Software Tuning Discuss all software tuning topics. |
12-07-2019, 10:12 PM | #1 |
Drives: brz
Lean after 5500rpm
C
12-08-2019, 04:22 AM | #2 |
Drives: brz 2017 hksv2
Ecutek pdf of gt86 tuning just says it is used internally by Ecu and there should be no need of adjusting
If you raised the Engine load limit, did you raise also the Mass airflow limit? |
The Following User Says Thank You to tomm.brz For This Useful Post: | solidsnake11 (12-08-2019) |
12-08-2019, 05:01 AM | #3 |
Ok whwn you do FI on tjese cars you need to rescale the MAF load limit AandB tables, the maf max load limit, thte maf air flow limit. And rescale a bunch of fueling timing vvt, pi\di ratio tables.
You also donrt want to run the di max pulse width past about 6.5 ms and the port injectors past about 15 ms. You might also want to change the di max quantity allowed table to allower higher flow at higher rpm If you dont rescale load limit ravles and !ax load and max flow rate tavles the ecu calculates the true load but it get truncated at those limits and will cause lean runnng once limits exceeded |
The Following 2 Users Say Thank You to steve99 For This Useful Post: | gt7877 (12-08-2019), solidsnake11 (12-08-2019) |
12-08-2019, 05:09 AM | #4 |
More than 4 of engine load and more than 500 grams of air of maf, lol
And I thought my 2.5 of load with 1 bar of boost was high.. |
12-08-2019, 05:15 AM | #5 |
Ok jad a look at the log
Id say max load is still at 4 it might need to be increased you hit 4 load at 15 psi , avout 450 g\s od air flow the air flow and boost keep increasing to 21 psi and 670 g\air flow but load stays at 4. So looks like its hitting load limit or air flow limit Your also very close to maxing maf sensor at 5v Check the max load limit i think stock it 4 and mas air flow limits stock is 200 from memory |
The Following User Says Thank You to steve99 For This Useful Post: | solidsnake11 (12-08-2019) |
12-08-2019, 10:13 AM | #6 | |
It s like a racerom patch so it doesn t cap at 4 That s another reason for you to upgrade to ecutek |
12-08-2019, 10:21 AM | #7 |
Unfortunately is expensive, I know well, I spent those 1000€ it costed me
But it has his advantages Also the kit and racerom license are highly resellable You can also put failsafe strategies, you certainly can t with tactrix Not gonna save a weak rod to snap like in my case, but you get to save the engine if something out of your control fails |
12-08-2019, 11:20 AM | #8 |
I think it s a different logic there, but don t know.. I wouldn't know how to convert that "100%" in our tables
I just use the load comp table just to make small adjustments to the afr without modifying the maf, scaling, and the maf oat comp to make the ecu correct the afr based on charge temp (not really necessary as I use forced closed loop even when car is supposed to be in open loop state, but it makes the fuel trims similar in every ambient temperature) If 4 of engine load is your invalicable limit, I would make the maf scaling a lot leaner than then real needed, to make engine load calculation smaller, and then make the afr richer directly from the primary open loop table and by offsetting the port injection scaling, like putting a smaller "cc" value But seems sketchy and not sure it would work |
12-08-2019, 06:38 PM | #9 |
That table is just an enrichment of the afr target for when advance multiplier drops from 1
Like, if am goes to 0.9, the 10% of the values of that table gets added to the afr target It is to cool the chambers when it knocks, it will be no help for your problem Be careful with those knock correction and super lean afr at 7k rpm with 22psi of boost :/ Last edited by tomm.brz; 12-08-2019 at 06:54 PM. |
12-08-2019, 07:16 PM | #10 |
I m spending like 6000 euro to rebuild my engine, and for you is not a big deal to throw away a functioning engine.. But you can t spend money for ecutek? That i do not really understand
With ecutek you can hook that Wideband permanently to the ecu and even use it to command a closed loop until redline, you Don t even have to scale well the maf or set up all those odd tables like you are doing now to make it work It can also make super simple the management of the wastegate and even of the flex sensor you ve bought |
12-08-2019, 07:41 PM | #11 | |
Drives: Toyota 86 GTS
Example: If you multiply the entire maf scale by 1.1, load will increase by 10%. "Load" is a very arbitrary number, really only purpose is looking shit up in tables. No reason to go past 4, don't need that much resolution. It's a bandaid but it's better than all the other many bandaids in tables that you've linked. Also, if you've disabled fuel trims in open loop, you're not using the maf scale for learning trims, so who cares the scaling on it. |
The Following User Says Thank You to Wayno For This Useful Post: | solidsnake11 (12-08-2019) |
12-09-2019, 03:04 AM | #12 |
Put lower cc value on PI scaling and make afr target richer
The Following User Says Thank You to tomm.brz For This Useful Post: | solidsnake11 (12-13-2019) |
12-09-2019, 05:50 AM | #13 | |
I think at this point it probably worth considering ecutek. Runnong 15 plus psi boost !axing out load and close to maxing out maf . Its probably worth gping ecutek to get higher load limits without hack. A boost cut failsafe. Built in closed loop boost control ( you jist need mac valve or solenoid, no controller) . It will do throttle close or fuel cut overboost cut or both. Speed density ( hybrid with maf if needed) and flex fuel. Yeah it more money but you could sell oft to offset cost. Unfortunatly you will need racerom extension as well as cavle and licience |
The Following User Says Thank You to steve99 For This Useful Post: | solidsnake11 (12-09-2019) |
12-09-2019, 06:44 AM | #14 |
With ecutek you set different boost also based on gear, and would be your car more usable always
You can also set an antilag if you want |
Similar Threads | ||||
Car Running Lean | MyGT86Yas | Software Tuning | 9 | 09-24-2019 07:46 PM |
16 or 32 bit ECU? Should I lean the air if.... | chazmuska | Software Tuning | 2 | 07-12-2017 06:48 PM |
Running lean ? Maybe ? | lizbrayan | Engine, Exhaust, Transmission | 35 | 06-19-2016 12:16 AM |
lean at idle only | woode | Forced Induction | 5 | 05-03-2014 04:48 PM |
running lean | EZWood | Engine, Exhaust, Transmission | 26 | 10-18-2013 12:53 PM |
