Old 12-03-2011, 11:44 PM   #1
Mess11
Drives: Miata
Post Car Advice Toyota 86 review prototype drive
Toyota 86 Review: prototype drive
By Jez Spinks | December 4th, 2011
Can a Toyota be fun to drive? It’s a question that’s difficult to contemplate answering in anything but the negative when you consider the company’s current line-up.
Corolla, Camry, Aurion, Kluger, RAV4… they’re all competent machines that sell in vast numbers and have plenty of admirable qualities. But driving excitement is not among them.
So this is it. After plenty of hype, ‘FT-86′ concept previews and then official pictures, we’ve at last got behind the wheel of the Toyota 86 – the sports car that is aiming to help counteract the company’s conservative image and reach out to younger motorists.
It’s just a few days since Toyota unveiled what it calls a production prototype of the coupe at the 2011 Tokyo motor show as we find ourselves at the Toyota-owned Fuji Speedway racetrack, named after the Japan’s iconic mountain based at the foot of Japan’s iconic Mount Fuji.
There’s not much of a view, however. With the clouds low, grey and depositing plenty of rain onto the track, the only thing towering over the track is a sense of anticipation from the assembled Australian motoring media as we contemplate getting to know the new rear-wheel-drive car in the wet.
There’s a couple of sighting laps behind a pace car first, to help us acclimatise to both the track layout the amount of available grip. And regarding the latter, it’s certainly a greasy surface that will need respect.
Our first Toyota 86 test car is fitted with 17-inch Yokohama low-rolling-resistance rubber that’s borrowed from the Prius to ensure the car isn’t over-tyred. There’s still a reasonable amount of grip, though, considering the conditions.
For a car that takes its name – and principles – from Toyota’s legendary front-engine/rear-drive Corolla AE86, the good news for enthusiasts who remember the 1980s is that the modern 86 is happy to go sideways.
You’ll need to switch off the car’s stability control system, which unlike any other current Toyota will genuinely prevent the electronics from interfering with the angle of the car through corners. Leave the system on and it’s overly intrusive – again in frustrating Toyota tradition.
The saturated track certainly makes it easy to push the 86’s tail outwards, but we’ll have to wait until we run the Toyota in the dry before we can determine whether the engine has enough squirt to achieve the same feat.
The car’s initial attitude to corners is slight understeer, and there’s a sense that achieving oversteer will come easier as a result of lifting off mid corner rather than being trigger happy with the throttle. Either way, there’s a limited-slip rear differential to help keep playtime going.
The 2.0-litre four-cylinder ‘Boxer’engine comes courtesy of Subaru (but adds Toyota direct injection technology) along with virtually all the other mechanicals and Impreza-based platform as part of the joint venture project that has also produced the near-identical Subaru BRZ twin.
It produces 147kW of power, which is respectable when you consider a VW Golf GTI manages just an extra 8kW by turbocharging its 2.0-litre capacity.
Toyota is said to be working on a supercharged version of the engine, but that’s a story (to look forward to) for another day.
Even in the wet it’s clear the Toyota 86 is a car that’s more focused on corners than setting any 0-100km/h standing start sprint records. A highly unscientific seat-of-the-pants feel suggests a time somewhere in the seven to eight-second bracket.
But with that flat four pumping its four cylinders horizontally lower and further back than in any other Subaru, and combined with a circa-1200kg kerb weight, it takes only a few corners of our first flat-out lap to appreciate the Toyota 86 is a very nicely balanced sports car.
The car’s initial attitude to corners is slightly understeer, but as any good driver’s car should, the 86 rewards delicate inputs from the steering wheel and throttle. Or you can just throw it about, so chuckable is the chassis.
There’s a pureness to the steering – at least on the smooth bitumen of Fuji Speedway (so no verdict yet on ride quality). It’s smooth, responsive, and well judged in terms of weighting.
The smallest steering wheel in Toyota’s line-up also feels just the right in the hands.
Fuji not exactly a track that requires lots of heavy braking, but even in wet the brakes provided sufficiently confident stopping power in the one downhill start/finish straight. Everything feels progressive, including the engine.
This was the only part of the track where there was a decent opportunity to rev the engine, which carries a characteristically growly Subaru throb even it’s not as deep as the note heard from a WRX. The revs feel a bit more enthusiastic with the six-speed manual version of the 86, though even the optional six-speed auto will climb towards the 7400rpm cutout without changing gear.
And with the peak power of 147kW produced at 7000rpm, it’s not a waste of time holding onto gears.An automatic would normally be heresy for a keen driver, but the self-shifter at least comes with paddleshift levers that offer some semblance of engagement – as well as blipping the throttle on downshifts.
Choose the manual and you’ll find the shift action notchy, but the throw is nice and short and teams with a well weighted clutch pedal.
