10-05-2013, 10:11 AM | #953 |
Drives: 2013 FRS
10-05-2013, 10:44 AM | #954 |
Drives: Scion FR-S
That belt will be too big. Since your pulley is .48" smaller than the stock pulley (3.48") you'll need to subtract that difference on the belt length, bringing you down to a belt length of 97.0". If you can find a belt that's just a hair shorter than 97.0", it should be a very snug fit & less likely chance of belt slip.
The Following User Says Thank You to Rick@Vortech For This Useful Post: | ft86me (10-05-2013) |
10-05-2013, 11:50 AM | #955 | |
Thupercharged
Is there perhaps a chart with the different pulley sizes and the respective peak PSI at factory redline?
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
10-05-2013, 01:44 PM | #956 | |
Drives: Scion FR-S
The one thing I can tell you is that every pulley size you go down, it usually equals a 1-2psi increase (I say "usually" because your overall altitude comes into play in certain areas). Again, it all depends on what's done to your car & where you live (altitude comes into play). For example, someone with a 2.87 pulley in Los Angeles (just about sea-level) may make 16psi, but someone in Denver with that exact same pulley on the exact same car may make 11psi (those are just random numbers. strictly for example) Going from a 3.48" to a 2.87" is one heck of a jump. At that point, I would do the calculations to make sure you don't over spin the blower. Again, that's just me. |
10-05-2013, 01:48 PM | #957 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
It's right about 14psi on our engines give or take based on elevation
Nolan
The Following User Says Thank You to pheoxs For This Useful Post: | Rick@Vortech (10-05-2013) |
10-05-2013, 02:34 PM | #958 |
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
There's a write up about it, under google how to read a compressor flow graph, after doing it to establish the difference between the rotrex and the vortech... After doing all that I'm never gonna ask the psi of xxx again because I realize how violently of a shift the psi you will see based on ambient air and how good your intercooler is doing its job... To sum up my experience with doing all that (you can see it in the kraftworx thread) all I can say is I'm Jon snow and I know nothing.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
10-06-2013, 01:18 PM | #959 | |
For a 3.00" you will likely need to be running the 962 belt. They do not make a blue belt or even a green belt (drats! this is for a chevy 2500 too!). This should fit nice and snug placing you cold at roughly 1/3 tension on the tensioner. I have a 3.125" pulley but a passenger side idler with ~ -0.1-.2 (i forget the exact, my stock one got completely obliterated with a 975 belt and a 3.125 pulley within 20 miles on the highway with cruise control on) size difference and the 962 was the only belt that i could run without snapping it within 200 miles. Just make sure once you put this pulley on you verify your pulleys are lined up as close as possible. There is a lot more "play" in the backplate angle than you may realize which can easily cause issues with your belt.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
10-07-2013, 05:40 AM | #960 | |
Drives: BRZ D4S 6MT L Vortech
10-07-2013, 07:13 PM | #961 | |
10-10-2013, 07:09 PM | #962 |
Sounds close but probably 12psi instead. I think the 2.87 makes 14psi
Nolan
10-11-2013, 12:42 AM | #963 |
Thupercharged
Ordered the FA20club 12psi upgrade as well as injectors/fuel pump.
Going to measure the pulley when I get it to see what size they are using for this.
2013 FRS
10-11-2013, 03:49 PM | #964 |
Maybe 3 inch. 3.125 got me 10psi
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
10-12-2013, 10:20 PM | #965 |
According to the dynos weather station 3.125 gave me 11.5psi at 7100 rpm. Ecutek logs with checking ambient atmospheric pressure of my 3var showed 11.5 at 7400
Your exhaust flow and can tuning cam affect this boost reading. Unless someone has installed a pre-intercooled iat sensor you may not get the info you want. However my pulley is nearly that size and I have been doing a lot tests including multiple dyno sessions. Maybe if you just tell me what you are aiming to find I can just directly answer it.
10-12-2013, 10:25 PM | #966 |
I tapped 360whp on the dyno today with a 3.125 pulley and e80 fuel. . Plot shows hood open vs hood closed.
Stock exhaust. No snorkel. 3.125 pulley. Fa20club flex fuel and tune. Dw65 Pump 540cc injectors. Berk test pipe.
Similar Threads | ||||
Vortech Supercharger | denverizzles | Forced Induction | 176 | 10-19-2013 06:48 PM |
New Vortech Supercharging System Information... | Brian@Vortech | Forced Induction | 306 | 11-08-2012 05:49 PM |
Supercharging the GT86 | Billy2224 | Engine, Exhaust, Transmission | 13 | 06-05-2012 03:58 PM |
Turbo/Supercharging Your FRS | BoostJunkie | Engine, Exhaust, Transmission | 123 | 05-18-2012 06:26 PM |
Supercharging: the forgotten form of FI | madfast | Engine, Exhaust, Transmission | 76 | 03-02-2012 05:06 PM |
