #13
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I received U0073 today and yes I was using Torque at the time. Whatever it did, it actually shut off my engine. Restarted fine but still had the CEL for a bit. The fault cleared itself after a while (after I unplugged my ELM427 BT).
mit_peid is offline   Reply With Quote
Old 04-13-2014, 07:09 PM   #14
extrashaky
FYI, general consensus seems to be that Torque causes this if it's already running when you start the car. I started making sure to exit Torque every time I turn off the car (hitting the "back" button twice from the realtime monitor screen will give you a prompt to ask if you want to exit). Since I started doing that, the only time I've had the code is the one time I forgot to turn off Torque when I was just running into a parts store for a minute.
I won the FT-86 II Social Network Racer Competion + free trip to car's unveiling! :D Leeky Scion FR-S / Toyota 86 GT86 General Forum 76 11-27-2011 08:51 PM
Social Network Racer ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 10 10-22-2011 06:47 PM
Playstation Network OldSkoolToys Off-Topic Lounge [WARNING: NO POLITICS] 9 06-09-2011 11:16 PM
Sony Comes Clean: PlayStation Network Hackers have Stolen Personal Data ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 11 04-27-2011 02:53 PM