And if you’re already wondering how it will compare with its twin, the Subaru BRZ, which it shares virtually everything except the badge and the odd styling detail, we can tell you.
Exactly the same, according to a Subaru insider who spoke to CarAdvice. Not even the suspension tuning between the two cars has been changed, our source says.
If Subaru Australia does decide to bring the BRZ to Australia, that means it essentially boils down to two simple factors: brand preference and price.
With half a year to go until the Toyota 86’s June 2012 launch, the company will says only that it hopes to start the sports car’s price with a ‘3’. Expect a figure in the mid to late-$30,000 bracket rather than low $30,000s, CarAdvice suggests.
We drove pre-production test cars that leave room for some final tidy-ups here and there, but even allowing for that the 86’s cabin still suggests it was built to a mid-$30K price point. There’s no shortage of hard plastics while the cabin presentation is unlikely to win any awards for innovation.
The cramped rear seats also make this a 2+2 coupe rather than a genuine four-seater, though the rear seatbacks fold down to create extra boot space (for items such as spare wheels and tyres for track days, Toyota suggests).
But at least the cabin delivers on the sporty feel. The driving position is low and the driver is partially cocooned by the well bolstered sports seats.
And, crucially, our first overall overseas impressions suggest we may have an answer to our original question: Yes.
Mess11 is offline   Reply With Quote
Old 12-04-2011, 12:45 AM   #2
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Sweet!
- The Ancient BRZ Sacrament
by Zaku
Old 12-04-2011, 01:17 AM   #3
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
june? 30k?
VenomRush is offline   Reply With Quote
Old 12-04-2011, 01:28 AM   #4
Syrianto
Drives: Hondas
Yeah, thirty thousand... plus? D= Hopefully it's cause it's specced out to the max so that if we remove some options it'll be a little more into the twenties range.
Syrianto is offline   Reply With Quote
Old 12-04-2011, 01:48 AM   #5
Tofu
Tofu's Avatar
Drives: Infiniti QX4
Those are in AUD, fyi. Not USD or CAD
Tofu is offline   Reply With Quote
Old 12-04-2011, 02:25 AM   #6
PuGZoR
Long time obsessor
Drives: AE86 & depressing SUV
Car Advice is an Australian website. Mid 30's is about on line with what everyone has suggested as an Australian sale price.
Edit: http://www.caradvice.com.au/149767/t...ototype-drive/
FYI, Camry's start at around 30k + on road costs, with total drive away price being ~$34k. They ramp up to 40k + on roads for a Camry Grande.
PuGZoR is offline   Reply With Quote
Old 12-04-2011, 02:45 AM   #7
coyote
coyote's Avatar
Drives: Slowly
Yep .. and not a very good one.
We just don't have motoring writers the quality of EVO, etc.
coyote is offline   Reply With Quote
Old 12-04-2011, 11:59 AM   #8
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
i guess the "$" threw me off
Old 12-04-2011, 12:14 PM   #9
Ikaros
Solar wind surfer
Ikaros's Avatar
Drives: 2013 FRS
Wow, you guys in Australia get crazy mark ups on your car. What's driving up the cost?
Ikaros is offline   Reply With Quote
Old 12-04-2011, 12:19 PM   #10
Giccin
Giccin's Avatar
Import tax.
Cost to own a vehicle tax perhaps.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 12-04-2011, 12:35 PM   #11
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Love the oxymoron name!
Sport-Tech is offline   Reply With Quote
Old 12-04-2011, 10:01 PM   #12
PuGZoR
Long time obsessor
Nah, gotta remember guys that we're on an island away from the rest of the world, haha, we only sell very low volumes of vehicles here due to our population, and then there's the fact it's really easy to own and keep running old cars. Things like safety testing (which is pretty stringent here) and marketing doesn't get spread over a nice big number of units. Logistics is a huge business here because we're so bloody spread out as well. I think AU is a bit of a cash cow for a few marques because the market is really well insulated from the rest of the world.
Old 12-05-2011, 01:10 AM   #13
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
While Canada is more populated than Australia, we'd likely be in the same boat pricewise if it weren't for being parked next to the big sales elephant that is the US, as many of the factors you mention apply here as well.
Toyota 86 first drive review (Car Guide) a6ela Scion FR-S / Toyota 86 GT86 General Forum 22 03-14-2012 12:34 PM
Autoexpress Toyota 86 first drive review Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 14 12-30-2011 06:08 PM
Insideline Toyota 86 First drive review thread. Matador Scion FR-S / Toyota 86 GT86 General Forum 7 11-30-2011 04:29 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
Autocar's Toyota FT-86 / Scion FR-S First Drive Review Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 128 10-31-2011 03:57 PM
