Old 08-24-2012, 01:22 PM   #1
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
5mph roll up hill or incline, no power?
Question for you guys. I've never noticed this before and I wanted to see if it's normal. I normally don't roll 5mph up a hill, but let's say you're in traffic or someone in front of you decided to slow way down. So I'm rolling at 5mph up an incline or a hill on a manual transmission, and I get on the gas pedal again to speed up. The car bogs and gets no power unless I clutch in and raise the revs first with the gas pedal. This does not happen to level ground, only on inclines or hills. Has anyone have this happen before? Normal?
Edit: Happens on a flat surface too. So I'm rolling at 5mph in 1st, mash the throttle, and the rpms climb slowly to 2000rpm, where it hesitates and bogs. If I stay on the throttle, it usually overcomes it.
Jidonsu is offline   Reply With Quote
Old 08-24-2012, 01:31 PM   #2
ST185RC
Drives: White Out FR-S
If you're in first gear it shouldn't happen. at 5mph, if you're locked out of first, you can double clutch to get back into first to avoid bogging it down.
Most won't agree with the above statement but works for me and I don't have to slip the clutch in second while going up an incline at low speed, putting stress on the transmission.
<flame suit: on>
ST185RC is offline   Reply With Quote
Old 08-24-2012, 01:33 PM   #3
Jidonsu
I was in first gear. Sorry, I should've made that clear.
Old 08-24-2012, 01:52 PM   #4
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
It's just physics. On an incline, your car is heavier (Sorry, i'm not going to do a free body diagram) therefore needing more torque to pull yourself up. And to get more torque, you need higher revs. If I remember correctly, some of the dyno results show that you probably need to be at least around 3k rpm to get enough torque.
Books is offline   Reply With Quote
Old 08-24-2012, 02:03 PM   #5
Jidonsu
That's what I hope it is.
Old 08-24-2012, 03:03 PM   #6
Jlturner
Jlturner's Avatar
Drives: Scion fr-s
Every time I pull out of my underground parking and go up the rather steep incline to get onto the road It feels as if the car isn't going to make it up. I have to pretty much rev up to 3500 RPM before starting the incline or else the car shakes as if it is about to stall out. If the doorway wasn't such a tight turn I could possibly get some momentum built up and I wouldn't have to peel out just to make it up to the road!
Jlturner is offline   Reply With Quote
Old 08-24-2012, 03:16 PM   #7
alyon
I noticed this also. Almost needs a shorter 1st gear. Anything between 0 and 5mph is hell in traffic. Especially on hills.
The other week I got stuck in a 2 mile up hill stop and go traffic. I felt like I was going to kill the clutch. Never again.
alyon is offline   Reply With Quote
Old 08-24-2012, 06:27 PM   #8
Jidonsu
Old 08-24-2012, 06:49 PM   #9
Zaggeron
Zaggeron's Avatar
Drives: '13 BRZ Limited '10 370ZR
I wouldn't worry about it. I've found this car to be more responsive in that situation than my previous daily driver (Mazda 3). Think about all the manual transmission econo boxes running the same roads as you, but with less HP & torque and more weight to boot.
2013 GBS Subaru BRZ Limited 6MT
2010 PG 370z Roadster: Sport/Touring 6MT
Zaggeron is offline   Reply With Quote
Old 08-24-2012, 06:56 PM   #10
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
It's a million times better in these situations than my WRX. Just part of having a 2.0L engine.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 08-24-2012, 06:59 PM   #11
Jidonsu
It's definitely something I don't normally encounter since I almost never try to hit the throttle so quickly from a slow or low rpm roll, but I did notice it today and I can easily replicate it. I just wanted to see if anyone else has seen the same thing. Thanks for the input.
Old 08-24-2012, 07:21 PM   #12
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I never mash the throttle at low rpms.
ashtray is offline   Reply With Quote
Old 08-24-2012, 07:22 PM   #13
Jidonsu
Yea, I only started noticing it because I was behind someone at the light making the left. I was in first gear and he suddenly slowed down. I just lifted my throttle and the speed dropped to 5 or 6mph. I hit the throttle quickly when he moved out of the way, and I felt the bog. I just need to avoid doing that and continue to clutch in and rev first.
Old 08-24-2012, 07:45 PM   #14
ashtray
Yeah, if you lifted at 5mph up hill, you were probably 1/2 second away from a stall if you kept it in gear - but I've been there. You lift, your left foot starts going for the clutch, then your path clears so you're back on the gas, but the car ain't happy.
That's why the 5-60mph time for this car is so much slower than 0-60. You lose a few seconds during that bog.
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-27-2013 12:49 AM
Hill Holder on Manual Transmission? devinclfalcons Engine, Exhaust, Transmission 73 04-28-2013 01:18 AM
Castle Hill Performance T/C 86 mroczeK Engine, Exhaust, Transmission 91 08-23-2012 12:48 AM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 06:44 PM
AT BRZ just landed in Chapel Hill DantKR Southeast 11 06-14-2012 08:50 PM
