Old 04-09-2017, 12:59 PM   #1
JDM4E
Drives: Honda Accord Euro
Exclamation Cross winds at high speed (un)stability
I recently testdrove MY2017 BRZ finally, and being on autobahns I can do some speed. I immediately noticed, that while the car being stable at high speeds, it was very vulnerable to (probably) any wind. The surface was smooth, so I don't think it was bad roads but rather wind, also I did not feel anything in a steering wheel (like from low-profile tires, etc).
I checked the forums and there are hints about it there and there, so I think it is worth to its own solution thread.
Around 100 mph car is "jumping" left and right, while obviously I drove straight. The car was stock, dealers presentation model. I am unhappy about it, since I want from a car to be able drive at those speeds at ease and it is one of the reasons I wanted a good handling sports-car. I have never experienced vulnerability like that in any car I have driven, including estates with much more side-area. And lastly, my Accord with the same Primacy HP tires (225/50/17) is rock stable at those speeds. No feedback and soft, but stable.
Do anybody know a reason for this, and more importantly, can anything be done to solve this to be at least "normal"?
Thank you!
JDM4E is offline   Reply With Quote
Old 04-09-2017, 03:46 PM   #2
strat61caster
strat61caster's Avatar
Personally I do not believe it is wind, I had an old boxy '80s truck that was absolutely affected by wind and you could hear and feel when a gust caused the car to move. The 86 is absolutely less affected by crosswinds and large commercial vehicles due to it's low profile. There are some here that believe it is wind, I regularly drove across a bridge that routinely gets flagged with 'high wind advisory' 30+ mph gusts easily on a good day, the 86 is very easy to maintain in lane provided the alignment specs are conservative.
IMO it is wheel alignment and road related, ask for an alignment to be performed on the car, a little toe in all around will likely have it feel just like you want it to, factory alignment specs are not perfect, and maybe the dealership set alignment to be a bit more aggressive during pre-sale inspection since that's what many 86 buyers like.
ineedyourdiddly
Old 04-09-2017, 03:50 PM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
I think it's dependent on the following element..
Old 04-09-2017, 03:59 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It's a dealer's model- check underneath and make sure the panels under the car are all there. Maybe it's been in an accident and the alignment is off? I get some cross wind buffeting but not as bad as you describe, though it got worse when I installed the lip kit. It doesn't get really squirrelly until over 120 MPH.
Old 04-09-2017, 04:02 PM   #5
ls1ac
ls1ac's Avatar
We drive well over 100 on the track and have never noticed that. We do use track tires and a good alignment, so I doubt it is body related.
Old 04-09-2017, 04:09 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
I would start with the tires (uneven wear/uneven pressure) and then look at alignment and/or buckled wheels and then suspension (loose components) and then chassis for alignment..
Old 04-09-2017, 04:27 PM   #7
JDM4E
Thanks, so basically you are saying it is not wind and it is not normal? That would be great. BTW weird, that it is worse with the lip kit - that should decrease lift if anything.
Old 04-09-2017, 08:26 PM   #8
strat61caster
IMO it may still not stable enough for your comfort as it is a lightweight car, maybe your threshold for comfort is different than ours. I'd call the salesman up and say "hey the high speed stability concerned me, I would be very interested in the car if you could solve that, I believe a four wheel alignment may help, if you can have that done I'd love to test drive the car again, oh and I'd like to see the alignment printout of that isn't too much trouble"
If they refuse, head out to another dealer and hop in a different car. There's other things too like tire pressures and potential unseen damage, some cars had spring spacers not removed early on, things like that, but imo alignment has the biggest impact to how the car acts.
ineedyourdiddly
Old 04-09-2017, 09:16 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, why not check tire pressure from steps listed by yourself at any fuel station?
Old 04-09-2017, 09:45 PM   #10
ryoma
ryoma's Avatar
keep in mind that the stock alignment is a wide range. you will get better results if you specify a certain alignment setting. I personally use the following settings:
Front:
Camber: -2
Caster: 6 degrees
Total Toe: 0
Rear:
Camber: -1.5
Total Toe: 1/16" total toe in
Old 04-09-2017, 10:00 PM   #11
cjd
cjd's Avatar
Drives: 2017 BRZ
Front:
Camber: -2
Caster: 6 degrees
Total Toe: 0
Rear:
Camber: -1.5
You can't touch that front alignment until you own the car. It will take more than just the common factory crash bolt, which typically maxes out ~-1.4deg camber. And caster will usually fall a touch short, ~5.8.
The car is definitely sensitive to alignment.
The other thing to consider here is that the car may simply be providing that much more feedback, so it's easy to notice those little annoyances where other cars they'd be absorbed by all the little things that make the car feel mushy...
Old 04-09-2017, 10:46 PM   #12
7 skulls
Drives: 2014 scion frs
I have felt this too OP. Windy day, strong gusts hitting the rear quarter make the back end of the car feel uncomfortably light at 100 mph. (Deserted highway, I had just been passed by an Audi A4 and sped up from limit just to see how fast he was cruising.) After a few seconds of "Whoa, this is new!" I dropped back to 60 and the car went stable again. Alignment is good, tires were almost new, pressures good. I do have the stock rear spoiler.
I think it is more to do with the shape of our cars. Not saying they produce gobbs of down force or anything but I remember a video on the development of the car where the Japanese engineers were talking about the shape and how every crease has a purpose aerodynamically. Even the little canards on the tail lights are there to do something.
A strong, gusty wind on the rear quarter definitely does lighten the tail end and push the car around a little at those kind of speeds, IMO. If I hadn't experienced it, I would have been skeptical.
7 skulls is offline   Reply With Quote
Old 04-10-2017, 01:59 AM   #13
Mr Nerd
Mr Nerd's Avatar
I am in the same boat as the OP and have been baffled ever since I joined the forums that no one really compains about this.
When I first purchased the car I was extremely concerned about the squirly feeling this car has on the freeway. I bought 2 different sets of tires and got it aligned probably 4 times, had the dealer check everything probably 3 times and never found a solution.......until summer time.
I purchased my car during our windy season. When Summer came along and the wind went away it was like a completely different car. It is now windy season again and it drives me nuts!
I feel like it is a combo of the VSC, electric power steering and the electronic brake distribution trying to over compensate at times. I am convinced that these systems are still ACTIVE AND VARIABLE at all times even when the dash lights aren't indicating it(unless in peddle dance mode).
Mr Nerd is offline   Reply With Quote
Old 04-10-2017, 05:38 AM   #14
JDM4E
Thanks for the input. If you have this kind of behavior on the same roads with the correct setup, it seems like the wind is the variable. Perhaps you can try drive in pedal dance mode then? Personally I think it is highly unlikely this to be caused by ESP, but you never know. Can you try?
Stability Control intervention at very low speed smbstyle Issues | Warranty | Recalls / TSB 10 07-15-2016 02:11 PM
High winds + large water tank = Manji Off-Topic Lounge [WARNING: NO POLITICS] 10 10-06-2015 12:33 AM
High RPM for current speed HachiRo Engine, Exhaust, Transmission 14 04-02-2015 02:59 PM
Light weight and high winds in a Subaru alluringreality BRZ First-Gen (2012+) — General Topics 49 03-01-2014 06:04 PM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 12:37 AM
