Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
BRZ Wannabee
Drives: 2013 Limited BRZ
Dreaded p000b; Please Help!
I really need help. As a background, I have a 2013 BRZ Limited and I randomly got a p000b code 8 months ago when I first put my JDL uel header and OFT stage 2 tune on; cleared it, and didn't think much of it. The last few months I've been getting the p000b code every 3 weeks, but now it's becoming more frequent than that. Additionally in the last month, it's gotten very cold in New England and sometimes at idle the engine would become very lumpy and feel as if the cam timing had completely reversed; it would go away if I turned the car off and on again, or if I gave it some gas. Some times it would then generate a p000b code minutes afterwards, sometimes not. A few days ago I got fed up and reflashed my stage 2 tune, and the idle problem went away. I drove a few hundred miles and the p000b code came back. Now I swear I hear a ticking noise after I let the engine idle (could definitely be paranoid...), and I'm worried that I could be causing engine damage the longer I let this problem persist?
The p000b code seems completely random. It's not when I make hard pulls, it's usually when I'm just driving along; sometimes it came up after the engine got super lumpy at idle. Is there any ways I can diagnose this myself? I've seen the Subaru bulletin for this issue and read the nightmare horror stories on this forum. Realistically my choices are below: 1. Have my guys at Monroes put the stock header back on, reflash the factory tune, pray the p000b code pops back up, and then drive 3.5 hours to the dealershit where I bought the car. My f*cking factory warranty expired a few days ago. Hope they don't give me crap for the ECU flash counter, and somehow cover the cost of the work. 2. Have my guys at Monroes provide a sanity check, then take it to a more local dealershit leaving it stage 2 and forget about the warranty, and then just pay out of pocket. 3. Just keep clearing the code every couple days lol. Let me know if you think there's anything else that could be contributing to my problem that I can check into. Thanks! |
#2 | |
Since I don't know anything about it ..... I would suggest you disconnect the battery, drink a beer, reconnect the battery ...... to see if the ECU had just hiccupped and will right itself. humfrz |
#3 | |
[insert cool phrase here]
Drives: BRZ Premium
If your warranty is gone I'll just ask how much your guys at Monroes would do the work. You know dealers are pure rape. Might as well ask around for something cheaper
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following User Says Thank You to Mr.ac For This Useful Post: | humfrz (01-15-2018) |
#4 | |
Huge E85 fan!
Drives: 2016 Scion FRS
![]() never disconnect the battery and clear a code unless you KNOW what and why the code was thrown! The tech will need to be able to retrieve that data to see when it happens. I'd just drive in, mods and all and ask them to look at it. Bring brownies or a cake or lasagna for the service writers (I'm dead serious- my wife is the master at this) and be as nice as can be. They won't check for the tune. But the prob with flashing back to stock is that then you will lose the data from the events and the tech will need that. |
#5 | |
![]() I've had situations where I gotten a code and I cleared the code with a code reader and the code came back. I then disconnected the battery, to clear the code and reset the ECU, and the code hasn't come back (for over a year now) ..... ![]() However, all this "code stuff" is new to me. Back-in-the-day, we could look at and listen to, an engine and tell what the problem was ........ ![]() I'll defer to those more in the know ...... ![]() humfrz |
Drives: 15 BRZ LTD, 05 FXT
Start by not going to Monroe. They are there to slap pads on Camrys and Civics, and sell everyone that comes in a $50 air filter after blowing the original one out with an air gun.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
P00B is. code for camshaft Slow response.
Check your oil level Check your running correct type and viscosity oil Tunes can excersise the cam actuators faster or over a larger range wgich can show up latent issues in the cam actuators or oil control valves. But is not actually a tune problem Puting the stock tune back may srop the code for above reason, but thier is still a problem somewhere |
#8 | |
BRZ Wannabee
#9 | |
BRZ Wannabee
#10 | |
The early cars 2012-2013 had their fair share of cam issues. best work through the TSB and eliminate each possible cause. once you clear codes in these ecu their is no record in ecu unfortunately |
#11 | |
Huge E85 fan!
So yeah, bring brownies and a good disposition! |
#12 |
BRZ Wannabee
Update... The oil change made the engine noticeably smoother, and I had high hopes. However just now after a hundred miles the car went indy limp mode for p000b again...... At this point I'm wondering how long I can keep clearing the code before I start causing serious mechanical problems? Car is 3 weeks out of warranty and stage 2 modified, but the problem started months ago. I guess I'm gonna have to suck it up and go to the dealershit?
#13 | |
Drives: Car
#14 |
BRZ Wannabee
Another update, not good news...cleared the code and drove home, and something is now noticeably wrong. Above 5k RPM the car doesn't accelerate any more and you can hear the exhaust cam whine and struggle; it feels very unhealthy and I'm not gonna push it. I live in an apartment complex so I can't do the work myself.
Code P000B | CTB727 | Issues | Warranty | Recalls / TSB | 15 | 10-15-2023 12:19 PM |
OCV Keeps Failing P000B Fault Code | Gumberculies | Issues | Warranty | Recalls / TSB | 6 | 11-12-2018 08:09 PM |
Fault Code P000B, before I got to the dealer | TURBObro10 | Issues | Warranty | Recalls / TSB | 4 | 11-08-2016 04:29 PM |
p000b | Djratrap | Issues | Warranty | Recalls / TSB | 8 | 08-29-2016 02:33 PM |
Dreaded lights went away | frosty86 | Issues | Warranty | Recalls / TSB | 11 | 03-27-2013 10:04 PM |
