Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
01-14-2020, 05:53 PM | #1 |
Drives: 2015 BRZ
Someone help, new user, wheels rubbing!
I recently bought a brz with 18 inch enkei rs05rr fitted with 235/40/18 tyres. But I find that when I'm going down hills and turning my front wheels rub somewhere in the fender. I think its behind the wheel itself but i'm not sure. Has anyone else had this issue and if so, what can I do to fix it?
Edit: I do not know the offset of the rims, but it wouldn't be that negative. Also im fairly sure its the tyre rubbing not the rim. Edit: The car is also on a stock suspension and is not lowered Last edited by josh.condor; 01-14-2020 at 08:36 PM. |
01-14-2020, 06:30 PM | #2 |
Jack up car, remove wheel and find where it is rubbing.
What size and offset are the rims? Is the car lowered? Do you have adjustable coilovers? Do you have a sane wheel alignment IRT camber and toe? My 235/45 17 on Enkei RPF-1, 17 x 8 +45, clear everywhere, the tyres are 25.33" diameter, yours are 25.4", stock is 24.62". I would hazard to guess your ride height, offset or size, or combination of all 3, are not compatable. Disclaimer: I used google for the tyre diameter size.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
01-14-2020, 06:47 PM | #3 |
Drives: Crapcan
Need to know the wheel offset. Likely it is rubbing the spring perch if it is on stock struts.
01-14-2020, 08:47 PM | #4 |
Drives: jrsc_brz
you can put wheel spacers on th bump it away from the inner well/ suspension parts. you run the risk then of rubbing on your fenders, but you might get by with no problems. take the wheel off and inspect it
01-16-2020, 01:58 PM | #5 |
Drives: ‘13 FRS
Watch THE WORLD'S FASTEST INDIAN and bring a sharp carving knife.
01-16-2020, 02:03 PM | #6 |
Rust bucket enthusiast
Our cars don't handle 9"+ wide wheels and less than +40 offset on stock suspension. It will rub. Get coilovers to significantly increase the space for wheels if you want wide wheels
Tags |
brz, dunlop, enkei, tyres, wheels |
Similar Threads | ||||
Will 18*8 +45mm offset wheels fit with stock shocks without any rubbing all around? | tommyc321 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-15-2018 08:22 PM |
*Anyone tried 215/50 tires on oe wheels? Any rubbing? | Lonewolf | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 12-16-2017 10:55 AM |
Widest wheels without rubbing on stock springs with eibach springs ? | H214M | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-09-2017 11:41 AM |
What does your user name mean? | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 356 | 05-01-2016 08:52 AM |
Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? | Eazy-V | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 11-02-2014 09:42 PM |
