Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
10-06-2016, 07:34 PM | #1 |
Drives: 2013 Subaru BRZ
Code P000B
So my CEL has been coming on and off over the past few weeks with a code P000B - cam position sensor slow response, bank 1 position B. Can someone tell me where exactly this is located?
I have searched everywhere and can't seem to pinpoint exactly where this is. I bought a sensor from the dealer and hopefully this solves the issue. I'd imagine with the CEL being intermittent that it's a sensor issue, and not something mechanical. |
10-06-2016, 08:57 PM | #2 | |
have a look at the tsb here related to rough idle cam position and cam sensor shimming. http://www.ft86club.com/forums/showthread.php?t=21868 Unfortunatly it might not be as easy as the sensor it could be the cam sprocket/actuator or the cam oil control valve that causing the slow response to ecu commands. ie the sensor is ok or a problem with the ecu itself Last edited by steve99; 10-06-2016 at 09:41 PM. |
10-06-2016, 09:26 PM | #3 | |
humfrz |
10-06-2016, 09:52 PM | #4 | |
Also I read the about the cam sprocket TSB. My car exhibits NONE of the other symptoms or codes. So I will go with the sensor first. Thanks for that very insightful and informative response though. |
10-06-2016, 11:12 PM | #5 | |
yes that the reason I referred you to the TSB section see here while this tsb is for cam position censor cam shimming it does show you can sensor location, and if you note it does not mention P000B http://www.ft86club.com/forums/attac...6&d=1375302652 however I would suggest you read the TSB below as well it does mention P000B , it looks like you have not seen this one . note it does suggest multiple causes for the problem and requires extensive diagnostics and replacement of expensive components such as oil control valves, camsproket/actuator and ECU , but none of them being the cam sensor itself. 02-132-12 : DTCs Relating to the AVCS (Active Valve Control System) |
10-06-2016, 11:25 PM | #6 | |
I didn't mean to challenge your ability to diagnose and fix your car's problem. I was just trying to be helpful, by suggesting you take it to a professional, experienced in these matters ..... humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | guybo (10-10-2016), Ultramaroon (10-11-2016) |
10-06-2016, 11:55 PM | #7 | |
quite a logical suggestion, given the amount of diagnostics and expensive parts that can contribute to this issue, even the dealers have trouble with this problem. |
The Following User Says Thank You to steve99 For This Useful Post: | humfrz (10-06-2016) |
10-10-2016, 07:15 PM | #8 |
Thanks. Just an update, bringing the car in to the dealer tomorrow. Found that position B is out of reach. Also not trying to take everything apart on my daily driver when I have a 60 mile daily commute.
Will let you all know what the issue is. |
10-11-2016, 02:28 PM | #9 |
Drives: 2015 Subaru Blue Series - Pearl
GL dude.. dealer has had my car in several times for this same issue replacing Oil control valve(OCV ) several times, cam sprocket, and ECU. They have had my car for 3+ weeks now with no idea on how to fix. I recently filed a Motor Vehicle Defect Notification with Subaru.
2015 BRZ Series.Blue CWP (K1X) - JDL UEL Header, 3" JDL Res FP, 3" JDL OP, 3" Perrin Res Cat back, 3" Perrin BigMAF Intake/Inlet tube, Perrin Light Weight Pulleys (AC, Water Pump, Crank) - Moto-East FFK - E85 Tuned by HRI - ECUTEK - Eibach Pro-Kit Lowering Springs
10-11-2016, 10:48 PM | #10 |
Well, $395 later. Apparently the powertrain warranty doesn't cover sensors? They replaced part number 10921AA230, valve assembly - oil control. Also says "replace bank one camshaft sensor to correct", even though a part number isn't listed or priced.
The Following User Says Thank You to CTB727 For This Useful Post: | shiumai (10-11-2016) |
10-13-2016, 08:44 PM | #11 | |
Drives: BRZ DGM Limited
Did that fix the issue? |
10-14-2016, 03:42 PM | #12 |
I doubt it as i've had both replaced in my car.
10-23-2016, 04:31 PM | #13 |
It's been nearly 1000 miles, and so far yes.
I'm speculating here but I honestly wouldn't be surprised if running 0W-20 in Florida for so long has caused some of my issues. I also had oil seepage that was repaired (under warranty) back in June. |
09-03-2018, 01:18 AM | #14 |
Drives: gt86 aero kit
Hey found any solution ?
Similar Threads | ||||
Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 11:27 AM |
p000b | Djratrap | Issues | Warranty | Recalls / TSB | 8 | 08-29-2016 02:33 PM |
Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 10:19 PM |
CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 01:27 AM |
u0115 code? | ThisGuy919 | Issues | Warranty | Recalls / TSB | 1 | 11-11-2013 12:09 PM |
