Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-10-2020, 01:40 AM | #1 |
Drives: 13' BRZ
No power to windows
So there I was cleaning my GSF and minding my own business at home. Kids came down to the garage and I decided to roll the DS window down to bump some music out of the BRZ while they rode their bikes around. I sat there taking a break enjoying the great weather California has to offer when it’s not on fire.
Called it a day, and turned the car on to make sure battery hadn’t died. Left the windows as they were and closed the garage. Following day I decided it was time to wash the car so I turned her on and attempted to close the windows, Nothing happened, I thought hey I might’ve pushed the window lock button and I pressed it to verify that it wasn’t on, still nothing. I noticed the PS window was also completely inop and both DS and DS switches were not illuminating like the rest of the interior lights. I checked and replaced the fuses to the doors in the engine bay compartment even though they weren’t blown just to make there wasn’t a slight chance I missed one. I obcourse did the things that require less work first so I disconnected the battery for 10 minutes thinking it would reset. Nothing changed. I then decided to remove both door panels in hopes I would find a loose connector. I removed and reinserted the plugs behind the switches. Again nothing. I thought maybe if I replace the DS window switch it’ll fix everything🤷🏽*♂️ So I drove down to a Subaru junkyard and purchased a used switch that I verified was in working condition. I connected the new to me switch and nothing. That’s where my hopes and dreams completely shattered and I ran out of ideas😂 I’ve started reading and going through the schematics to give the troubleshooting a try but it’s slightly overwhelming to understand. Just because I was badass at trouble shooting electrical issues on Marine Corps vehicles does not mean I know how to TS 😂. It’ll take me a while since I’m not too familiar and I don’t have a sense of direction of where to even start besides power.. Just wanted to share in hopes someone had a similar or if not the same issue that would save me time ! Tyfyt |
09-10-2020, 09:13 AM | #3 | |
Drives: 2016 BRZ
I'm not completely sure that's going to work since that assumes the switches are getting power and he wrote...
09-10-2020, 09:23 AM | #4 | |
Drives: 2013 frs raven
09-10-2020, 09:39 AM | #5 | |
Drives: 2016 BRZ
But I do know they flash if a there's a problem. (30 seconds into the video you'll see) You could still be right though, maybe this is an extreme case....but if the pins don't get power there's something else wrong further down the circuit (captain obvious moment here). So it's probably worth checking. The fact that he went to a junkyard to get another working switch panel to try and it still didn't work is what makes me curious about the power to the harness in the door. The reset is still worth trying, might as well cross off as many options as possible. |
09-10-2020, 09:47 AM | #6 |
Fair enough. Hopefully it's as simple as a re program and he's good to go
09-10-2020, 11:59 AM | #7 | |
Drives: 13' BRZ
I’ve tried that window reset procedure multiple times when I first encountered the issue but without power there is no use of it. |
Similar Threads | ||||
Removing Power Windows | ja1217 | Tracking / Autocross / HPDE / Drifting | 3 | 07-25-2017 01:26 AM |
Power windows recall | Packofcrows | Other Vehicles & General Automotive Discussions | 5 | 10-21-2015 04:36 PM |
Power Windows Not Operating | Andrizzle | Issues | Warranty | Recalls / TSB | 13 | 03-04-2014 10:53 PM |
Power Windows acting funny | sufu05 | Electronics | Audio | NAV | Infotainment | 5 | 12-03-2013 11:58 PM |
Power windows do not stop | brzing | BRZ First-Gen (2012+) -- General Topics | 5 | 07-10-2013 02:06 PM |
