Old 04-03-2016, 11:46 AM   #1
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Engine Oil getting too hot Track use
so im using a Fullblown motor turbo kit 300v motul oil 5w30
i been getting temps over 250F during track use
i do have an oil cooler ( full blown as well ) right behind my passenger foglight - was considering moving it to get more air.
upgraded radiator and fans
whats next? LOL hood vents?
needs some advise i want to continue track use but my temps are getting really high
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 04-03-2016, 12:05 PM   #2
Dream20b
Y u do dis?
hood vents. They will also reduce underhood pressure.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 04-03-2016, 12:14 PM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Hood vents seems like the best thing honestly. Maybe turn the foglights into air ducts, too?
MS, CSCS, TSAC-F, CPT
Old 04-03-2016, 12:20 PM   #4
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
My oil temp on track is consistantly around 130-135°C (270°F)
My car is Vortech supercharged and I use either 5W30 or 5W50 which I change every 3-4 track days.
I've had zero problems after two and a half years supercharged and 28 track days which includes some amateur racing.
So 250°F wouldn't worry me at all, but that's just my opinion...
YMMV
Fish Eagle is offline   Reply With Quote
The Following User Says Thank You to Fish Eagle For This Useful Post:
Tcoat (04-04-2016)
Old 04-03-2016, 12:35 PM   #5
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
YMMV
Have you logged your oil pressure?
I am guessing that the pressure will fall dramatically at those temps.
When you come in from a run with oil that hot, my SWAG says you will be down below 10 PSI at idle.
justatroll is offline   Reply With Quote
Old 04-03-2016, 12:36 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Thanks for breaking forum rules and not searching! been covered more times than 99% of the other topics, along with, "will this coilover setup rub???" and a classic "what exhaust should I get??"
....but thats none of my business.
If we have to make a new member advice sticky, I'm out.
Old 04-03-2016, 11:29 PM   #7
Northwest86
Drives: Velocity Orange 86 GT
Ive never had issues but our turbos are in better spots and way more effective at carrying heat away even with stock radiators. Depending where the oil cooler is you can try ducting in air and ducting it away. Hood vents will increase airflow. Dont remove the air dams around the radiators as that bleeds alot of air away. Maybe a heat exchanger upsize.
Northwest86 is offline   Reply With Quote
Old 04-03-2016, 11:53 PM   #8
swarb
Air going towards the oil cooler will take the easiest path and go around the oil cooler instead of through it. Maybe some ducting?
Old 04-04-2016, 08:40 AM   #9
Ashikabi
Ashikabi's Avatar
Hood vents and or ducting/relocate on oil cooler heat exchanger
Old 04-04-2016, 10:54 AM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
250F is just fine for the track.
The Following User Says Thank You to King Tut For This Useful Post:
Fish Eagle (04-04-2016)
Old 04-04-2016, 01:29 PM   #11
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
agreed, 250F is fine. Change it frequently (I change it every 4 - 6 track days)
Sleepless is offline   Reply With Quote
Old 04-04-2016, 01:32 PM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I hit 250F on the street before my oilcooler. You will be fine lol!
Old 04-05-2016, 03:39 PM   #13
sw20kosh
Drives: 2013 Black FR-S
As you get faster/better and as the temp here in CA increases in the summer you will see higher oil temps.
I would try the CSG Track Spec hood vents as it dramatically decreased my temps at the track:
I also have a big oil cooler (setrab 25row series 9) located in the main airflow .
The Following User Says Thank You to sw20kosh For This Useful Post:
Nu_era (04-06-2016)
Old 04-05-2016, 09:54 PM   #14
ryoma
ryoma's Avatar
first of all, try moving your oil cooler to a spot that has more airflow. I would assume behind the foglight will have minimal airflow; try centering it in your front grill and see what temperatures you get. I have the JR oil cooler and I struggle to get past 210F when under hard load either in canyon runs or just some street pulls. I am waiting until my next track day in May to see what temps I get.
Engine Oil for DD/Track EINSTEIN562 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 69 11-21-2015 08:35 PM
track driven car - Engine noise - click on driver side - vid philooo Tracking / Autocross / HPDE / Drifting 1 04-27-2015 08:09 PM
LSx engine swap for track use, thread foodman Tracking / Autocross / HPDE / Drifting 77 03-16-2015 03:23 PM
Engine 11 Track Bike (Socal) Cop Miscellaneous 0 09-24-2014 09:49 PM
Check engine light at the track Thongpocket Issues | Warranty | Recalls / TSB 7 05-12-2014 08:54 PM
