Tracking / Autocross / HPDE / Drifting What these cars were built for! |
02-22-2022, 08:06 PM | #1 |
Drives: 2022 BRZ
2022 Twin to STR
Finally classed to STR
https://cdn.connectsites.net/user_fi...pdf?1645577607
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
The Following 8 Users Say Thank You to Simmons For This Useful Post: | Autoxer62 (02-23-2022), bholliday (02-23-2022), Breezio (02-22-2022), otter (02-22-2022), SCFD (02-22-2022), strat61caster (02-22-2022), timurrrr (02-22-2022), whataboutbob (02-22-2022) |
02-22-2022, 08:11 PM | #2 |
AutoX-10/10ths every run
...#31899 2022 Twins are Rad
Thank you for your input... lol
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
02-22-2022, 10:54 PM | #3 |
Drives: 2022 BRZ, 2008 S2K CR Delete
That was my letter I said to class the damn car in STR as there's really no where else to put it, no additional time is going to magically make it reasonable to put it in STX, etc. I said do that, or give it it's own provisional STX2 class, which is why I got a TYFYI
The Following 3 Users Say Thank You to Banannie For This Useful Post: |
02-23-2022, 08:23 AM | #4 |
This should make for some interesting STR battles.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
02-23-2022, 10:24 AM | #5 |
Drives: 2013 Subaru BRZ
I love that Gen1's get a longer lifespan in STX. It'll create a great battle in STR and leave STX as-is (which is perfect).
The Following 4 Users Say Thank You to PointDSM For This Useful Post: |
02-23-2022, 03:29 PM | #6 | |
Drives: Miata
Put them on the same line along with the 2022 and update/backdate engines and final drives? Last edited by racingfool; 02-23-2022 at 04:28 PM. |
02-23-2022, 06:07 PM | #7 |
Write a letter and ask for that. It certainly seems reasonable to ask for all the first gens to be on the same line.
The Following User Says Thank You to Autoxer62 For This Useful Post: | DocWalt (02-24-2022) |
02-24-2022, 04:27 AM | #8 |
Custom User Title
STX participation will take a noticable hit though. Don't get too comfortable if numbers slip a lot this year.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
02-24-2022, 03:05 PM | #9 |
Drives: 2022 GR86
02-26-2022, 01:07 PM | #10 |
Drives: 2022 BRZ
I got the rains mounted,.....that should mean it will never rain right?
2022 BRZ 71 STR
The Following 3 Users Say Thank You to Simmons For This Useful Post: |
02-26-2022, 05:03 PM | #11 | |
lol, didn't notice the screenname initially. I'm assuming it is way past time for you to get a new car :P
The Following User Says Thank You to whataboutbob For This Useful Post: | strat61caster (02-26-2022) |
02-26-2022, 06:43 PM | #12 |
Well because they’re on separate lines you can’t swap parts between them, yes the frs/2017 is a typo but not the underlying problem they’re looking at.
One of the neat/terrible things about street prepared is update/backdate, so you Could legally put a 2017+ engine with the extra 5hp into a 2013 chassis assuming the cars are on the same line in the classing, which it’s currently proposed that they are not. If the ‘22+ ends up on the same line you could put the 2.4L into an early car. The gearing options may be worth considering as well, not sure much else is. On the newer cars a knuckle swap might be interesting. Whether that’s the right call idk, not many people are interested in playing with those rule sets these days, it’a a lot of work for not a ton of gain. |
The Following User Says Thank You to strat61caster For This Useful Post: | DocWalt (02-28-2022) |
03-20-2022, 07:59 PM | #13 |
Drives: 2022 BRZ
My 1st event in the brz. It was a test and tune and was around 48 degrees.
2022 BRZ 71 STR
The Following User Says Thank You to Simmons For This Useful Post: | DocWalt (03-23-2022) |
04-04-2022, 10:26 AM | #14 |
Drives: '22 BRZ
First autocross weekend in the history books! The car is phenomenal! I tested back to back with an ND2 Miata in STR and I don't think we can hang in STR yet (but it will be close with tunes to fix the low rev limiter) but the car is so dang fun I don't even really care. Love the easy adjust Karcepts swaybar and the Shaftworks USA shocks. I made one swaybar change early Saturday at the Test and Tune (math said I should have been where I ended up, but I was lazy and set the swaybar softer) and I didn't do anything for shocks, adjustment wise. I'm really really happy with the car.
My Saturday TnT run: Amy's TnT run: Sunday's event was defined by crummy off and on rain. I made no changes for the wet and I was clearly the fastest in the wet, but it dried out and I coned away my fast run, then it rained again for Amy and she was faster in the rain than in the dry but coned it away too. Ignore the squeaking in the video, we left our trunk junk in because of the rain and the mic was picking up the squeaky styrofoam. I'll share our faster runs first. My fastest raw time: Amy's fastest raw time: My fastest clean run: Amy's fastest clean run:
The Following 6 Users Say Thank You to DocWalt For This Useful Post: | bcj (04-04-2022), Desertnate (04-04-2022), Kado (04-04-2022), RedReplicant (05-05-2022), Simmons (04-11-2022), strat61caster (04-04-2022) |
Similar Threads | ||||
2022 Twin to STR | Simmons | BRZ Second-Gen (2022+) -- General Topics | 11 | 03-01-2022 10:03 AM |
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition | Hachiroku | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 13 | 02-12-2022 11:44 PM |
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition | Hachiroku | BRZ Second-Gen (2022+) -- General Topics | 20 | 02-10-2022 11:44 AM |
2022 Toyota Land Cruiser Revealed With New Platform, Twin-Turbo V6 | vh_supra26 | Other Vehicles & General Automotive Discussions | 24 | 07-07-2021 01:44 PM |
what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
