Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
Drives: 2013 WRB BRZ 6MT
AC compressor pulley not spinning when dis-engaged?
So I just noticed the other day that what appears to be the AC compressor pulley doesn't spin sometimes, seems to be when the compressor isn't engaged. I'm just curious if this is normal operation or should it always be spinning?
In case I'm confused and it's not the AC compressor pulley, I've circled the pulley in question in this picture: ![]() |
#2 | |
It is called a clutch pulley and will only spin fully when engaged. Sometimes the belt will just touch it and it will spin but not be doing anything.
The Following User Says Thank You to Tcoat For This Useful Post: | Lynxis (05-03-2017) |
Thanks Tcoat. Everything seemed to be operating normally so I wondered if it was normal operation but just wasn't sure and thought I should check.
It is actually a clutch pulley not an idler. I typed faster than my brain functioned.
#6 | |
My response is always driven by the post prior to it.
#8 | |
My TYPE of response ...
The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (05-03-2017) |
"click" sound only when throttle is engaged, and dis-engaged AT | BRZPDX | Issues | Warranty | Recalls / TSB | 50 | 10-11-2016 01:08 PM |
Rust developing on a/c compressor pulley | nickmerronesucks | Issues | Warranty | Recalls / TSB | 9 | 09-25-2015 02:49 PM |
SOLD Cusco Engine Pulley Belt Cover Aluminum Blue Anodized Alternator Compressor | hirollaz | Engine, Exhaust, Bolt-Ons | 2 | 05-31-2015 02:25 PM |
pulley not spinning and then spins loud noise | Composite | Engine, Exhaust, Transmission | 19 | 12-11-2014 07:09 AM |
Spinning at Buttonwillow (1CW) | ddeflyer | Tracking / Autocross / HPDE / Drifting | 76 | 05-22-2014 08:24 PM |
